Rear Defroster Burnt Wire Fix Write Up - Page 3 - Chevy Impala Forums
post #31 of (permalink) Old 11-06-2011, 09:24 AM
Shadex's Avatar
Thank you
I just wanted to come on here to thank the OP for taking the time to post the pictures and instructions, this was spot on to fix my car
Shadex is offline
post #32 of (permalink) Old 11-23-2011, 06:55 PM
XTRME 94's Avatar
I'm wondering if this is the same issue I'm having with our '05. While under warranty, it went out and they "fixed the wiring", replaced the relay, replaced the circuit breaker. Well it's out of warranty and it's out again. I've already replaced the relay and it still doesn't work. Haven't had the time to get into it any further, so now I'm trying to "research" the problem.
XTRME 94 is offline
post #33 of (permalink) Old 11-23-2011, 07:46 PM
systemcheck2006's Avatar
if its not a fuse, burnt relay in our location (fix with a fused bypass), then it may be in another harness location, not sure but this will help bump. I was told by a dealer who also told me about this fix, that this could potentially set car on fire but cant vouch for that.
then you'd be normal."
systemcheck2006 is offline
post #34 of (permalink) Old 11-28-2011, 10:33 PM
h1000's Avatar
I have an 08 Impala which has this same issue and fixed it in nearly the same way. I am not sure why a fuse is needed here. Fuses are not best at thermally protecting a circuit against heat. Plus the circuit is already protected against drawing to many amps in the fuse panel.
Keep in mind that during this process I never used crimps, always solder and heat shrink to connect the wires.
First time I fixed this I used an inline fuse holder with a 30 Amp fuse and 12 gauge wire. The contacts on the wire going to the fuse were the culprit and were getting hot. The fuse holder reached melting point and fuse still had not blown.
Next I switched to a blade type fuse, this was much better. The blades of the fuse were slightly warm but not hot to the touch.
Finally I switch to connecting the wire without a fuse all together. This resulted in zero heat in any of the wiring. To me this makes sense too. The factory wiring harness failed right at the at the point of the spade connector. This connector was unable to transfer the amount of amps needed to run the defrost. The spade contacts heat up and causes the plastic housing around the spade connector to melt and burn. Eventually the heat corrodes the metal contacts on the spade connector and current no longer passes to the rear defroster.
The wiring on both sides of the connector is heavy enough, the fuse in the fuse panel is big enough, the spades connectors failed. The proof is in the lack of hot wiring at the point where I soldered the wires together to bypass the factory connector.
h1000 is offline
post #35 of (permalink) Old 12-08-2011, 05:28 AM
Apex Everything
Burt's Avatar
My parents just had this problem with their '08, it's a shame I didn't read this earlier. I guess I'll be doing this to my car at some point
'09 Impala LS - Sold
'12 Camaro SS
Burt is offline
post #36 of (permalink) Old 12-09-2011, 04:01 PM
radiodave1's Avatar
I had the EXACT same problem with mine. Of course it had to happen just as the temperature dropped to frost the windows overnight. I sent this page to my service guy at my dealership and although my '08 was already at almost 62,000 miles, they repaired it for free.
radiodave1 is offline
post #37 of (permalink) Old 12-13-2011, 05:30 AM
boostme97's Avatar
Just wanted to say the same. Mine went out last winter, but managed without over the warmer months. Now that it's cold again, this became annoying and took a few minutes to give this a look. Sure enough, the connector looks identical to the one in the original post. Heading out to pick up the fuse holder... THANKS!
boostme97 is offline
post #38 of (permalink) Old 12-27-2011, 09:43 AM
Chipfan's Avatar
I concur with Shadex in thanking the OP for the excellent writeup and pics. My rear defroster stopped working last week on my 2007 and thanks to the posting, I had it fixed in 15 minutes.
Chipfan is offline
post #39 of (permalink) Old 12-28-2011, 08:37 AM
paul1732's Avatar
Question
Does anybody know what other connections are being made through this wiring harness? About 9 months ago, I was driving when I heard a pop sound from this area, and smelled the burning wire. Since then, I have had the following problems with my car:
Constant
1. Stereo Aux connector does not work unless my device (ie cellphone) is also plugged into a cigarette lighter adapter. I assume that this is due to a bad ground.
