3400 V6 cooling system bleed - Chevy Impala Forums
Go Back   Chevy Impala Forums > General Discussion > DIY How To's & Write Up's
Old 12-06-2012, 03:45 PM   #1 (permalink)
This is how to properly bleed the cooling system on your 3400 engine, perhaps you have no heat at idle, or perhaps you just replaced a component, or maybe just a basic drain and fill. Regardless of why, this is what to do.
First, fill the overflow reservoir to the "full hot" line. Next, loosen the bleeder on the water pump outlet, both bleeders are 7mm.
Then fill the radiator till fluid starts coming out of the bleeder, close the bleeder and stop filling. Put the radiator cap back on, and start the car. Turn the heater controls all the way to hot, and let the car warm up to operating temperature. Once warm, open the bleeder screw on the thermostat housing
Once air stops coming out of the bleeder, close it.
Leaving the heat on full, drive the car around the block. You should now be free of any air pockets in the cooling system. Don't forget to recheck the level in the overflow tank.
iallynx1 (01-15-2015)
Old 12-06-2012, 06:45 PM   #2 (permalink)
Back in Black
12ltz's Avatar
Good write up King, maybe make this a sticky
_________________________
2012 Impala LTZ 72,000 miles
12ltz is offline   Reply With Quote Quick reply to this message
Old 12-07-2012, 10:05 AM   #3 (permalink)
Already done, and thanks.
Old 12-07-2012, 10:45 AM   #4 (permalink)
Originally Posted by 12ltz View Post
Good write up King...
X2.
I've got it bookmarked. ctrl-B .
plano-doug is offline   Reply With Quote Quick reply to this message
Old 04-07-2013, 06:37 PM   #5 (permalink)
Lentzjj's Avatar
Can you still purge the air out when you break the bleeder on the pump?
Lentzjj is offline   Reply With Quote Quick reply to this message
Old 04-08-2013, 04:29 AM   #6 (permalink)
g25racer's Avatar
Yes you can
Replace the bleeder or ..
1. Fill rad
2. Leave cap off and start car
3. Squeeze upper and lower rad hoses to squeeze out air
4. Let engine warm up
5. Add coolant as necessary
6. Squeeze hoses again and use towel if need be to protect hands
7. Check coolant again and refill, also fill overflow tank to correct line
8. Go for a decent drive and check coolant level once engine cools down
Monitor engine temps during this whole process and leave heater on full blast. You should see via your temp gauge the coolant thermostat open and your temps dropping. If your temps spike your T-stat is either stuck closed or you have a big air bubble yet.
I have done this many times and it has never failed me or have I ever had issues. It's just not worth the risk for me to break the bleeder valve. I'd rather do it the good ole' fashioned way.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to g25racer For This Useful Post:
Lentzjj (04-10-2013)
Old 04-08-2013, 10:59 AM   #7 (permalink)
That will also work, just more of a pain.
Old 04-09-2013, 12:34 AM   #8 (permalink)
g25racer's Avatar
Agreed but, if your bleeder valve is broken you really don't have a choice.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
Old 04-19-2013, 08:10 PM   #9 (permalink)
johnccc's Avatar
I drained mine out and refilled without even using the bleeder, just filled it up at the reservoir and the rads cap.
Since the coolant will not be doing any cycling whatsoever before the car warms up, due to the thermostat been closed, usually 180 degrees before it opens, you may be low on fluid, I simply let the car warm up by driving it around, carrying extra water/coolant in a 1 gallon jug. Once the temps reach the middle area, they may go a tiny bit over, turn off and let cool for about 10 minutes or so, then add more fluid, its been keeping me cool for months like that.
However, the bleeder is the right way to do it as it will not require any top offs after the original fill up.
Metallic Cyber Gray 2011 Chevy Impala LT (Standard Fleet Equipment) (automatic)
Includes Stock Remote Starter
Mods:
LOUD Advent PRO9233N Alarm system
iSimple Solutions Gateway & SiriusXM Tuner and Bluetooth - Hidden in dash (Uses Stock Radio)
Window Tint
Chrome Window Pillars (almost done)
Future Mods:
Chrome Door Handles
Foot area LED Strips (Also replace all interior bulbs with LEDs)
Chrome 5 spoke 20" Rims (later on)
johnccc is offline   Reply With Quote Quick reply to this message
Old 05-24-2013, 11:51 AM   #10 (permalink)
Dr.SwineSmeller's Avatar
Kingnutin the Genius
Kingnutin, you are my hero.
