Rear Defroster Burnt Wire Fix Write Up - Page 2 - Chevy Impala Forums
post #16 of (permalink) Old 03-07-2011, 08:17 PM
Jerrybo's Avatar
Thanks for this great write up with pictures. I will bet this is what is wrong with my rear defroster and if it is will be the second time this forum has helped me figure what was wrong and fix my 2006 impala. This has turned out to be a great forum. Thanks to all who have imput. Jerry
Jerrybo is offline
post #17 of (permalink) Old 03-08-2011, 08:18 AM
200-A's Avatar
As for the fuseholder catching on fire, I can think of two things. It is possible that the tabs that attach the defroster wire to the window have deteriorated, this can cause additional resistance in the circuit as can a ground that has become corroded, or any additional connectors which might be in the circuit (not sure if there are any additional ones) Any additional resistance will increase the amp draw. While I can't say the Impala has the problem with the tabs, I have encountered a few GM vehicles from the late 90s-early 2000's with that problem.
Also, make sure you are using fuses that are manufactured by a reputable company such as Buss. Avoid the "bargain packs" of off-brand fuses you sometimes see at the parts store real cheap, some of them are not made to the same standards and I have heard stories of burnt wiring after using those kinds of fuses.
In any case if the new fuseholder catches on fire there is obviously a bigger problem, and the fact that this generation Impala bypasses the defrost timer once you reach about 42 MPH and leaves it on continuously does not help this problem.
200-A is offline
post #18 of (permalink) Old 03-08-2011, 11:27 AM
Well, thanks for acknowledging my concern. I will have to just keep tracing wiring till I find the problem...
post #19 of (permalink) Old 03-09-2011, 02:33 PM
Jerrybo's Avatar
I finally got time to look at my plug today and found the same thing that 84 convertablegt posted. If I took pictures it you would thing they were the same pics he posted. Will wait and see if my fix works as well as his. Thanks again Jerry
Jerrybo is offline
post #20 of (permalink) Old 04-03-2011, 11:01 AM
slundon's Avatar
Many Thanks
Wonderful Write-up! I was able to do the fix in under 10 minutes at a cost of $3.50.
Thank you!!!
slundon is offline
post #21 of (permalink) Old 09-15-2011, 05:59 PM Thread Starter
84convertablegt's Avatar
glad to see this fix has worked for other people. to the poster who had the new fuse melt: sounds like something else is wrong with the element in the back. almost seems like a short, but it should definitely pop the fuse first! that's crazy. I had the car for about six months after the fix and it worked great the whole time, and it was heavily used during the winter. my brother in law has had 2 other impaled with the exact same problem. it's crazy that chevy hasn't actually addresses the issue.
84convertablegt is offline
post #22 of (permalink) Old 10-02-2011, 07:53 AM
tomac28ems's Avatar
I checked the plug on my 06 impal and the same thing is wrong going to fix this today.Has anyone contact gm about this problem? Thanks for the posting and pic i been tring to find the problem for a year now
tomac28ems is offline
post #23 of (permalink) Old 10-02-2011, 09:50 AM
tomac28ems's Avatar
follow up on fixing my rear defroster it is all fixed and the fuse got warm but did not get hot so the person who had a problem of get hot and catching on fire check your rear window connecters
thank you again on the pic and info
p.s. the wire colors on my 06 impala was purple on the front side and black on the back side
post #24 of (permalink) Old 10-03-2011, 09:12 AM
ebby69k's Avatar
Rear Defrost
Another one fixed. Thanks for the great write up.
ebby69k is offline
post #25 of (permalink) Old 10-04-2011, 10:05 AM
tomac28ems's Avatar
follow up on the rear derfroster everyone needs to call gm to put in a claim so this will be a recall i called gm to today and spoke to a lady she said to have everyone call in to put in a claim so they get enough people to make it a recall... here is the number 1-866-790-5700 ex.41141 ask for Lekeia
please call... this is a fire hazard just think if your kids are in the car and it cought fire... if you fixed it your self please still call you could save a life
thank you
impala owner and a firefighter
post #26 of (permalink) Old 10-08-2011, 04:28 PM
Mike G's Avatar
Hi,
I have a 2007 impala with the exact same issue. I just called and talked to Lekeia. Great lady and more than willing to help. Still not enough complaints to make a recall. Hopefully more people will actually call.
Thanks,
Mike
Mike G is offline
post #27 of (permalink) Old 10-10-2011, 07:23 AM
Quoted: 7 Post(s)
Hello all,
Thank you for being proactive and bringing this concern to our attention! Iím making a note of it on my end as well.
Sarah
GM Customer Assistance
post #28 of (permalink) Old 10-19-2011, 06:33 AM
systemcheck2006's Avatar
Smile rear defrost
tried this last night and it worked, thanks man finally i have a rear defroster again.http://www.impalaforums.com/images/smilies/clap.gif
systemcheck2006 is offline
post #29 of (permalink) Old 10-30-2011, 11:02 AM
sbcaprice305's Avatar
Just wanted to thank the op for making this. Saved my parent's a little dough.
Very easy job, though I ran into a problem. I ended up going with a inline fuse holder I had laying in the garage simaliar to this but with a clear plastic housing. It was #12 wire with a 30a 32v agc style fuse
It ended up getting really hot and started to effect the housing in minutes. All connections were soldered. I checked the tabs on the rear window and they were intact. So I was a little pissed and decided to get a different type of fuse holder.
Simaliar to this. It was a 30a 32v buss inline holder.
So far so good. Ran it for the 10minutes till it automaticly turns off and all seems well. It gets a little warm but I can touch the fuse with my fingers w/o feeling any sensation of pain.
Thanks again guys.
sbcaprice305 is offline
post #30 of (permalink) Old 10-30-2011, 07:44 PM
speaking of saving money, when I originally went to the dealer to see the cost of new wire harness plus installation dude told be it be around $300, I'd say we saved some dough.
then you'd be normal."
LinkBack to this Thread: http://www.impalaforums.com/diy-how-to-s-and-write-up-s/251292-rear-defroster-burnt-wire-fix-write-up.html
2009 Impala Onstar quit working. - FixYa This thread Refback 01-13-2012 03:32 PM
'06- All to common Degogger Problem - Forums - NAIOA This thread Refback 10-29-2011 04:39 PM
Rear defrost dont work on - FixYa This thread Refback 10-01-2011 08:30 PM
NAIOA Impala Forums :: Topic review - '06- All to common Degogger Problem This thread Refback 11-27-2010 07:18 PM
North American Impala Owners Association - 2006+ General Discussion - '06- All to common Degogger Problem This thread Refback 11-21-2010 04:57 PM
North American Impala Owners Association - Forums - This thread Refback 11-21-2010 01:17 PM
2009 Chevrolet Impala SS [Discontinued] Overview This thread Refback 07-04-2010 07:44 PM
rear fog defroster wont work rajeshshivam Mechanical and Electrical Problems 0 01-29-2010 02:33 PM
Rear window defroster issue Ldysportsbuff Chevy Impala Discussion 6 01-18-2010 02:06 PM
rear defroster Carnegie Chevy Impala 7th Gen Discussion 4 01-12-2010 08:51 AM
Non-working Rear Defroster monzaspyder Chevy Impala 8th Gen Discussion 1 11-22-2009 02:04 PM
04 rear defroster breaker SPECTRE184 Chevy Impala 7th Gen Discussion 3 03-25-2008 12:19 PM
