Rear Defroster Burnt Wire Fix Write Up - Page 19 - Chevy Impala Forums
post #271 of (permalink) Old 02-10-2016, 05:27 PM
Mwcotthoff's Avatar
& here is the picture. Thanks again
https://app.box.com/s/pmlc7e9j1s5aldlm437mjlqugozctjgw
Mwcotthoff is offline
post #272 of (permalink) Old 02-12-2016, 06:23 AM
KG2014's Avatar
Quoted: 56 Post(s)
What gauge wire you using? I had an issue with mine originally. Make sure you using thick enough wiring.
Yeah I got a few mods.......
Check out my mod thread here
Check out my garage here
KG2014 is offline
post #273 of (permalink) Old 02-12-2016, 08:55 AM
Mwcotthoff's Avatar
16 originally. I re wired with 12 and still not working. Fuse is fine. Have order d a new relay. Going to 2x check the wiring later.
post #274 of (permalink) Old 02-12-2016, 11:42 AM
KG2014's Avatar
Quoted: 56 Post(s)
Use a volt meter to check for power to the broken wire.
KG2014 is offline
post #275 of (permalink) Old 02-13-2016, 05:20 AM
retiredpauly's Avatar
Quoted: 120 Post(s)
Did you solder the wires together or just twist them and wrap in electrical tape ?
retiredpauly is offline
post #276 of (permalink) Old 02-13-2016, 09:34 AM
Mwcotthoff's Avatar
Think I have solved problem. I used butt connectors and 12g wire. Power is running to back. The old connectors I used were causing resistance. When I used the 16g the wires were warm to touch. I'm not feeling that here.
post #277 of (permalink) Old 03-13-2016, 05:35 AM
KellySue65's Avatar
Did this fix and for some reason my check engine light is staying on now. Car is running fine, never had this light on before...because it's on my remote start won't work. 2013 Impala
KellySue65 is offline
post #278 of (permalink) Old 03-13-2016, 05:37 AM
Quoted: 353 Post(s)
Was your defroster not working before and is working now after the fix?
Will need to get the code read to see what code you have... That will help a lot.
jtrosky is online now
post #279 of (permalink) Old 03-15-2016, 07:15 PM
KG2014's Avatar
Quoted: 56 Post(s)
I'm guessing maybe you cut the wrong wire or maybe didn't plug the harness in all the way. Did you turn the car on with the harness unplugged? That will throw a code until it is cleared, ask me how I know because I did it haha.
KG2014 is offline
post #280 of (permalink) Old 08-28-2016, 04:35 PM
Snoopy's Avatar
Thumbs up Another happy reader.
Thanks for your post. I just did the repair on my 2011 Impala.
Snoopy is offline
post #281 of (permalink) Old 12-10-2016, 06:21 PM
dtnel's Avatar
Anyone know if the left front impact sensor wiring for the the airbags runs thru this connector? B0085 - 5 Short to Voltage code and wondering where to start. Already replaced the left front impact sensor, swapped the left with right after the replacement didn't solve the issue after I'd had the dealer diaghnose the code originally. Went back and told them apparently they don't know how to diagnose and was glad I didn't have them fix it otherwise I probably would've got hosed over.
dtnel is offline
post #282 of (permalink) Old 12-26-2016, 10:19 AM
donzi's Avatar
Me too. Listened to the radio when I had the 2 harnesses unplugged. Threw 3 codes afterwards. P0449, P0452, & P0463. I also tried to turn the ignition off when the harnesses were off. It wouldn't turn back to the off position so I couldn't remove the key. Scared the heck out of me. Ignition worked fine after I plugged the harnesses back in. I then reset the codes. Fingers crossed.
I do have a question though. Before doing the fix, I had no power the the rear windshield defroster contacts. After the fix, I get power to the passenger side contact but not the drivers side contact. Is that normal? It is too warm today to check the defroster properly. Its the main reason it got fixed today!
Thanks. Props to the OP for the great write up and others for their helpful contributions.
BTW - Burned up connector like everyone else. 2013 Impala LT. I just butt spliced the purple and black wire using some extra 14 gauge wire I had laying around. I did not use a fuse. (Yes, I read all 19 pages of this thread)
donzi is offline
post #283 of (permalink) Old 12-26-2016, 10:28 AM
Carbide's Avatar
Quoted: 87 Post(s)
Power at only one side of the grid means the grid has a break.
I know you can buy a paint made for reconnecting the grid, although I have not done this.
I believe it works like a bottle of fingernail polish, and you clean the area and paint line between areas around the break, the paint being electrically conductive.
Having a multimeter tester for checking for resistance/continuity is a big help in finding the problem(s) and then verifying your fix(s).
There are several vids on YouTube.
https://youtu.be/u_v942ySQHA
Carbide is offline
The Following 2 Users Say Thank You to Carbide For This Useful Post:
donzi (12-26-2016)
post #284 of (permalink) Old 12-26-2016, 11:46 AM
donzi's Avatar
Thanks Carbide. I checked the continuity from the rear passenger side grid connector to the rear driver side grid connector and also several spots throughout the grid. Everything checked out good. I think I wasn't testing the power output correctly. Before, I connected the black ground wire of my multitester to a vehicle ground near the inside of the door then touched the red wire of the tester to each of the grid connectors, one at a time. This was with the rear defroster turned on. When I touched the passenger side connector, I got a little over 10 volts. When I touched the driver side connector, I got nothing.
Your post made me go out to the car and try the continuity test. Once I determined that the grid was good, I used the multimeter again. This time I touched the red wire to the passenger side connector and the black wire to the driver side connector and got over 13 volts. I think everything is working as it should. I'll know for sure when it gets colder. Thanks again for your help.
donzi is offline
post #285 of (permalink) Old 02-22-2017, 03:14 AM
deputydwag's Avatar
Smile Accurate Information
followed the step by step and found the problem- pictures and description very accurate. Job took 15 minutes and now working.
deputydwag is offline
The Following User Says Thank You to deputydwag For This Useful Post:
retiredpauly (02-22-2017)
LinkBack to this Thread: http://www.impalaforums.com/diy-how-to-s-and-write-up-s/251292-rear-defroster-burnt-wire-fix-write-up.html
2009 Impala Onstar quit working. - FixYa This thread Refback 01-13-2012 03:32 PM
'06- All to common Degogger Problem - Forums - NAIOA This thread Refback 10-29-2011 04:39 PM
Rear defrost dont work on - FixYa This thread Refback 10-01-2011 08:30 PM
NAIOA Impala Forums :: Topic review - '06- All to common Degogger Problem This thread Refback 11-27-2010 07:18 PM
North American Impala Owners Association - 2006+ General Discussion - '06- All to common Degogger Problem This thread Refback 11-21-2010 04:57 PM
North American Impala Owners Association - Forums - This thread Refback 11-21-2010 01:17 PM
2009 Chevrolet Impala SS [Discontinued] Overview This thread Refback 07-04-2010 07:44 PM
rear fog defroster wont work rajeshshivam Mechanical and Electrical Problems 0 01-29-2010 02:33 PM
Rear window defroster issue Ldysportsbuff Chevy Impala Discussion 6 01-18-2010 02:06 PM
rear defroster Carnegie Chevy Impala 7th Gen Discussion 4 01-12-2010 08:51 AM
Non-working Rear Defroster monzaspyder Chevy Impala 8th Gen Discussion 1 11-22-2009 02:04 PM
04 rear defroster breaker SPECTRE184 Chevy Impala 7th Gen Discussion 3 03-25-2008 12:19 PM
