Overheating issue. - Chevy Impala Forums
post #1 of (permalink) Old 02-16-2017, 03:40 PM Thread Starter
Jeffsax's Avatar
Overheating issue.
Hello,
I have a 2003 3.4 impala. When I drive my car within the first 3-4 kilometres it overheats, than I pull over and shut it off and let it sit for a few minutes and it drives fine after that, no overheating issue. Put a new thermostat in it, but it still overheats.
This also happens on cold Canadian winter mornings.
Jeffsax is offline
post #2 of (permalink) Old 02-16-2017, 04:32 PM
Quoted: 34 Post(s)
Originally Posted by Jeffsax View Post
Hello,
How is it overheating? Are you seeing the temp gauge reading too high? Any other symptoms?
When you see it doing this, are the radiator fans on? It may be you have a bad relay resulting in the fans being off when they should be on. This is more noticeable in stop-n-go traffic. At highway speeds, the fans aren't needed so much because of the air being pushed thru the radiator.
Another thought is a bad temp sending unit or bad wires coming from it. You can inspect the wires looking for a damaged spot. This requires removing the wires from the plastic loom. (And it can be a PITA to put it back in the loom.)
post #3 of (permalink) Old 02-16-2017, 05:34 PM Thread Starter
Jeffsax's Avatar
So it'll be fine for the first kilometre than the gauge creeps up and red lines and the car loses power, so I pull over and turn it off. There isn't any smoke or anything like that coming from the engine. The heater and air conditioner still work perfectly fine.
Jeffsax is offline
post #4 of (permalink) Old 02-16-2017, 05:35 PM Thread Starter
Jeffsax's Avatar
Oh and sorry the fans are on when it overheats too
Jeffsax is offline
Overheating issue jayare96 Autocare and Maintenance 0 08-27-2015 05:04 PM
Overheating issue with 2000 Impala 3.4L JohnnyV Chevy Impala 7th Gen Discussion 42 12-15-2013 12:25 AM
2004 3.4 Overheating Issue Stormhawke Mechanical and Electrical Problems 13 11-21-2013 07:12 PM
Overheating issue.. gamepro56 Mechanical and Electrical Problems 1 10-22-2013 06:21 PM
overheating issue nycSS Chevy Impala 6th Gen Discussion 7 06-07-2010 09:30 AM
