key Stuck in Ignition Fix - Chevy Impala Forums
Go Back   Chevy Impala Forums > General Discussion > DIY How To's & Write Up's
Old 04-02-2013, 12:08 PM   #1 (permalink)
systemcheck2006's Avatar
This is for the 2006 Impala where the Key wont come out of the ignition and you will only need a flat head screw driver. First you need to identify the rubber plate below the key, pry it open with a flat head screw driver. Then with a flashlight on the right-hand side of the opening you will see a white object with a silver piece of metal protruding from it (it's a button as seen in the forth picture). You need to take your flat head screw driver and push the button up while turning the key. That's it, that is one way to key your key back out.
If anyone has a write-up for replacing this object let me know, and post it in this forum.
then you'd be normal."
systemcheck2006 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to systemcheck2006 For This Useful Post:
valleygirl (12-22-2013)
Old 05-09-2013, 08:57 PM   #2 (permalink)
vaboi's Avatar
My key tends to get stuck in the ignition from time to time and all I do is push up on my shifter and my key is released. I have never had to tear apart the ignition area.
vaboi is offline   Reply With Quote Quick reply to this message
Old 05-10-2013, 12:28 AM   #3 (permalink)
g25racer's Avatar
Ahh what a neat access panel. Gm must have been expecting problems, eh?
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline   Reply With Quote Quick reply to this message
Old 05-10-2013, 05:52 AM   #4 (permalink)
Yeah, been stuck doing this for about 2 months now. Funds a little low now, hopefully I can get a permanent fix soon, Not too fond of removing the air bag to fix this, so I'll end up taking to a "pro".
Old 06-06-2013, 07:56 PM   #5 (permalink)
gamepro56's Avatar
Yea I would do the same
gamepro56 is offline   Reply With Quote Quick reply to this message
Old 12-22-2013, 05:55 AM   #6 (permalink)
valleygirl's Avatar
Thumbs up 2008 Chevy Impala Key Stuck In Ignition
https://www.youtube.com/watch?v=mFco-bP0wI4
This happened to us yesterday! I found this video, we got the key out. I also found some info through my local library. They have a chiltonsonline manual. Looks like this is a common issue for many people. Here is a link on Key Stuck In Ignition.
http://content.chiltonsonline.com/TS...x4vdPU2A%3d%3d
valleygirl is offline   Reply With Quote Quick reply to this message
Old 01-23-2014, 06:45 PM   #7 (permalink)
king38fan's Avatar
What is the name of that particular part? On my wife's 2008 Impala the cylinder will not stay in so I am thinking some sort of retainer ring has disintegrated or otherwise disappeared. I want to order a new one but need the name of it. Thanks for any help.
king38fan is offline   Reply With Quote Quick reply to this message
Old 01-24-2014, 10:18 AM   #8 (permalink)
Well for me to fix the key issue it turned out to be a broken off wire from the shift solenoid (near the floor shifter). spliced new wired reinserted and the key came out on it's own.
vaboi (01-28-2014)
Old 06-23-2014, 02:25 PM   #9 (permalink)
Grateful
Grateful's Avatar
Thank you! Thank you! I borrowed a friend's car and listened to the radio until the battery died and the key wouldn't come out of the ignition. Your photos were priceless and your step by step instructions were right on. I used the arm of a pair of reading glasses to push the button up because there wasn't screwdriver in the car. Worked perfectly. Thank you again!
Old 07-17-2015, 11:41 AM   #10 (permalink)
creedx1's Avatar
Angry key stuck in ignition
I have a 2009 Impala and the shifter was stuck in park. I replaced the wiring connector to the shifter and now it works great but the key is stuck in the ignition. I've noticed if I hold the brake and touch the green and purple wires together then turn the key on and back off the key when come out. Does anyone have any ideas on how to fix this? This is about the 7th electrical issue I've had with this vehicle. I have never owned anything but GM products but this is probably my last one.
creedx1 is offline   Reply With Quote Quick reply to this message
Old 07-22-2015, 06:24 AM   #11 (permalink)
retiredpauly's Avatar
Wondering if the actual switch connected to the shifter ( that the connecter plugs into ) may be pooched ?
We are all born ignorant but one must work hard to remain stupid .
retiredpauly is offline   Reply With Quote Quick reply to this message
Old 07-26-2015, 08:23 AM   #12 (permalink)
creedx1's Avatar
Im not sure but I did get two new connectors just to see if the first was faulty but still have the same problem. wonder if it may be a fuse? any help would be very appreciated.
Old 07-26-2015, 01:02 PM   #13 (permalink)
Are you sure that your RAP fuse is OK? If the RAP fuse it bad, it will also not allow the key to come out of the ignition. The RAP fuse is in the passenger site "footwell" area fusebox and is kinda hard to see/access - it's up behind the metal relays (they kinda block it from being seen). It's a red fuse.
jtrosky is online now   Reply With Quote Quick reply to this message
creedx1 (07-26-2015)
Old 07-26-2015, 05:36 PM   #14 (permalink)
creedx1's Avatar
Thank you. That fixed it. I didn't even see that fuse the first time I checked. I'm disappointed that Chevy hasn't issued a recall for this but I'm grateful that people are willing to help each other with these problems.
Old 07-26-2015, 06:50 PM   #15 (permalink)
Believe it or not, I've found that this community tends to know more about these cars than the dealer service departments do! It's an awesome community and makes owning these cars so much more enjoyable!
Glad to hear it was just a simple issue. Hopefully, you'll be problem free for a while now.
2007 impala 3.9 key stuck in ignition stuck in park dalejrfan88 Chevy Impala 8th Gen Discussion 11 01-11-2016 12:01 PM
key stuck in ignition wink4life Chevy Impala Discussion 15 11-25-2013 01:07 PM
Key Stuck in Ignition - Won't turn to OFF Orioles Chevy Impala 8th Gen Discussion 2 04-02-2013 12:15 PM
Stuck ignition lock cyliner Michelle03 Impala 1st - 5th Gen Discussion 0 04-20-2008 12:28 PM
