1963 wiring problems maybe - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Impala 1st - 5th Gen Discussion
Impala 1st - 5th Gen Discussion 1958-1985. Discuss all Chevy Impala 1st Gen - 5th Generation Performance and Technical Discussion here. Includes 1964 and 1967.
Old 07-26-2012, 05:43 PM   #1 (permalink)
bigmanvoodoo's Avatar
i recently bought a 1963 Impala 2 door. i got it home and started checking things over and well motor Check, brakes check, windows check, brake lights...errr uh oh. i had one brake light so i started i noticed some corrosion on the sockets no biggy to fix. got that taken care of. then i noticed that the drivers side are much dimmer than the passenger side. hit the blinkers and nothing. turn headlights off and i got blinkers. go to turn the head lights back on and nothing. wiggle the knob( ha ha) and i get lights. long story short could my head light switch be causing the problem?
bigmanvoodoo is offline   Reply With Quote
Old 07-26-2012, 06:48 PM   #2 (permalink)
Back in Black
12ltz's Avatar
Sounds like it to me or at least check wiring on back of switch.
12ltz is offline   Reply With Quote
Old 07-26-2012, 07:05 PM   #3 (permalink)
Storm Trooper Ralf
MixedImpala04's Avatar
Omg I hope you don't have the same prob i had on my 65, on the steering column there is a switch, check. For all your power functions there, if you don't have power their where you are supposed to change the switch, if everything is good go to the tail lights and check all the connections. I can take a picture of the switch on the steering column if you like but you should be able to see it, its got like eight wires coming out of it.
MixedImpala04 is online now   Reply With Quote
LinkBack to this Thread: http://www.impalaforums.com/impala-1st-5th-gen-discussion/328375-1963-wiring-problems-maybe.html
Chevy Impala Forums This thread Refback 07-26-2012 08:16 PM
2001 impala wiring problems randman26 Audio, Video, and Electronics 8 11-14-2012 07:37 AM
62 Bel Air wiring problems (Tail lights or Head light swtich) slammedtoys Chevy Bel Air 3 11-11-2011 10:23 PM
Rear wiring harness 1963 Belair gtaylor Restoration Forum 2 02-14-2011 08:04 AM
Heating Problems/Cd Problems ethelaugg Chevy Impala Discussion 0 01-14-2009 08:03 AM
Wiring Classic1 Automotive Discussion 3 09-21-2008 12:14 AM
