motor and trans mount Replacement? - Chevy Impala Forums
  • 1 Post By kingnutin
post #1 of (permalink) Old 09-24-2012, 06:59 PM Thread Starter
Bobbyceleste's Avatar
hi we have a 2007 impala ,just had dealer tell us that engine and tranny mounts need to be replaced,But they wanted 900 to do it,so I have it at home now,and looking for info on how to switch them out myself, i would greatly apriciate any and all tips to getting this Job done!! i have the Haynes manual, it just gives basic info but, does not include the total number of engine mounts and tranny mounts i need to swap out, specific locations would be nice, please help,our car is in need !!!!!!!
Bobbyceleste is offline
post #2 of (permalink) Old 09-24-2012, 07:07 PM Thread Starter
I hope i posted this in the right place,sorry if i didnt
post #3 of (permalink) Old 09-25-2012, 04:32 PM
There are four total, one lower engine mount, one lower trans mount, and the two upper dogbones. The two upper dogbones are cake to change, just a couple minutes with a 15mm wrench and socket. The lowers are a serious pain in the ass to change. The engine mount bolts to the engine on the passenger side, two studs come out the bottom and into the subframe. The trans mount is on the driver side, and bolts to a bracket that bolts to the trans, also with two studs going into the subframe. You'll need to take the nuts off the bottom studs, and jack the engine up, use a block of wood on the oil pan. You may also need to lower the subframe a little to get clearance.
post #4 of (permalink) Old 09-27-2012, 11:26 AM Thread Starter
Awesome that's exactly what I needed, thank you. Thank you thank you,
post #5 of (permalink) Old 10-12-2012, 09:07 PM Thread Starter
The locations you gave me were right on the money. And lowering the subframe saved me a lot of hassle. I was able to get the replacement parts for about 300. From the local Pep Boys , I spent an hour on the trans mount. And about 1 and a half on the engine side , did not rush just kinda had to pry the old ones out. Thanks for the advice. It really helped guide me through this.
post #6 of (permalink) Old 10-15-2012, 01:09 PM
Glad I could help!
JahB1 likes this.
post #7 of (permalink) Old 01-21-2016, 09:07 PM
Pttaylor9's Avatar
Can you tell me how high you had to jack up the engine in order to remove the old motor mount on the passenger side ? I'm worried I'm going to break something. Thanks
Pttaylor9 is offline
post #8 of (permalink) Old 02-21-2016, 12:19 PM
Foute2001's Avatar
Where exactly are the mounts? I changed the top 2 and is was simple like you said. Doing that relieved a lot of the movement but I'm still hearing the clunk on the driver side. I live in Illinois so an unheated garage isn't pleasant but I have no other choice.
Foute2001 is offline
post #9 of (permalink) Old 02-21-2016, 12:21 PM
Foute2001's Avatar
Oh yeah its a 2001 impala 3.8
post #10 of (permalink) Old 12-19-2016, 04:43 PM
Rangel5656's Avatar
In order to replace the transmission mount, doni have to loosen up the engine mount as well??
I already changed the engine mount but I didn't loosen up the transmission mount at all!! I just jacked up the engine and replace the engine mount
Thanx
Rangel5656 is offline
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-discussion/331360-motor-and-trans-mount-replacement.html
Untitled document This thread Refback 09-16-2014 07:39 PM
bushings (motor mount) cali boi Chevy Impala 7th Gen Discussion 6 08-21-2012 09:30 AM
Poly Motor Mount & Poly Dogbone Mount 06ChevySS Private Wanted Classifieds 2 04-30-2012 08:19 AM
Motor mount flip? 06silverss Chevy Impala 8th Gen Discussion 7 05-17-2011 09:55 PM
Snapped Motor Mount 01 Blackout Chevy Impala 7th Gen Discussion 1 06-01-2009 06:49 AM
