| Chevy Impala Discussion Discuss all non-technical general Chevy Impala topics here. |
flat spot when punched
Recently installed K-N cold air intake kit and all is well except when you floor it. It takes off right away and quickly falls on it face for a half second then catches up and away we go! Any tips clues suggestions?
We are dealing with a 2007 SS with the 5.3 of course. |
| Sponsored Links | |||
Advertisement | |||
2007 Bogg
I am not sure how many miles you have on the Impala, It could be the fuel filter?
Check with your local tuner guy. Are you planning on doing a cat back exhaust, you may want to tune after you do the exhaust and 160 Deg Stat. __________________ PAUL R DUMDIE JR. HERD546 ISSCA 2158 W9DWP AZISSO 460 www.theherd.com 1996 DGGM IMPALA SS 1995 BLACK CAPRICE SS WAGON 2008 Impala LT 2002 Impala LS HERD Club Events Coordinator. |
#3 (permalink) |
Moderator
maybe something to do with the tune (DOD OR tcs), if youre spinning the wheels then it falls flat, then picksup up again, I'm willing to bet its the TCS/Torque Management, which can be tuned out.
__________________ any asshole can make a v8 fast It takes a special breed oof stupid/crazy asshole to make a v6 fast http:www.hellfiremotorsports.com/garage |
#4 (permalink) |
flatspot
Thanks for the tips guys!
Now that I think about it,I'm not sure if I had the traction control on or off as 04 Detroitls mentioned! The car only has 7300 miles on it so I can't believe it is a failure of other sorts. I don't believe it did this until I put on the air intake but it's not like I make a habit of seeing how much fuel and rubber I can burn every time I drive it. I'll experiment some more when the chance arises and see what results I get and let you guys know what's up. Thanks again! |
#5 (permalink) |
Moderator
IIRC the torque mgmt stays on even if TC is off (so you dont grenade your trans) there are aftermarket tuners/pcms (stay away from piggy back chips ie Jet) that will adjust your shift points, fuel maps, etc so you can get every ounce of fun out of it ;)
#6 (permalink) |
Probablly the TC/electric pedal
Ive noticed something similar in my 2007 SS with 33000 miles... I think flooring it may cause some unexpected results due to the electric pedal and the logistics of the traction control. I wouldnt worry about it, just dont slam the pedal like me
| Sponsored Links | |
Advertisement | |
| Will flat lifters last much less longer than roller ones in a Chevrolet | m_tony48 | Chevy Caprice | 2 | 09-11-2008 09:22 PM |
| I have a 04 Impala and recntly hit a pothole and got a flat.? | andrew m | Chevy Impala Discussion | 1 | 06-04-2008 11:49 AM |
