2016 stock headlight bulb - Chevy Impala Forums
post #1 of (permalink) Old 03-11-2017, 04:51 PM Thread Starter
Mikey7436's Avatar
Quoted: 5 Post(s)
I just purchased a 2016 the other day and wanted to switch out the headlight bulbs to LED. My question is how many other owners have 9005 bulbs in their car? My manual says 9005 but every part store lists 9012 for the bulb. I called the dealer and asked them and they couldn't give me a straight answer because they didn't have any in stock.
Thank you
Mikey7436 is offline
post #2 of (permalink) Old 03-11-2017, 07:01 PM
The Guz's Avatar
Quoted: 11 Post(s)
What model?
The Guz is offline
post #3 of (permalink) Old 03-11-2017, 10:17 PM Thread Starter
Mikey7436's Avatar
Quoted: 5 Post(s)
It 2 I believe or just a lt
post #4 of (permalink) Old 03-11-2017, 10:49 PM
ICUBB's Avatar
Quoted: 43 Post(s)
Sites list 9012, unless they changed it mid model which I cannot imagine why, I would order from a location that takes returns.
http://www.impalaforums.com/signaturepics/sigpic129377_1.gif
Just a resident noob.
ICUBB is offline
post #5 of (permalink) Old 03-12-2017, 08:40 AM
blue2lt's Avatar
I recently ordered a 9012 LED kit for my LT2 and the bulbs will fit but they are not cut exactly like the stock bulbs. I had to kind of put them in at an angle and turn to get them flush into the housing. Also, I would definitely recommend HID's over the LED's. The lighting was more blue than white and honestly to me didn't put out too much more light than the stocks, especially on the sides where the impala lacks.
blue2lt is offline
post #6 of (permalink) Old 03-12-2017, 11:04 AM Thread Starter
Mikey7436's Avatar
Quoted: 5 Post(s)
I haven't tried putting the 9012 in the housing but the socket for the headlight will not do a 9012 bulb. It works with a 9005 bulb. Which is weird cause I believe a 9005 bulb is a high beam bulb.
post #7 of (permalink) Old 03-12-2017, 11:08 AM Thread Starter
Mikey7436's Avatar
Quoted: 5 Post(s)
I looked a a 15, 16, and 17 and they all list 9012 bulb so they couldn't of changed it mid year. So I'm wondering why mine says 9005.
post #8 of (permalink) Old 03-12-2017, 11:56 AM
impaler's Avatar
Quoted: 86 Post(s)
Someone else mentioned their car having a 9005 bulb on here before as well.
It was Thomcat on his 2017 Impala. Here is the thread http://www.impalaforums.com/chevy-im...-impala-9.html
Page 275 of the 2016 Impala owners manual does show a 9005 bulb listed https://www.chevrolet.com/content/da...ers-manual.pdf
Page 277 in the 2017 Impala owners manual does show a 9005 bulb listed https://www.chevrolet.com/content/da...ers-Manual.pdf
From what I've read an 9012 HIR bulb has little higher lumen spec than a 9005 bulb. I wonder why they switched to a 9005 bulb and I also wonder if the newer Impalas put out better or worse light with the bulb change than the 2014 and 2015 Impalas.
2015 2LT
Convenience pkg
Advanced Safety pkg
Sunroof
Suntek CXP 50/35 tint
impaler is offline
post #9 of (permalink) Old 03-12-2017, 12:35 PM Thread Starter
Mikey7436's Avatar
Quoted: 5 Post(s)
I have h11 leds and a h11 hid kit from my 13 impala. Anyone know if I could use those bulbs in place of the stock 9005 bulbs?
post #10 of (permalink) Old 03-12-2017, 01:05 PM Thread Starter
Mikey7436's Avatar
Quoted: 5 Post(s)
Yea the dealer couldn't even give me a straight answer
post #11 of (permalink) Old 03-12-2017, 01:30 PM Thread Starter
Mikey7436's Avatar
Quoted: 5 Post(s)
Also how do I know what LT version I have? I was told a LT 2 but not surw
post #12 of (permalink) Old 03-12-2017, 01:38 PM
ICUBB's Avatar
Quoted: 43 Post(s)
Is it a 6cyl or 4cyl?
6 is 2LT, 4 is 1LT
ICUBB is offline
post #13 of (permalink) Old 03-12-2017, 01:42 PM
Quoted: 73 Post(s)
Try punching your vin # into a decoder.
https://www.google.com/#q=2016+impala+vin+decoder&*
They return varying degrees of detail, but most should indicate the trim levels.
plano-doug is online now
post #14 of (permalink) Old 03-12-2017, 08:33 PM
ICUBB's Avatar
Quoted: 43 Post(s)
I looked at my Amazon order to confirm my bulb size through KenSun and mine were a 9006 (HB4) for HID's. I still think your best suggestion is to order through a retailer that takes returns if they suggest the wrong item.
ICUBB is offline
post #15 of (permalink) Old 03-13-2017, 12:36 AM
The Guz's Avatar
Quoted: 11 Post(s)
Do you still have the stock bulb? Does it say what it is on the bulb base?
Can you post a photo as well.
9011/9012 HIR bulbs are suitable replacements for 9005/9006. All it requires is a little modification at the base of the bulb. HIR's produce more lighting.
Here is a link on how to trim the tabs.
How to Modify HIR bulb bases
I did check the manual and it lists the 9012 as the replacement bulb. Do you have a 9006 to try?
The Guz is offline
Headlight For 2015-2016 Chevrolet Impala Passenger Side w/ bulb RSS Bot Impala Diecast Toys Cars on eBay 0 02-24-2017 08:50 AM
2016 2X H11 H8 H9 180W 18000LM LED Headlight Bulbs Philips Plug Bulb White 6500K RSS Bot Impala Diecast Toys Cars on eBay 0 02-17-2017 08:00 AM
2016 2X H11 H8 H9 180W 18000LM LED Headlight Bulbs Philips Plug Bulb White 6500K RSS Bot Impala Diecast Toys Cars on eBay 0 02-03-2017 08:00 AM
2016 New 180W 18000LM H11 H8 H9 Single Beam LED Headlight Bulb w/copper belt 5S RSS Bot Impala Diecast Toys Cars on eBay 0 01-23-2017 09:12 PM
2016 2X H11 H8 H9 180W 18000LM LED Headlight Bulbs Philips Plug Bulb White 6500K RSS Bot Impala Diecast Toys Cars on eBay 0 01-20-2017 06:50 AM
