Help with my leak ! - Chevy Impala Forums
Old 12-22-2009, 07:55 AM   #1 (permalink)
I PREFER FWD!!! AND IM A NOOB
mark8ish's Avatar
Exclamation Help with my leak !
Both my passenger side front and back are completely pooled in water. It's too much for the a/c, but I found it wet way up high near the a/c fan under the rubber fire wall. Can it be anything but the windshield leaking? Thanks
95' Impala SS - Headers - Cold air induction - 160 Stat - 3.73 Gears - 2200 Stall - Hypertech chipped
mark8ish is offline   Reply With Quote
Old 12-22-2009, 07:06 PM   #2 (permalink)
Gregg-O's Avatar
heater core if it's anti-freeze.
Old 12-22-2009, 07:24 PM   #3 (permalink)
77Impala's Avatar
Check the seal on the passenger compartment air filter. It is located under the windshield cowl. If the seal on it is bad then you will get water into the car.
Old 12-23-2009, 09:53 PM   #4 (permalink)
pinner's Avatar
Lightbulb
I had the same problem, when it rained my carpet would be wet on the passager side on my 04 impala SS what l found is that the cabin air filter that is in the cowl is not seated correctly and allowing water to enter the inside of the car. Im not sure if your Gen has one. But if its only when you have the A/C on then check the drain where the evaporator is in the car its most likely plugged not allowing the water to drain. Check under the car where the drain would be and blow short bursts of compressed air or some water from a garden hose up the drain
pinner is offline   Reply With Quote
Old 12-24-2009, 08:16 AM   #5 (permalink)
aka IMPALER
ekm1190's Avatar
hey i just posted a thread on this exact same topic... i'm in the process of figuring out what's going on. For a temporary fix i pulled up the carpet and the rubber up front and put towels down, then put a thin layer of plastic. Until i get it fixed it'll keep the water from getting to the carpet (as long as you change the towels regularly).
PLEASE LIKE Hoosier Impala & Caprice Club
Check out my build thread:"Form = Function"
ekm1190 is online now   Reply With Quote
water leak nycSS Chevy Impala 6th Gen Discussion 3 09-13-2009 08:15 PM
leak 00 impala Autocare and Maintenance 4 08-31-2009 07:03 PM
A/C Leak wowdusk Automotive Discussion 1 07-20-2009 08:39 PM
07 SS small oil leak Manoogia86 8th Gen Engine Performance 8 06-15-2009 05:47 AM
Found my oil leak deuce228 Buick Roadmaster 5 04-30-2008 01:32 PM
