| Chevy Impala Discussion Discuss all non-technical general Chevy Impala topics here. |
Traction Control light
I have already been reading up on this issue, and it sounds like I have a wheel hub assembly going bad... Is there a way to tell which one? It's obviously the front, so should both sides just get replaced or what? Any advise would be appreciated...
#3 (permalink) |
Sounds like an easy of enought of a test... thanks! I will check it out that way. Is there any harm in driving on it while it is bad? Other than the obvious uneven tire wear... Like, will the damn wheel fall off while i'm driving down the road or anything?
#5 (permalink) |
32-34mm I dont know if it depends on year or what, but thats what ive seen ppl using, IIRC i used a 33mm and it was a little loose.
you CAN seize the hub which = BAD but you'll hear it grind, get worse, then a loud snap ;) - THEN MORE GRINDING and feels like youre driving with a flat... Not that i would know ;)
I am Wanderson's bitch . ![]() See the NEW project: http://www.fullthrottlev6.com/forums...ad.php?t=59648 |
#6 (permalink) |
What year is your vehicle. On my 04 the drive shaft nut shows to be a 27mm and the hub bolt is a 12mm.
#7 (permalink) |
Mine is a 2001. Already had the front left one done 2 years, and about 35,000 miles back... So I will see. Thanks for the input and I will keep you posted when I get the chance to inspect it in the next day or two...
#8 (permalink) |
edit
crap im running 99 GTP axles... maybe thats why the difference?
#9 (permalink) |
The bolt size is the same as my vehicle
#10 (permalink) |
Thanks guys! I plan to do the work over the weekend... providing I can find the part locally.
| loving the traction control | Jam545 | Chevy Impala 7th Gen Discussion | 7 | 02-09-2010 09:53 AM |
| Traction control problem | Jake123 | Chevy Impala 7th Gen Discussion | 3 | 12-16-2008 09:21 AM |
| Traction control service light | cfjames11 | Autocare and Maintenance | 3 | 12-07-2008 01:38 PM |
| Traction Control Warning | brntblock | Mechanical and Electrical Problems | 5 | 09-02-2008 08:09 AM |
| 2002 Chevy Impala Service Traction System Light comes on with ABS light;... | preciousmoments | Mechanical and Electrical Problems | 2 | 09-06-2007 03:01 AM |
