Non OBDII compliant - Chevy Impala Forums
post #1 of (permalink) Old 12-01-2012, 06:23 PM Thread Starter
rlkidd's Avatar
Non OBDII compliant
I have a 2000 Impala, 3.8L, V-6, that is not shifting and it has a service engine light on. The trouble is that I can't retrieve trouble codes from it. The emissions sticker does not list it as OBDII compliant. I believe that the car may have manufactured in Canada. Autozone, Oreillys and Advance have all tried and their scanners will not link. What can I do to retrieve the codes, other than take it to a dealer? I really can't afford that.
rlkidd is offline
post #2 of (permalink) Old 12-01-2012, 06:39 PM
auntjemima's Avatar
Honestly, Canadian built or not, the car is OBD2 compliant. IIRC all vehicles since 1994 are.
Regardless of the top info, I would investigate the integrity of your OBD2 port. Clearly there is a connection issue on its BUS or with the PCM control unit itself.
auntjemima is offline
post #3 of (permalink) Old 12-02-2012, 07:32 AM Thread Starter
rlkidd's Avatar
Non OBDII compliant
Thanks. I'll do a little checking. There are also only 4 wires connected to the port, but I guess that would be all you need... gnd, +12 volts, A and B.
rlkidd is offline
post #4 of (permalink) Old 12-02-2012, 09:19 AM
Gregg-O's Avatar
What are the scanners coming up with ? Might what to check fuse's. On my '96 the cig. lighter & the comm port are the same fuse. scanner couldn't link because the fuse was blown.
Gregg-O is offline
post #5 of (permalink) Old 12-23-2012, 08:58 PM
g25racer's Avatar
Since 1996 not 94. Yes it sounds like a obd port issue or PCM issue.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
Best wireless obdII device? Ejbiers Automotive Discussion 0 05-27-2012 07:40 AM
Actron CP9145 AutoScanner OBDII Vehicles $90 Richard Automotive Discussion 0 11-25-2009 02:02 PM
