| | #1 (permalink) |
| Junior Member | 180 Degree Thermostat I have an 04 Impala SS. I swapped out my pulley and I installed a 3.4 inch pulley with new gator back belt. I also have a k&n intake. Now I heard that if you drop your pulley size you must get a 180 Degree Thermostat. Now my car comes stock with 180 stat and my oil temp and engine temp runs perfect. I don't see anything wrong? Does anyone know if I should get the stat or no? Then lastly spark plugs. They recommended me to get Autolite 103's...any suggestions of what I should do or even what else I should purchase... -Thanks |
| Sponsored links | |
| | #6 (permalink) | |
| Super Moderator Join Date: May 2008 Location: Detroit
| Quote:
good read on plugs http://www.oqcgp.com/forum/kb.php?mode=article&k=50
__________________ Last edited by 04DetroitLS : 10-05-2008 at 03:26 PM. | |
| | #7 (permalink) |
| Super Moderator Join Date: Nov 2007 Location: Denison, TX
| I have tried 2 different "performance plugs" in my factory original stock 305. These are my findings. 1) No milage increase. 2) No performance increase, performance was worse-see 3 & 4. 3) Idleing was bad. 4) Engine had momentary hesitation when applying the accelerator. Put the AC Delco plugs in and idleing was smooth, and the hesitation disaperd. A friend of mine whom use to work for for a GM dealership had customers come to the shop just after doing their own tune up and said the car was not running correctly. Since the customer had done their own tune up the technitions would pull a spark plug wire and see what plugs the owner had put in there. 9 out of 10 times the tech's would replace the plugs with the proper AC Delcos and the engine problems were gone.
__________________ 1977 Impala Sedan, 5.0L, TH200R, 3.25:1, 74K miles, 26 Lifetime Warranty Parts. 1997 Dodge Ram B2500, 5.2L, 3.21:1, 334K miles, 6 Lifetime Warranty Parts. |
| | #8 (permalink) |
| Senior Member Join Date: Jun 2008 Location: MASSHOLE USA
| im with u 04detroit, ill be putting colder plugs & t-stat when i drop my pulley so i dont get detonation.
__________________ 05 SS IMPALA 14.748 @ 94.06 mph MOD'S<JMB PERFORMANCE FENDERWELL INTAKE-ROYAL PURPLE HIGH PERFORMANCE OIL-K&NOIL FILTER-R1 DRILLED & SLOTTED ROTORS-HAWK PERFORMANCE PAD'S-STREETTRENDS BILLETGRILLE-35%TINT-RAINGAURDS-8000K HID LOW BEAM-8000K HID FOGLIGHTS-REMOVED CIRCLE FROM SIDE IMPALA SYMBOLS-KENWOOD DECK-DIAMOND AUDIO SPEAKERS&TWEETS-DIRECTED AMP-VIPER ALARM>& MORE TO COME |
| Sponsored links | |
Similar Threads | ||||
| How do I change my thermostat in my '05 Impala 3.4 V6..I changed the water... | Scooby | Chevy Impala Discussion | 1 | 08-02-2008 05:43 PM |
| how difficult is it to change thermostat for impala? | holyghost130 | Chevy Impala Discussion | 1 | 11-03-2007 07:06 PM |
| How to remove thermostat from '93 Sunbird? | ViSaja | General Automotive Discussion | 0 | 09-13-2007 09:59 PM |
| 1987 Pontiac Sunbird Thermostat replacement? | beavisman4 | General Automotive Discussion | 0 | 09-12-2007 04:26 PM |
| 93 gran prix, what would cause overheating besides the thermostat? | beckykinney1 | General Automotive Discussion | 0 | 09-09-2007 08:28 PM |
