Impala SS Supercharger Maintenance? - Chevy Impala Forums
Old 09-08-2007, 05:18 PM   #1 (permalink)
mrs.crs
mrs.crs's Avatar
Does my supercharger need to be maintenanced? If so, how and how often? Have read about checking the oil, but how is that done?
Old 12-28-2008, 05:49 AM   #2 (permalink)
indyimpalass's Avatar
Supercharger oil change
I've heard 50K miles, but just changed mine at 28K...it was certainly needed, as the oil was dis-colored and stunk pretty bad! I've been getting 30K as a response from a few other maintenance guru's...I say better to do it sooner than later (especially if you like to use the supercharger as much as I do).
IndyImpalaSS
indyimpalass is offline   Reply With Quote
Old 12-28-2008, 11:05 AM   #3 (permalink)
Moderator
04DetroitLS's Avatar
according to gm, the S/C doesnt need to be serviced at all, and the life expectency is ~100k, that being said, it ALWAYS stinks badly, easiest way to change is w/ a syringe and airline hose and suck out as much as you can. It takes 1 1/2 bottles IRRC
04DetroitLS is offline   Reply With Quote
Old 01-19-2009, 06:59 PM   #4 (permalink)
dwilson's Avatar
ss maintainence
I do not have any idea about ss maintenance, I know some places where they sell cheap automotive parts including impala brake parts
dwilson is offline   Reply With Quote
Old 01-28-2009, 07:34 AM   #5 (permalink)
impala04ss's Avatar
Send a message via AIM to impala04ss
I just changed mine, on a 04 ss if you look at the snout of the supercharger
You can go to your dealership or browse online for the supercharger oil which looks like this...
Carefully unscrew that, I would do this when your engine is cold. I found it easier if you have a spray nozzle and just spray it in a water botttle like this image
Get as much as you can out and just refill it with the bottle, I would purchase two bottles and once you do that your all set!
*2004 Impala SS*
-K&N Cold Air Intake-
-Airaid Throttle Body Spacer-
-3.4 Supercharger Pulley-
-6000K HID Low Beam-
-Magnapack cat back -
-180 T*Stat-
-AutoLite's 104's Plugs-
impala04ss is offline   Reply With Quote
Old 06-28-2009, 03:24 PM   #6 (permalink)
parrip's Avatar
Question Does anyone know or have pics of the filters?
I have filters for the supercharger. It's a square filter that looks like it goes inline somewhere. GM Part # is 801528 - foam filter it's small too. Does anyone know where they go?
parrip is offline   Reply With Quote
Old 06-28-2009, 04:18 PM   #7 (permalink)
Moderator
ummm nowhere on the car that i know of
Ive had the SC apart and saw no such part...
EDIT: that part number is a wastegate solenoid filter for an 86/87 Buick GN
Supercharger help Impala 2005 Wolverine316 7th Gen Engine Performance 7 08-21-2012 02:56 PM
'04 Impala SS - Sunroof Maintenance EXOTIC SS Autocare and Maintenance 6 12-30-2010 03:28 PM
Basic maintenance for 01 impala luke_fairs Chevy Impala 7th Gen Discussion 2 09-28-2008 07:25 PM
I have a 2004 Chevy Impala at 86k. What maintenance should I look into at Ana R Autocare and Maintenance 11 08-03-2008 02:46 PM
Supercharger for 01' Impala LS ponch89 Forced Induction 8 06-26-2008 12:15 AM
