Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical > Chevy Impala 7th Gen Discussion > "DIY" Do it yourself/how to
Old 10-27-2009, 06:11 AM   #1 (permalink)
04DetroitLS's Avatar
ISS Lube (link)
Remove this ad!
to fix the clunk, click, thud in your steering you should keep the Intermediate steering shaft lubed.
http://colinkraft.com/shaft.php
some may need to be replaced, but try this first.
04DetroitLS is offline
Old 12-27-2009, 03:44 PM   #2 (permalink)
05ss45's Avatar
great link!! i just started to get the clicking poping sound. any idea what the part # for the shaft just in case.
SLP headers, 3.8/3.5 MPS,v1.0 DHP PCM, Grant built trans, intense I/S, Trans-Go shift kit, 2800 stall(Comp Cams custom grind 2 be installed)
05ss45 is offline
Old 12-29-2009, 08:02 AM   #3 (permalink)
05ss45's Avatar
i got it on alldata it is p/n 19179923.
i also found a TSB for a clucking/creaking noise from subframe. a result of small relative movement between the contacting surfaces of various brackets, crossmembers and side rails that are welded together to form the frame/cradle assembly. the specific areas/contact points on the frame assembly that may cause this is the steering gear brackets (steering rack) to rear crossmember as well as right/left body mount bracket to rear crossmember and right/left side rails. correction is apply penetrating grade threadlocker to the cleaned (do not use brake cleaner between the steering gear mounting brackets, it may dilute the threadlocker) locations stated above. as well as horizontal and vertical welds. ensure adequate and complete coverage of designated areas. start vehicle and turn steering wheel lock to lock 25 times (performing this on abrasive/aggresive type surfaces such as rough concrete can cause tire flat spotting) it then states to let vehicle remain stationary in a warm/dry environment for 24 hours.
i hope this helps those that still have creaking noise after lubing the ISS!
05ss45 is offline
Steering Column Thump/Lube? Wolffy 7th Gen Suspension 11 03-13-2010 04:35 PM
what gear lube should i use Bizkitss81 Chevy Caprice 1 09-24-2009 01:50 PM
Sway Bars/Center Link - Advice? texastillie Autocare and Maintenance 4 05-31-2009 07:52 AM
Lube and oil specials to avoid George Bates Automotive Automotive Discussion 13 03-03-2009 08:19 AM
can anyone show me a link to a oldsmobile? cookiesmom Automotive Discussion 0 09-07-2007 03:12 AM
