LS2 engine into a 1963 Impala - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Impala 1st - 5th Gen Discussion
Impala 1st - 5th Gen Discussion 1958-1985. Discuss all Chevy Impala 1st Gen - 5th Generation Performance and Technical Discussion here. Includes 1964 and 1967.
Old 11-16-2008, 12:15 AM   #1 (permalink)
Bigtoe's Avatar
I just purchase a 2006 6.0L and tranny that came from a 2006 Silverado Super Sport. What is involved in order to install these 2 items to my 1963 Impala and How much ?
Bigtoe is offline   Reply With Quote
Old 11-16-2008, 04:20 AM   #2 (permalink)
Gregg-O's Avatar
For starters, a new fuel system, You need to be able to handle the high pressure & make-up a return line which the '63 doesn't have. The wiring harness from the truck, probably an oilpan. The computer from the truck. & at least $1000.
Old 11-16-2008, 02:39 PM   #3 (permalink)
Bigtoe's Avatar
I do have the wiring harness and the computer from the truck. Would i have to fabricate motor mounts?
In order to use the tranny what will i need to do?
Old 11-16-2008, 03:00 PM   #4 (permalink)
77Impala's Avatar
Most likely you will need to have motor mounts and tranny mounts fabricated. You may need to have the drive shaft modified. New exhaust system will have to be made. Do you have all of the sensors that this engine's PCM needs, including the O2 sensors?
Old 11-16-2008, 08:56 PM   #5 (permalink)
Bigtoe's Avatar
Yes, I have all the sensors. I am guessing I will have to "chip it"? Any suggestions?
My 1963 impala is a SS, which means it has a floor shifter. The SS silverado tranny is a column shift. Any suggestions? Kits?Info?
Old 11-17-2008, 05:37 PM   #6 (permalink)
77Impala's Avatar
Here in this thread are some places to have the PCM reprogrammed.
http://www.impalaforums.com/resource...rograming.html
On the tranny shifter you might check some of the salvage yards for a totaled out 96 Impala SS or some other car and see if the floor shift kit is still in it and modifiy it to your car.
Old 11-17-2008, 08:55 PM   #7 (permalink)
Blackout's Avatar
Send a message via AIM to Blackout
Here, these links should help you with your engine swap.
Swaping ls2 into 1960 Biscayne
http://www.hotrodlane.cc/PDFFILES/60biscayne.pdf
Where to buy parts for the swap (Request a Catalog)
Blackout is offline   Reply With Quote
Old 11-18-2008, 08:33 PM   #8 (permalink)
Bigtoe's Avatar
So i went to pick the engine up. It is actually a 6000 Vortec 6.0L with a 4l85-e tranny. I figured I would take it. I bought them both for 900.00. Any info on putting this on a 63 chevy would be great.
Thanks everyone for your help
Old 05-09-2010, 04:38 PM   #9 (permalink)
zuesmyrott's Avatar
Did you get that 6.0 in yet?
LS-1 powered 76' Impala
zuesmyrott is offline   Reply With Quote
Old 05-09-2010, 04:45 PM   #10 (permalink)
Impala Fanatic
HammerDown's Avatar
That would be one badass '63, wouldn't it?
Justin
HammerDown is offline   Reply With Quote
Old 05-16-2010, 12:12 AM   #11 (permalink)
Wheel Man's Avatar
There's been a few done. Here's a couple links for you:
http://www.ls1tech.com/forums/conver...a-project.html
http://www.ls1tech.com/forums/conver...nvertible.html
http://www.ls1tech.com/forums/conver...rbo-build.html
Wheel Man is offline   Reply With Quote
Old 10-27-2010, 12:33 PM   #12 (permalink)
theSSpimp's Avatar
Jegs or Summit Racing might have some kind of brackets for this or at least some that just welds in. I would give them a call.
theSSpimp is offline   Reply With Quote
1963 Impala w/ 283ci Engine Question 1963-Impala-SS Impala 1st - 5th Gen Discussion 4 05-05-2009 01:05 AM
Engine wont start in 1963 impala? Erick R Chevy Impala Discussion 3 05-29-2008 12:39 AM
1963 Chevy Impala 283 engine w/powerglide engine swap to a LS1 & 4l60E? Ben Chevy Impala Discussion 0 05-03-2008 02:50 AM
1963 Chevy Impala best fuel efficiency engine setup.? Ben Chevy Impala Discussion 0 05-03-2008 12:27 AM
1963 Impala 283 engine swap to a LS1? Ben Chevy Impala Discussion 4 05-02-2008 11:52 AM