2. A/C actuators will make a knocking sound for about 2 minutes when changing air ciculation.
Sporadic
1. Stereo will sometimes not shut off when opening the door after shutting off the engine.
2. Sporadic "Tighten Gas Cap" error.
3. Temp guage will drop to 0 and "Enginge Hot Turn A/C Off" error will display. This will clear out when I turn the engine off then back on again, and has only happened 4 or 5 times in the last year.
4. Tail light fuse will blow occasionally.
About two months ago, I was messing around with the wires around the wiring harness, and all of the problems that I listed above went away for about an hour. I assumed that I had an electrical short, which led me to look in the kick panel where I found the burnt wiring harness. Mine looks similar to the one shown above, but a little worse.
paul1732 is offline
post #40 of (permalink) Old 01-06-2012, 03:45 PM
hatzie's Avatar
Quoted: 11 Post(s)
As crispy as some of those connectors look I'd be sorely tempted to buy a new pair and move the wires except the defroster to the new ones.
hatzie is offline
post #41 of (permalink) Old 01-09-2012, 03:33 PM
johnkah16's Avatar
had the same problem, they repaired it at the dealer today, but they just fixed it the way it was so its setup for failure again,of course i found this when i got home and wanted to see how common a problem it is. also had to have the ac delco battery replaced for the 3rd time since i bought the car(08 LTZ) anyone else have a problem with the battery. they just keep changing them out with no question or charge which says they know they're crap
johnkah16 is offline
post #42 of (permalink) Old 01-09-2012, 03:38 PM
johnkah16's Avatar
mines out of warranty too, but they fixed it for no charge, so i would go and ask them to do it
post #43 of (permalink) Old 01-15-2012, 03:57 AM
fastkatt's Avatar
thanx for the pics,,,,great job,,,,diddo for my 07,,,,,but,,,,,i did not use the inline fuse,just 12 guage wire,,there is a 40a fuse(batt3)under the hood beside the relay for rear defroster, after consulting other gm people, they all said it was good,,,, the inline is fine as well,,,,it's all GOOD,,except the wiring from GM.
fastkatt is offline
post #44 of (permalink) Old 01-15-2012, 03:59 AM
fastkatt's Avatar
no problem with my battery,,,6 years old and counting,,,sorry man
fastkatt is offline
post #45 of (permalink) Old 01-15-2012, 08:52 AM
SStuntin on em
WallyLO's Avatar
I am shocked I don't have this (yet) so far my Imp has every common problem ( tranny, spindle rods, rear door not opening)
WallyLO is offline
LinkBack to this Thread: http://www.impalaforums.com/diy-how-to-s-and-write-up-s/251292-rear-defroster-burnt-wire-fix-write-up.html
2009 Impala Onstar quit working. - FixYa This thread Refback 01-13-2012 03:32 PM
'06- All to common Degogger Problem - Forums - NAIOA This thread Refback 10-29-2011 04:39 PM
Rear defrost dont work on - FixYa This thread Refback 10-01-2011 08:30 PM
NAIOA Impala Forums :: Topic review - '06- All to common Degogger Problem This thread Refback 11-27-2010 07:18 PM
North American Impala Owners Association - 2006+ General Discussion - '06- All to common Degogger Problem This thread Refback 11-21-2010 04:57 PM
North American Impala Owners Association - Forums - This thread Refback 11-21-2010 01:17 PM
2009 Chevrolet Impala SS [Discontinued] Overview This thread Refback 07-04-2010 07:44 PM
rear fog defroster wont work rajeshshivam Mechanical and Electrical Problems 0 01-29-2010 02:33 PM
Rear window defroster issue Ldysportsbuff Chevy Impala Discussion 6 01-18-2010 02:06 PM
rear defroster Carnegie Chevy Impala 7th Gen Discussion 4 01-12-2010 08:51 AM
Non-working Rear Defroster monzaspyder Chevy Impala 8th Gen Discussion 1 11-22-2009 02:04 PM
04 rear defroster breaker SPECTRE184 Chevy Impala 7th Gen Discussion 3 03-25-2008 12:19 PM
