Column shift question 73 impala - Chevy Impala Forums
  • 1 Post By plano-doug
post #1 of (permalink) Old 05-19-2017, 12:36 PM Thread Starter
dunnhole's Avatar
I have an issue with my column shifter, when I bought it for whatever reason the electronics are on off then the mechanics. When in park on the column the transmission is in park and the column and transmission always match properly. The electronics on the other hand do not, when in park my reverse lights are on and I can not start it, when in reverse I can crank it over and car thinks it's in neutral, so forth and so on. Where do I begin to look for the problem here. This is new to me, is it in the column or the transmission.
Sent from my SM-G955U using Tapatalk
dunnhole is offline
post #2 of (permalink) Old 05-19-2017, 12:44 PM
Quoted: 68 Post(s)
I cannot say with absolute certainty, but I believe the neutral safety (lock-out) switch is on the steering column above the driver's feet/legs. If you can get under there - you need to be kinda limber, and you need to remove some some trim pieces, as I recall - you should be able to find it, and adjust or maybe replace it. As I recall, the switch can be adjusted to correct for your issue, by shifting it sideways a bit.
Anyway, I'm pretty sure this is your issue.
I took a quick look at Oreilly Auto - they have this part for your 1973 Chevy
List: Neutral Safety Switch - 1973 Chevrolet Impala | O'Reilly Auto Parts
BTW, if you study the images, you may notice how the mounts are slotted to allow the unit to be rotated side-to-side a little to adjust it.
dunnhole likes this.
post #3 of (permalink) Old 05-19-2017, 06:58 PM Thread Starter
dunnhole's Avatar
Perfect this is probably exactly my problem, so the column shifter hits the different plates as it shifts through the gears, if I have this right, and I should hopefully be able to just adjust to match actual position of shifter. Thanks a lot.
dunnhole is offline
« New guy question | - »
Steering column 1995-96 Chevy Impala Caprice column shift with key RSS Bot Impala Diecast Toys Cars on eBay 0 09-02-2015 07:40 AM
1965 66 chevrolet impala belair biscayne tilt column , column shift nice RSS Bot Impala Diecast Toys Cars on eBay 0 05-24-2015 08:20 PM
1986 olds cutlass column shift steering column refurbished! Nice! RSS Bot Impala Diecast Toys Cars on eBay 0 04-04-2015 09:00 AM
1986 olds cutlass column shift steering column refurbished! Nice! RSS Bot Impala Diecast Toys Cars on eBay 0 03-10-2015 07:30 AM
1986 olds cutlass column shift steering column refurbished! Nice! RSS Bot Impala Diecast Toys Cars on eBay 0 02-03-2015 06:10 PM