Long story short, I was ready to trade my 3400 Impala, as I had fought an overheating problem to the point I was disgusted. After reading a lot of BS with people having the same symptoms/problems on various forums and no one with an obvious answer other than people blowing thousands of dollars on unneeded repairs that didn't fix the problem, I found this thread.
Bottom line, I followed your instructions, and my chronic overheating problem was cured.
This forum is bookmarked!!
You da' man, Kingnutin!!
Dr.SwineSmeller is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Dr.SwineSmeller For This Useful Post:
kingnutin (05-24-2013)
Old 05-24-2013, 12:08 PM   #11 (permalink)
Forum Foto Fanatic
tonyc712000's Avatar
Welcome Doctor! Feel free to use this forum whenever necessary! King is pretty cool, eh? Oh, and we can use a doc here sometimes....
Hey King, yer gonna have to grease your ears to get through doorways...
1994 Caprice-Sold
Current ride-
2012 Chevy Sonic LTZ
2000 Impala 3.4
This car is going to my son. We will fix it together.
LS options
Mods: K&N Drop-in filter
Future add-ons: Chevy centers, trim rings,
Window tint
tonyc712000 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to tonyc712000 For This Useful Post:
Dr.SwineSmeller (05-26-2013)
Old 05-24-2013, 01:28 PM   #12 (permalink)
Much needed help!!
Thanks TonyC.
I feel like I should send you guys a check for repairs.
Old 05-24-2013, 03:47 PM   #13 (permalink)
Happy to be of service! I pick up lots of little things along the way with how much I work on these cars, it would be criminal not to share.
Old 05-26-2013, 02:31 PM   #14 (permalink)
Thanks again
That is more than a little thing.
From my I-Net research, I learned this is a very common problem with the 3400, but no one out there seemed to know the right fix (and be it so inexpensive).
I have now driven my car a few hundred miles since properly bleeding the system per your instructions, and she runs like a new one now.
Here was my key to finally figuring I must have some kind of circulatory problem, per the way the car was operating prior to the proper bleed....
1) The heater would only work at speeds of 70mph and greater. Let off the gas on the freeway, and cold air instantly blew from the heater. Once I bled the system, hot air returned to being perfectly normal. Evidently, the air lock was within the heater lines/coil? The worse the heater progressively worked, the more often the car would overheat.
To think I went all winter without a heater, and had continuing intermittent overheating problems, was ready to sell my perfectly good and paid for Impala, and all I needed was a proper bleed... Jeez.
I also learned that any engine maintenance, including parts replacement, anti-freeze change, and even in some cases, just taking off the radiator cap, can cause the cooling system to ingest air. Hence why the problem is so common I assume. The bigger problem is, unknowing suckers are paying countless dollars for unneeded repairs. My mechanic suggested we put an intake manifold gasket on. I asked if that would cure the problem. He said, "I can't guarantee that." Needless to say I skipped his suggestion minus a guarantee. I also will find a new mechanic, though I do most of my own work, my job is long hours, and sometimes for routine stuff I will pay to have work done.
Thanks again KingNutin. You made a big difference in my budget. I couldn't afford a car payment. Thanks to you, I don't have to worry about that.
kingnutin (05-28-2013)
Old 07-07-2013, 09:15 PM   #15 (permalink)
LA1
LA1's Avatar
something I would like to add that is in the same general venue. When you change your coolant. Instead of using tap water, use distilled water. Get 3 x 1 gallon jugs, what you have left over use for your battery ( if fillable).
LA1 is offline   Reply With Quote Quick reply to this message
cant bleed air out of cooling system richp04impala Chevy Impala 7th Gen Discussion 26 03-14-2015 10:29 AM
How long does it take to bleed air out of coolant system? unioncreek Chevy Impala 7th Gen Discussion 5 04-26-2012 06:28 PM
95 caprice 9c1 cooling system capriceclassic93 Chevy Caprice 9 06-21-2011 12:54 AM
Cooling system issues Borderguy190 Mechanical and Electrical Problems 4 02-10-2010 10:49 AM
How do I bleed air from power steering system in an '03 Impala .? sweetyebug3 Autocare and Maintenance 2 05-28-2008 11:50 AM
