2012 Impala low tire pressure - Chevy Impala Forums
post #1 of (permalink) Old 11-24-2012, 09:13 AM Thread Starter
LisaRich's Avatar
Hello, after getting air in my rear tire the low tire pressure on my dashboard will not go off. Can someone please tell me how to reset it??? Thanks you!
LisaRich is offline
post #2 of (permalink) Old 11-24-2012, 09:55 AM
Bart77's Avatar
Quoted: 7 Post(s)
Did you check all your tires? The tire pressure sensor location may not have been relearned at your last tire rotation and the display is showing the wrong tire being low.
Bart77 is online now
post #3 of (permalink) Old 11-24-2012, 01:58 PM Thread Starter
LisaRich's Avatar
It showed the right rear tire low, then I got air put in it. I just bought the car so I haven't had the tires rotated yet. I was told to put on the emergency break, turn the ignition on ( but don't start it) on down the door lock/unlock on my key holder. The horn honked twice, then it displayed "Tire Relearning". I didn't know what to do after that.
LisaRich is offline
post #4 of (permalink) Old 11-24-2012, 04:17 PM
Bart77's Avatar
Quoted: 7 Post(s)
Ah. Well to do a tire relearn after getting the "Tire Relearning" message you need to go to the LF wheel and push in the LF tires valve to release tire pressure until the horn chirps once, then do it to the RF, then RR, then the LR, the horn should now honk twice indicating the sensors had been learned, then refill all your tires to the proper tire pressure. That is if this method still works, I believe GM has deleted this method from the 2012 models. If it doesn't work then you'll need a Tire Pressure Monitor Sensor Activation Tool to reset the tire monitor.
post #5 of (permalink) Old 11-25-2012, 01:01 PM
Hi LisaRich,
I borrowed this from page 10-45 of the 2012 Impala Owner's Manual. I hope it's helpful for you!
"The TPMS sensor matching process is:
1. Set the parking brake.
2. Turn the ignition to ON/RUN with the engine off.
3. Press the Remote Keyless Entry (RKE) transmitter's Q and "buttons at the same time for approximately five seconds. The horn sounds twice to signal the
receiver is in relearn mode and the TIRE LEARNING ACTIVE message displays on the DIC screen.
4. Start with the driver side front tire.
5. Place the relearn tool against the tire sidewall, near the valve stem. Then press the button to activate the TPMS sensor. A horn chirp confirms that the sensor identification code has been matched to this tire and wheel position.
6. Proceed to the passenger side front tire, and repeat the procedure in Step 5.
7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5.
8. Proceed to the driver side rear tire, and repeat the procedure in Step 5. The horn sounds two times to indicate the sensor identification code has been matched to the driver side rear tire, and the TPMS sensor matching process is no longer active. The TIRE LEARNING ACTIVE message on the DIC display screen goes off.
9. Turn the ignition to LOCK/OFF.
10. Set all four tires to the recommended air pressure level as indicated on the Tire
and Loading Information label."
Sarah (Assisting Katie), Chevrolet Customer Service
For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html
The Following User Says Thank You to ChevroletCustomerService For This Useful Post:
truckrglenn (09-27-2014)
post #6 of (permalink) Old 11-25-2012, 02:15 PM
volume's Avatar
volume is offline
post #7 of (permalink) Old 05-21-2014, 01:49 PM
JerryPH's Avatar
Originally Posted by ChevroletCustomerService View Post
Hi LisaRich,
"The TPMS sensor matching process is...
8. Proceed to..."
Hey Sarah, this all assumes that the user has a TPMS reprogramming tool (something like the ATEQ VT15 for example). For 2012 and on, unless you have the tool, you will need to make a stop at a dealership or a garage to address the issue.
For the OP... I purchased the mentioned VT15, it works great, and is easy to use. After the 2nd time using it, it has already paid for itself in terms of savings over what I would have had to pay at the local GM dealership.
http://syner-g.no-ip.biz/Impala/tpms.htm
Pics and procedure listed in the link above.
Edit: Just did a fast look on Amazon. Seems the one that I bought has gone up from $75 to $121... still not terrible. This one is tested to work with the Impala (well it works on MY 2013 Impala). They also have a cheaper unit, a VT5 for $75 that looks to do the similar. I cannot find this unit on the ATEQ site, so it may be a discontinued model. Buyer beware.
I just also visited the ATEQ website (http://tpmstools.ca/products/tpms-pe...-use/ateq-vt15), the VT15 does a crapload more than just GM. It does a lot of Ford and Chrysler too.
Starting to look better now! Just sayin'.
Just your average Impala
My Impala Website:
JerryPH is offline
post #8 of (permalink) Old 05-21-2014, 02:03 PM
No TreadSS Left
KCJC2011's Avatar
I just stop at Discount Tire or Belle and they do it for free.
KCJC2011 is offline
The Following User Says Thank You to KCJC2011 For This Useful Post:
post #9 of (permalink) Old 05-30-2014, 02:53 PM
JerryPH's Avatar
I'm one of those people that would prefer to do it myself. In life, one usually gets what they pay for... lol
My Impala Website:
JerryPH is offline
post #10 of (permalink) Old 01-27-2015, 09:57 AM
68ImpalaCustom396's Avatar
what does this relearn tool look like? i asking about the tool that you put against the tire.
68ImpalaCustom396 is offline
Low Tire Pressure darkbandit88 Autocare and Maintenance 5 03-20-2015 10:58 AM
Tire Pressure Issue pjenkins Chevy Impala 8th Gen Discussion 9 07-21-2014 03:02 PM
tire air pressure steve620 Chevy Impala 8th Gen Discussion 5 09-28-2012 03:54 PM
tire pressure rod1416 Wheels and Tires 7 02-08-2011 02:04 PM
Low Tire Pressure Monitor pennyb789 Chevy Impala 7th Gen Discussion 1 10-24-2008 06:18 AM
