Oil filter adaptor gasket replacement 8th gen 3500/3900 - Page 2 - Chevy Impala Forums
post #16 of (permalink) Old 03-14-2015, 07:29 PM
MJCULE's Avatar
thanks for the post and its attention to detail, it is super helpful. Just an alternate method, I found out taking off the splashguard completely gave me enough room with my hands to take all 3 bolts off so I didn't have to touch the compressor. saves you taking the wheel off but you have to mess around with more of those stupid plastic clips
MJCULE is offline
post #17 of (permalink) Old 03-14-2015, 07:59 PM
deepconcentratn's Avatar
Wish I had checked the forum before I paid someone to do it. He only charged 150 but I could have done it myself. Good write up
deepconcentratn is offline
post #18 of (permalink) Old 09-04-2015, 08:29 PM
Cocoabeans's Avatar
I think I have this issue, but I don't know if it's the that gsket or the header gasket. Is there a way to tell? I put oil in the engine and it gets leaks until a certain level sometimes and then it gets stable....
Cocoabeans is offline
post #19 of (permalink) Old 09-11-2015, 10:43 PM
chadt's Avatar
nice wright up
chadt is offline
post #20 of (permalink) Old 09-13-2015, 10:29 AM
retiredpauly's Avatar
Quoted: 107 Post(s)
Header gasket won't leak oil. It will leak exhaust and you will hear it.
And
How much oil are you putting in ?
You say it leaks untill a certain level and then stops. What "level" are you speaking of?
retiredpauly is offline
The Following User Says Thank You to retiredpauly For This Useful Post:
Cocoabeans (09-14-2015)
post #21 of (permalink) Old 09-13-2015, 12:45 PM
Quoted: 60 Post(s)
I think he may have meant head gasket
*2001 Impala Ls - 129k
*2000 Blazer 4x4 - 174k
Winter daily
*1977 C10 - Work in progress
*2014 Impala LT Limited - 35k
RYD SLO is offline
post #22 of (permalink) Old 09-14-2015, 04:31 AM
Quoted: 107 Post(s)
I think you may be right.
post #23 of (permalink) Old 09-14-2015, 10:25 PM
Cocoabeans's Avatar
And
The oil level and I'm glad you told me this. Other than oil my car doesn't leak anything, I think the auto mechanic was trying to exploit the flaw in my engine but I think I'd know if the header gasket was leaking. To be honest I think I may have just put too much oil in the car. I got a low oil warning about a week ago, so I put a quart in there and nothing has leak out since...I may just change the gasket anyway since the car's an 07' just to keep it in tip top shape...
Thank you so much for this post.
And yes I meant the head gasket. But I think this may be the issue as well...
post #24 of (permalink) Old 01-31-2016, 10:07 AM
bigjim1012003@yahoo.com's Avatar
I tried looking at youtube for a video but couldn't find one then I found this. We'll done, not one issue and relatively simple procedure!! Thanks, well done.
bigjim1012003@yahoo.com is offline
post #25 of (permalink) Old 02-16-2016, 11:14 PM
brigoyanks's Avatar
I changed my gasket about 3 months ago and I am still finding oil leaks, does anyone know if there are there any other common possible culprits that it could be?
brigoyanks is offline
post #26 of (permalink) Old 03-05-2016, 05:52 PM
Quoted: 107 Post(s)
Oil pan
post #27 of (permalink) Old 03-09-2016, 10:17 PM
07ImpalaLT01's Avatar
Quoted: 20 Post(s)
I need to check mine. My cars been dripping oil. I took it to get the oil changed instead of doing it myself back around November and they said the oil pan gasket was bad that's why it was dripping. Bought the gasket like two months ago just haven't had time to change it. I'll be sure to check this as well.
07ImpalaLT01 is offline
post #28 of (permalink) Old 06-08-2016, 05:36 PM
1Mech's Avatar
An alternate method
I have done a couple of these, did one this morning, but I found it easier to remove the exhaust manifold. It comes out without too much trouble and then you have a wide open shot to the oil filter base. To remove the manifold, 1st remove both heat shields covering the manifold and the crossover pipe, loosen the heater hose tubes below the throttle body to get room to remove the heat shield. Also remove the torque strut closest to the front of the engine, along with the vertical bracket it attaches to. You can now unbolt and remove the manifold and have easy access to the oil filter base.
If you want even more room, take the radiator fan out also!
1Mech is offline
post #29 of (permalink) Old 04-11-2017, 02:52 PM
moontn's Avatar
Great Job The write up help me fix my 2008 oil leak
moontn is offline
Magnaflow downpipe 3500/3900, anyone tried it? Overkill 8th Gen Engine Performance 10 01-05-2014 09:03 PM
7th Gen. catback fit 8th Gen? beast50 Chevy Impala 8th Gen Discussion 14 05-12-2013 04:57 AM
7th gen tail lights on 8th gen Anonymous Chevy Impala 8th Gen Discussion 12 02-13-2013 10:41 PM
2003 oil pan gasket replacement child_of_fire Chevy Impala 7th Gen Discussion 1 06-14-2011 11:15 AM
7th gen parts on 8th gen impala? einmitsui Private Wanted Classifieds 1 04-08-2008 04:52 AM
