Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Vehicle-Specific B-Body Discussion > Chevy Impala Discussion
Old 06-12-2008, 02:44 PM   #1 (permalink)
Don B
Don B's Avatar
Have 64 impala with rebuilt 327, doesn't perform right, need ideas.?
Remove this ad!
Have timing set a 4 btdc, dwell at 28, doggy on takeoff, also need info on correct way to vent crankcase. Has orignal smooth rockers (no pvc holes) Has 4 bl rochester carb. Everything is new in engine and compression is all good.
Old 06-12-2008, 07:34 PM   #2 (permalink)
impalacustom_76's Avatar
I am assuming you don't have vacuum advance since you have the old school points? I would give it more advance on the timingtry around 6-10, anytime you hop up an engine you should advance the timing, plus 4 degrees is pretty lean on the timing. After mechanical advance, weights in distributor, what is your total timing? I would aim for something near the 28-32 degrees total timing. Just be careful not to advance it too far as it will ping then. Is that quadrajet a vacuum or mechanical secondaries? Does the engine bog and then take off or just bog and not really feel alive all the way through rpm range? Personally on my old stuff I just use a vacuum gauge and timing light to tune my engine.
impalacustom_76 is offline
Old 06-12-2008, 09:58 PM   #3 (permalink)
60 Bel Wagon's Avatar
I have experienced the same problem and it turned out that the timing chain was out by 1 tooth. But then again I have also had the same problems with improperly adjusted rocker arms. Just some idea's :confused:
60 Bel Wagon is offline
Old 06-13-2008, 01:24 AM   #4 (permalink)
If you have the stock intake manifold you can knock a hole in the oil fill tube and either run a filter directly off that or run a line off that to a vacuum port on the carb.
Any ideas on what to name a 1964 Chevy Impala show car? WINKIES MOM Impala 1st - 5th Gen Discussion 4 10-29-2009 10:09 AM
i got a 02 impala with viper 791 installed,i got my engine rebuilt now the... Fabian M Chevy Impala Discussion 1 09-09-2008 02:01 AM
'03 impala won't take fuel at the gas pump below 40 degrees, any ideas? JUSTIN H Chevy Impala Discussion 1 03-06-2008 09:30 PM
I have a 1994 chevy impala ss had the tranny rebuilt 6x in 9 months. each kdwoodberry Mechanical and Electrical Problems 6 09-03-2007 08:10 PM
my 65 chevy impala ss will not hold in park, any ideas what could cause this? tina a Chevy Impala Discussion 0 09-02-2007 09:13 PM
