Fuel filling issues - Chevy Impala Forums
post #1 of (permalink) Old 02-10-2013, 10:11 AM Thread Starter
dla442's Avatar
Fuel filling issues
Just bought an 05 impala for the nanna. When filling the tank, the gas pump handle clicks of about 100 times....arg! i replaced the fuel vent solenoid and still not fixed. NO MIL LIGHTS either. Was going to shoot for thepurge solenoid or possible canister plugged, but if those go bad wouldnt a MIL come on? Just look for advice. Perhaps i should check the hose from the vent solenoid to the canister too......thanks folks
Thanks for your support
dla442 is offline
post #2 of (permalink) Old 02-10-2013, 01:47 PM
Designated Driver
CinRed's Avatar
The pump shutting off repeatedly.
I've had this happen before (with almost every vehicle I've owned).
I found that if you pull the pump nozzel out of the filler neck (just a lil' bit) it will stop shutting off on ya.
It almost seems like gas is splashing back into the nozzle tip, triggering the shut off.
"The weak are meat and the strong will eat."
CinRed is offline
post #3 of (permalink) Old 02-10-2013, 03:11 PM
auntjemima's Avatar
Dia442, evap codes won't show a MIL right away. Evap codes usually come on after 3 cold to warm runs of the engine. If its a new issue, it may show a code in the following week.
auntjemima is offline
post #4 of (permalink) Old 02-11-2013, 10:35 AM Thread Starter
dla442's Avatar
well, its been 30 days now. no matter hopw the handle is positions it clicks off. I have done a lot of reading on the evap system and seems rather obvious to diagnose if you have a tech-2 scanner and a smoke machine which i do not. i will start with the filler neck adn then check for obstructions in the vac lines etc....any other ideas before i tackle this annoying problem please advise......thank you
dla442 is offline
post #5 of (permalink) Old 02-11-2013, 03:23 PM
Gregg-O's Avatar
Put the lock on the first notch, fill it slow.
Gregg-O is offline
post #6 of (permalink) Old 03-04-2013, 12:58 PM
Royalwapiti's Avatar
You guys just don't get it. There is something differently wrong with these cars.
It doesn't matter how you hold the nozzle, how slow you set the trigger. The neck fills and clicks the nozzle off. It can take 20 minutes to put 10 gallons in my 04.
There is a vent line or something blocked, or maybe the filler tube is collapsed. Wish I knew.
Royalwapiti is offline
post #7 of (permalink) Old 03-05-2013, 02:06 AM
g25racer's Avatar
Hmm no issues with my 01. I am sure if "alot" of these impys had this problem "we" would hear more of it. Therefor, I believe you have a not so common issue going on. Likely a vent line or filler tube issue as you stated. I have had this issue happen "once" and went into the station, asked about it and the lady came outside and stated "this pump has issues so, pull the nozzle out a bit the, pump". Was no problem then. Def something abnormal going on if it takes you 20min to pump 10gallons. It takes me 4min tops for that even with pre-pay (much slower).
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #8 of (permalink) Old 03-05-2013, 05:01 AM
Joe
Joe's Avatar
Same here.
Not sure how the filler neck is configured on that car, but I had a truck years ago. I replaced the fuel tank and had a slight kink in my fuel filler neck. Fixed that and the problem went away...
** SOLD ** 2005 Impala - Base with a bunch of options / Debadged
1967 Camaro RS/SS L78 - Perpetual restoration project
2007 Trailblazer SS - Red Jewel
Joe is offline
post #9 of (permalink) Old 03-05-2013, 06:25 AM
Dave_N's Avatar
Quoted: 16 Post(s)
Have you tried easing up on the gas pump handle? I find that if you squeeze it fully, it will click too soon, but if you fill slowly, it will take more gas.
2006 Impala LTZ/SS 3.9 L V6
Magnaflow Catback Exhaust
5" Android Smart Mirror
Overkill Engine Tune!
Dave_N is offline
post #10 of (permalink) Old 03-05-2013, 07:02 AM
CopenGrizz01's Avatar
i have this exact same problem. i have a 2003 3.4l base and it dosnt matter how you hold the pump handle or the nozzle it will keep stopping. its like the fuel isnt going into the tank as fast as the pump is pumping it in and it clicks off like its a full tank. so i have to stand there and look like i dont know how to pump gas trying to put $25 in my tank. it sucks.
CopenGrizz01 is offline
post #11 of (permalink) Old 01-27-2014, 10:26 PM
Sofa King's Avatar
Did you get this figured out? It's happening in my 2008 Impala right now. And to top it off, now the floor heat doesn't work. The other vents work, just not the floor.
Sofa King is offline
Filling Gas Tank problems dla442 Chevy Impala 7th Gen Discussion 14 01-31-2013 09:48 PM
Fuel tank issues Ray2138 Mechanical and Electrical Problems 3 05-31-2012 09:17 PM
Gas filling problems 1BadLT1350 Chevy Impala 7th Gen Discussion 3 08-02-2010 08:44 PM
03 3.8 Start and stall after filling impaladino Chevy Impala 7th Gen Discussion 3 01-08-2010 10:40 AM
Lookin' for help troubleshooting fuel pump issues in a '95 SS klhill3 6th Gen Engine Performance 6 03-09-2009 09:56 PM
