| DIY How To's & Write Up's This forum contains some of the best How To's and Write Up's that have been posted by members. |
Turn signal flasher volume adjustment
One complaint I had with my 2010 Impala was that the turn signal flasher was not loud enough. Knowing that it was integrated into the BCM and/or radio, there was no way to change to a different flasher. So I decided to live with it. Out of curiosity, I looked at the chime setting which was at "normal'. I chnaged it to "loud" and it also changed the volume of the turn signal flasher volume to an acceptable level. The owner's manual DOES NOT mention this, and a search here did not find anything, so I felt that I should post this as it might help others.
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
I discovered it when I reset the chime volume, and noticed next time I drove the car the turn signals were louder. So I set the chime volume back to normal, and the turn signals went to a lower volume. So I will keep this set to "loud".
#9 (permalink) |
To change the Chime setting you will use what I believe is the 3rd button down out of the four that are located on the dashboard just to the right of the cluster. (where you reset you tip and check your tire pressure) It is the only button that you have to be in park to use. Then keep hitting it until you find Chime and change it to your desired volume
#11 (permalink) |
![]() ![]() Join Date: Mar 2010
Not really. Ever driven behind an old person in FL? If it could be completely silenced, driving there would be ridiculous. LOL.
__________________ 09 Impala SS (sold 3/2012); 2001 Cadillac SLS ; 2010 Lincoln MKS AWD Ecoboost "Trying Times Are Not a Good Time To Quit Trying" |
#12 (permalink) | ||
SadiStic Impala
![]() __________________ Quote:
#14 (permalink) |
Yup!
![]() It is seriously ridiculous. Funny the first 1000 times, irritating after that. I ahve been to FL 2x in the past 4 weeks...... ridiculous. __________________ 09 Impala SS (sold 3/2012); 2001 Cadillac SLS ; 2010 Lincoln MKS AWD Ecoboost "Trying Times Are Not a Good Time To Quit Trying" |
| Sponsored Links | |
Advertisement | |
| No answer on Turn Signal?? Still needs help!!! | kathrynjane1 | Audio, Video, and Electronics | 8 | 10-28-2010 05:26 AM |
| Turn Signal Problem | TGood | Chevy Impala 6th Gen Discussion | 4 | 02-09-2010 09:01 AM |
| Something broke on turn signal lever? Turn light won't turn off | sswodawg81 | Chevy Impala 6th Gen Discussion | 0 | 11-02-2009 01:19 PM |
| Turn Signal/ Flasher Issues. | hyseman | Automotive Discussion | 3 | 10-30-2009 10:55 AM |
| Turn Signal Problems.. =( | dj123456 | Chevy Impala 7th Gen Discussion | 3 | 08-18-2009 08:28 AM |
