How much engine oil should i have put in my 1996 impala ss. its a 5.7L V8. I also - Chevy Impala Forums
post #1 of (permalink) Old 06-24-2008, 06:43 PM
Nick H
Nick H's Avatar
Quoted: Post(s)
replaced the oil filter.?
i put 5 and a half quarts in just trying to make sure. the problem is i didnt use a funnel so i spilt just a tad bit. after driving it around the block a couple times at high rpm's and than opening the hood there was a little smoke coming off the header that i spilt the oil on.
post #2 of (permalink) Old 06-24-2008, 06:44 PM
evincent18
evincent18's Avatar
Quoted: Post(s)
pretty sure it is five quarts. put five and check the stick to see if you need more.
post #3 of (permalink) Old 06-25-2008, 05:33 AM
Heavy_SS's Avatar
The problem with that is if you change the oil filter then without starting the engine, you are taking an inaccurate reading.
I would fill it up with the five quarts. Knowing that the filter is empty, if the dip stick is a little beyond the full hashmarks, you should be OK.
I would start the engine to fill the new oil filter and check it again in a few hours. If its in the normal operating range on the dipstick your fine.
Eric Iverson
96 BBB SS
51 k and counting.
Typical newbie mods, with no gas in the tank.
www.minnessota.com
Heavy_SS is offline
post #4 of (permalink) Old 06-25-2008, 08:31 AM
COLD STEEL's Avatar
lol.... Well I suppose you cant do worse than jiffy lube.... The LT-1 B-body takes 5 whole quarts without priming the oil filter. If you prime the filter, just use the remaining oil in that quart bottle and the other four to fill and your done. No big deal here.
COLD STEEL is offline
whats the difference between a 1996 9C1 Caprice LT1 motor and a 1996 Impala cmanner323 Chevy Caprice 8 07-27-2009 03:34 PM
I have a 1996 impala ss the engine will rotate but wont run .? A J Chevy Impala Discussion 2 07-28-2008 08:57 AM
I have a 1996 Chevy Caprice Classic and my engine is turning over but won't start.? michaiaella b Chevy Caprice 2 07-21-2008 01:09 PM
1996 impala runs rough, engine light on, and transmission not shifting... Jeremy K Chevy Impala Discussion 1 05-28-2008 04:20 AM
1996 S-10 Pickup 2.2 CID 134 l4 engine? bvbbaluv Automotive Discussion 0 09-12-2007 12:58 AM
