1970 Impala Fuel tank sending unit - Chevy Impala Forums
post #1 of (permalink) Old 06-09-2010, 09:45 AM Thread Starter
klard's Avatar
I have a big block 1970 Impala that has a fuel tank sending unit I need help with. I have never seen one that looks like this. It is a canister type with two lines running to it. Is this common on a big block? I need a replacement or need it rebuilt but in reality I would like to know more about what I have.
Thanks, Ken
ID:	1785   Click image for larger version
klard is offline
post #2 of (permalink) Old 06-17-2010, 10:14 PM
Daddio041's Avatar
It's the stock sending unit. I just pulled one out of my tank last week.
"That which does not kill me has made a grave tactical error"
Daddio041 is offline
post #3 of (permalink) Old 07-29-2010, 12:45 PM
alanator's Avatar
Just joined the site and saw your post. I just aquired a 1970 impala from my 99 yr old grandmother. It has less than 55k miles and has been garaged all its life with the last ten years just sitting there. The fuel guage has not worked in several years so I just replaced it. The problem is the replacement only has one line where as the original had two. I drove it for the first time after replacing it and after a few miles, the car started to hesitate. I plugged the small line because there's no where to connect it. I think that's why it is starting to hesitate? Can I tee this 1/4" line into the vapor line going to the tank?
alanator is offline
post #4 of (permalink) Old 07-16-2012, 08:21 PM
velvet muldoon's Avatar
i just pulled off my gas tank and found a similar unit in my 70 4dr with a small block 400. only it has one line and doesnt have that bag thingy on the bottom....curious. i took it out because the gauge didn't work. its alot different than the ones various sites would lead me to believe i need for a replacement. rebuild sites or advice anyone?
velvet muldoon is offline
post #5 of (permalink) Old 07-16-2012, 09:50 PM
Gregg-O's Avatar
Velvet, That baggy thing is known as a sock, make sure you have one on when you get a replacement unit. It's pretty much the 1st line filter you have to protect everything else.
Gregg-O is offline
post #6 of (permalink) Old 07-18-2012, 04:25 PM
yeah i thought it was supposed to have a sock filter. where did it go? did it dissolve? can i get a replacement sock? the sending unit is fine the float was a little tight though.
post #7 of (permalink) Old 05-16-2015, 10:22 AM
DrumFunken's Avatar
I have come across the same problem with my 1969 Impala 350 custom.
Lost the fuel gauge did some research found the ethanol was destroying the old ones so I ordered a new one. Not knowing what the original looked like i didn't know better. After dropping the tank I found this
also noticed the top had two lines and the tank had a separate vent line off the top of the passenger side.
I checked the fuel pump and sure enough there is a return line.
I however cannot find a replacement for this fuel sending unit any where. '
Did any of you find a fix????????
DrumFunken is offline
post #8 of (permalink) Old 05-26-2015, 10:40 AM
DrumFunken's Avatar
Ok so Found the correct answer to this Problem.
It was a Canadian made part and only came on Impala's with A/C to keep the fuel pump wet for those who would start there car with the A/C On.
The correct replacement part number is
Spectra Premium "FG106A"
It does not have the canister but has the return lines and proper 3/8" send and 1/4" return. It took stopping at a lof of dealerships till I finally found one in NJ that said I wasn't crazy and provided me this information. I have not ordered it yet but supposedly it is the replacement for the canister style sending units with the old canister type.
I will be ordering one soon and will let you all know whether or not it fits.
Wish me Luck!!!
The Following User Says Thank You to DrumFunken For This Useful Post:
PMBell357 (05-26-2015)
6th gen fuel pump sending unit ???? POPIMPIN CUSTOMS I.N.C 6th Gen Engine Performance 5 03-12-2010 05:37 PM
fuel tank sending unit may be in my future ssety Automotive Discussion 7 11-27-2009 07:57 PM
Fuel sending unit ibm9902003 Chevy Caprice 0 08-08-2008 03:25 PM
Help: 96 RM Fuel sending unit needed uaart1 Wagon Discussion 3 07-17-2008 09:24 AM
how do you install a fuel sending unit to a 1963 Impala? Michael V Chevy Impala Discussion 1 06-06-2008 07:44 PM
