1963 Impala 283 engine swap to a LS1? - Chevy Impala Forums
post #1 of (permalink) Old 05-02-2008, 10:55 AM
Ben
Ben's Avatar
Quoted: Post(s)
I hvae a 63 Impala 4dr with a 283 engine and a powerglide. I have't began to work on it but am planning to. I want a better fuel efficiant more stronger engine. I was wondering if I a LS1 and a 4L60E transmission would be good for my project.
Would I have to do major modifications to the car.
Also would it be hard to get cruse control on that car.
post #2 of (permalink) Old 05-02-2008, 10:55 AM
Don B
Don B's Avatar
Quoted: Post(s)
Sure, it shouldn't be too hard to up-grade to the later model LS1/4L60E combo. Just make sure you get the wiring harness and computer out of the donor car. To go w/ the newly up-graded engine/tranny combo.
As for the cruise control, you can pick up an aftermarket cruise control from JC Whitney or someplace like that for the Impala.
Good luck!
Btw, nice ride, I had one those(in a 4dr thro, I'd perfer it been a 2dr) for my second car.
post #3 of (permalink) Old 05-02-2008, 10:55 AM
nwtrekkr
nwtrekkr's Avatar
Quoted: Post(s)
It will be very straight forward as long as you know what you are going. As essentially it is the same basic block, everything will be bolted in withfactory parts. The cruise will work with the computer. The biggest changes you probably have to make are driveshaft (shorter?) and transmission linkage.
post #4 of (permalink) Old 05-02-2008, 12:28 PM
pauly383's Avatar
About the only same thing is the bellhousing pattern , and even then a bolt is deleted and a bolt added . You can make old trannies fit though .
Heads , blocks , front accessory drive , oil pans , everything is different on ls1 style motors .
70 Malibu , 75 K5 , 83 K5 , 93 K2500 , 99 Suburban , 2003 Impala . four are mine , two are hers , two haven't seen daylight in several years :tongue:
pauly383 is offline
post #5 of (permalink) Old 05-02-2008, 12:52 PM
Heavy_SS's Avatar
i wouldnt go with a 4L60E. I would use a T-56. Cool points out the winder!!
Eric Iverson
96 BBB SS
51 k and counting.
Typical newbie mods, with no gas in the tank.
www.minnessota.com
Heavy_SS is offline
LS2 engine into a 1963 Impala Bigtoe Impala 1st - 5th Gen Discussion 11 10-27-2010 01:33 PM
04 Impala LS Engine Swap vick20 Chevy Impala Discussion 3 04-07-2009 12:58 PM
V8 Engine Swap for 7th Gen Impala? GTR 7th Gen Engine Performance 8 01-21-2009 08:20 PM
Engine wont start in 1963 impala? Erick R Chevy Impala Discussion 3 05-29-2008 01:39 AM
1963 Chevy Impala 283 engine w/powerglide engine swap to a LS1 & 4l60E? Ben Chevy Impala Discussion 0 05-03-2008 03:50 AM
