LED turn signal doesn't blink? - Chevy Impala Forums
Old 03-21-2013, 06:26 PM   #1 (permalink)
Stikky's Avatar
I replaced my rear bulbs with LEDs and after a resistor install resolved the hyper flash and they work great. Repeated the process on the front bulbs and although the hyper flash is gone they won't blink. I installed the resistor on the same yellow & black wires as I did on the back, do you think this is possibly the problem or is there something else I'm missing?
Stikky is offline   Reply With Quote Quick reply to this message
Old 03-21-2013, 06:33 PM   #2 (permalink)
SCOTTYINWV's Avatar
May have hooked them up to the park light, not the signal?
SCOTTYINWV
SCOTTYINWV is offline   Reply With Quote Quick reply to this message
Old 03-21-2013, 06:40 PM   #3 (permalink)
Stikky's Avatar
I checked that anyway but it would have been impossible to do. Opposite ends of the headlight plus the resistor fixed the hyperflash but the bulb now won't flash at all.
Old 03-21-2013, 07:14 PM   #4 (permalink)
SCOTTYINWV's Avatar
Try taking out the resistors and see if they even do the hyperflash now, its possible they burnt up. Are they the cheapos off ebay?
SCOTTYINWV
Old 03-21-2013, 10:00 PM   #5 (permalink)
Stikky's Avatar
I bought the decent ones from DDMTuning I feel confident the resistor is still good. I pulled the resistor and the hyperflash returned but only on the rears. The front bulbs remained lit and did not flash at all. I put the LEDs on the back burner and installed the HIDs, I'll try to get back to the LEDs this weekend. I heard something about getting an electronic flasher or something is necessary to resolve the no flash issue in the front. I don't know if that's even true or not.
Old 03-21-2013, 10:19 PM   #6 (permalink)
SCOTTYINWV's Avatar
I'm not sure what your working on. Are the front and rear bulbs the same? Could you swap them around to see what happens? Again I don't know what your working on so I don't know the bulb sizes.
SCOTTYINWV
Old 03-22-2013, 12:48 PM   #7 (permalink)
They should all be the same bulb, save for color maybe. The car already has an electronic flasher, clearly just a poorly designed one. Resistors are the only fix I am aware of on these. Use a meter to check the resistors, make sure they didn't burn out.
Old 03-24-2013, 06:56 AM   #8 (permalink)
Stikky's Avatar
Sorry the car is an 07' SS. I have tried the bulbs with and without resistors and the only thing that changes is hyperflash. They dont blink either way. I tried a different LED with the same result. Not sure what else it could be.
Old 03-26-2013, 07:52 AM   #9 (permalink)
KERR's Avatar
some cars just dont like LED. Take my sububran, the LED tail light works fine, but they dont have the current the electrical system needs to see, so the curise doesnt work.
KERR is offline   Reply With Quote Quick reply to this message
turn signal wont turn off. sublimeaces Impala 1st - 5th Gen Discussion 3 10-02-2012 09:57 AM
Turn Signal ejeezy_23 Chevy Impala Discussion 3 06-01-2011 03:28 PM
sequential tail lights aka blink blink blinks buddyluv Appearance 4 03-06-2011 07:39 PM
Something broke on turn signal lever? Turn light won't turn off sswodawg81 Chevy Impala 6th Gen Discussion 0 11-02-2009 02:19 PM
Have a impala 2000 and trying to make all 4 rear lights blink with turn poscam_77 Chevy Impala Discussion 1 04-15-2008 04:51 AM
