8th gen turn signal/dimmer switch replacement - Chevy Impala Forums
post #1 of (permalink) Old 08-08-2013, 04:22 PM Thread Starter
Common issue I have found with our 8th gen vehicles, after awhile the turn signal switch wears, and you find the highbeams coming on randomly when you use the signal. The fix is replacement, AC delco part is fairly cheap through rockauto, unlike it's 7th gen counterpart.
Lets get started. First tools, what I used: 1/4 driver, T25 torx bit, 1/4 end wrench, needlenose pliers (optional), and a small flatblade screwdriver.
First pull the tilt adjuster off, nothing holding it, just pull outward.
Remove the plug piece by the ignition switch
Remove the torx screw in the bottom of the column, front most hole. No idea what the others are for
Pull down the panel under the column, just a little, there are screws holding it at the bottom, but you just need a little room.
Remove the bottom column trim, just pop the clips apart at the front, then push back and wiggle, as shown it is held with hooks in the rear.
Remove the top trim, you have to finagle it around the ignition switch a little.
Remove the top torx screw holding the switch.
Now the lower screw, this is where the wrench comes in. There is no clearance without removing the wheel, I find this may be a serious pain, but easier than removing the wheel. The pliers come in here as well, once the screw is loosened you can turn it easier with them.
Pull the switch off the column.
Remove each of the 3 plugs using the screwdriver on the tabs.
And that's it! Put everything back together in reverse order. The column trim is a serious pain to get back in place, but be patient and look closely, and you'll get it.
The Following 4 Users Say Thank You to kingnutin For This Useful Post:
89Imp03 (01-04-2014), Ray Dockrey (08-15-2013), retiredpauly (08-14-2013), volume (08-09-2013)
post #2 of (permalink) Old 08-09-2013, 10:58 AM
TSS
TSS's Avatar
Quoted: 24 Post(s)
Excellent write up!
2009 Impala SS (sold 3/2012);
2014 Impala Limited LTZ
2010 Buick Enclave CXL;
TSS is offline
The Following User Says Thank You to TSS For This Useful Post:
kingnutin (08-09-2013)
post #3 of (permalink) Old 08-09-2013, 01:26 PM Thread Starter
Thank you.
post #4 of (permalink) Old 08-09-2013, 02:31 PM
Quoted: 240 Post(s)
Just curious - what are all of the switches mounted on your radio bezel?? Just being nosey! :-)
Thanks.
post #5 of (permalink) Old 08-12-2013, 11:40 AM Thread Starter
Security patrol car, they control the lights and whatnot. The red button is the airhorn.
post #6 of (permalink) Old 08-14-2013, 08:12 PM
retiredpauly's Avatar
Quoted: 37 Post(s)
Tanks !
Bookmarked it too.
retiredpauly is offline
post #7 of (permalink) Old 12-06-2014, 12:55 PM
Size_Atx02's Avatar
Would this fix the issue on the blinker/hi beam headlight switch? I have an issue of the high beam coming on by itself so i have to hold the blinker towards the steering wheel to keep the lowbeams on. Thanks for the excellent write up! This looks like what I need to do to fix the problem but wanted to double check with ya. Thx
Size_Atx02 is offline
post #8 of (permalink) Old 04-25-2015, 01:29 PM
Size_Atx02's Avatar
wow
After reading this in full, I feel dumb about asking that question lol. thx for the write up!
post #9 of (permalink) Old 12-17-2015, 05:56 PM
rsheak02's Avatar
Great write up!!
rsheak02 is offline
post #10 of (permalink) Old 10-01-2016, 11:02 AM
Fred2000's Avatar
9th Gen Impala Differences 2006-2013 (2014-2016 Limited)
They made the 9th generation turn signal switch replacement even easier. You need a T25 torx bit and small screw driver. The tilt adjuster does not seem to come off and can stay on for this 9th gen replacement.
1. Remove the plug piece by the ignition
2. Remove the black T25 torx screw in the bottom of the column, front most hole.
3. Pull down the panel under the column, just a little, there are no screws holding it.
4. Here's is where it is different - The column trim top and bottom are snapped together. The bottom trim is not hooked in the rear. So pop the two pieces apart. Takes a little effort.
5. Work the top piece off the ignition switch to get it off.
6. The bottom piece just needs to be pulled down a little to expose the silver bottom T25 torx screw in the front. If you can get the tilt adjuster knob off you can take the bottom piece all the way off.
7. Here is the tip - you will need to turn the steering wheel 90 degrees to open a path to that silver bottom torx screw.
7. Remove the silver top T25 torx screw and then the silver bottom T25 torx screw. Pull the old switch up so you can remove the 3 plugs with the little screw driver
The only part that took some time putting the new unit back was snapping the top and bottom column trim pieces together. You have to get the top piece back over the ignition switch then get both pieces aligned so they will snap together. Takes some back and forth to get the correct alignment.
Fred2000 is offline
Oil filter adaptor gasket replacement 8th gen 3500/3900 kingnutin DIY How To's & Write Up's 27 06-08-2016 06:36 PM
7th gen ignition switch replacement/access kingnutin DIY How To's & Write Up's 13 08-02-2015 10:02 AM
2008 Impala Switch Back LEDs....(Turn Signal) kliang298 Appearance 12 11-21-2014 12:37 PM
replacement turn signal mmd8x28 Chevy Caprice 11 01-20-2011 04:29 AM
Dimmer switch compatibility korbas12 Chevy Impala 7th Gen Discussion 4 07-11-2010 11:41 PM
