Check engine light on a 2002 Chevy Impala? - Chevy Impala Forums
Old 06-18-2008, 01:23 PM   #1 (permalink)
Mom_to_2!
Mom_to_2!'s Avatar
Does anyone know how many key cycles it takes before the check engine light goes off? My light came on Monday morning and has not gone out yet. I got gas Monday afternoon, thinking it could have been my gas cap, but it is still on. I called the dealership and they told me to give it a few more days. Is there anything else that I can try that may turn off the light?
Thanks!
  Reply With Quote Quick reply to this message
Old 06-18-2008, 01:23 PM   #2 (permalink)
areyouatoj
areyouatoj's Avatar
try unhooking the battery for a little bit that should reset the computer,just unhook the red positive
Old 06-18-2008, 01:23 PM   #3 (permalink)
doc
doc's Avatar
Unhooking the battery is a waste of effort and doesn't work, sometime after 1995 - 96, when OBD II scanners became the diagnostic tool, following OBD I. Only the scanner turns off the light, for significant or specific problems and trouble codes, other than gas cap. A new cap with proper seal will solve the problem, after which the light (computer) is programmed to go off in use - right, after so many key cycles, but in about 3 days of driving. You have to fix the problem first.
I need to reset the check engine light on my 2003 chevy impala..? Ace Chevy Impala Discussion 4 08-27-2008 05:38 AM
check engine light for chevy impala 2002? Sam S Chevy Impala Discussion 1 07-08-2008 02:51 AM
I have a 2004 Chevy Impala and the check engine light just came on. The car is... Dave W Chevy Impala Discussion 6 05-11-2008 10:52 AM
Check Engine Light/Leaking Antifreeze 2004 Chevy Impala? Jeanne C Chevy Impala Discussion 1 02-20-2008 10:46 AM
1992 Chevy 4.3 LT Astro Van Check Engine light? One Computer Guy Automotive Discussion 0 09-13-2007 09:04 AM
