Car Shaking - Chevy Impala Forums
post #1 of (permalink) Old 01-24-2013, 05:10 PM Thread Starter
xxpjmxx's Avatar
Car Shaking
Hello everyone
Ive been having an issue with my '08 impala (3.9l Police Interceptor)
At any speed, in any gear, when i softly press on the gas the car begins to shake. If I press harder on the gas the vehicle takes off just fine.
Also at night my headlights, dash lights, and fog lights turn on by themselves. Keep in mind its 1 degree where I am at in Michigan. My positive terminal had a horrible clamp attached and was fairly loose, so I had it replaced for 20$. Hoping the terminal was loose and resetting the computers causing the lights to go on it wasnt the case. So now im leaning towards replacing the BCM. Any temporary fixes to the issue? I pulled the fuses from my LR and LL beam headlights but all the other lights still came on and the doors were dinging. I have fuses for Batt. 1, Batt 2., Batt 3., and Batt. 4.
Any of these fuses specifically for lights that I can detach every night before bed?
Any help is appreciated thank you
xxpjmxx is offline
post #2 of (permalink) Old 01-25-2013, 05:40 PM Thread Starter
xxpjmxx's Avatar
UPDATE
I posted this on yahoo answers as well and someones reply was:
Why are you jumping on the transmission?
With the car running in Drive, hold the brake with the left foot and lightly press the gas with the right foot (don't exceed obvious limitations), do you feel the shake? If so, it is an engine problem, if not, need further diagnosis.
If you don't feel the shake, then the problem exist from the transmission "back" anything that should be rotating. Guessing the 115xxx is mileage, I would expect a rotating joint to have failed. CV or U-joint since this type of joint also gives flexing at various angles.
If the part about holding the brake is true.. it does still shake after I press on the gas. So if this is an engine problem what are the possibilities? A better way of describing what happens is pretty much if im trying to just keep a speed the car shakes but if I slow down or speed up the car does not shake.
Any help guys? Id appreciate it
xxpjmxx is offline
post #3 of (permalink) Old 01-26-2013, 05:35 PM
p-3
p-3's Avatar
My best bet is its haunted by the ghosts of those that got run over by this cop car. But how bad is the shake ? I know i feel it bit shaky too at idle but so did the rental car so it must be the sheer power ?
But i think its haunted else why would the lights come on by themselves ?
p-3 is offline
post #4 of (permalink) Old 01-26-2013, 09:39 PM
Evilemokid94's Avatar
how do you get your fog lights to come on with the key? I have to push my button
Evilemokid94 is offline
post #5 of (permalink) Old 01-26-2013, 09:57 PM
Anonymous's Avatar
Originally Posted by xxpjmxx View Post
Hello everyone
i'd check the motor mounts they tend to fail between 120k and 180k on most cars
Anonymous is offline
post #6 of (permalink) Old 01-27-2013, 07:54 AM Thread Starter
xxpjmxx's Avatar
Not haunted just a bad connection somewhere. ANYWHERE. This is a terrible problem I was thinking it was the BCM that needed to replace because its not just one light that goes off at night (in 7 degree weather) its all of the lights! BUT the lights stay off in weather usually above 25 degrees (guesstimate). Sooo I wouldnt say the BCM is bad but may be acting up. I believe there is a ground or a connection somewhere that is bad but I have no experience in electrical in cars.
And motor mounts is something I will look into thanks for the suggestion. But if it is the motor mounts wouldnt the motor shake quite a bit? Especially when I am speeding up?
Anymore suggestions guys keep em comin thank you
xxpjmxx is offline
post #7 of (permalink) Old 01-28-2013, 11:12 AM
So are you saying it DOES shake when you rev with the brake applied? (Not moving)
post #8 of (permalink) Old 02-01-2013, 07:00 AM Thread Starter
xxpjmxx's Avatar
Sorry I havent been on in a while. Thanks for the replies. When I am pressing the brake and giving gas (not moving) the car does shake a bit. Not as bad as when I am driving though.
xxpjmxx is offline
post #9 of (permalink) Old 02-01-2013, 07:16 AM
p-3
p-3's Avatar
So driving the car shakes or is there a weird wobble ? What about at stop lights is it more significant than ?
p-3 is offline
post #10 of (permalink) Old 02-01-2013, 12:16 PM
If it shakes when the car is not moving, most likely it's either torque converter out of balance, or a bad harmonic balancer.
post #11 of (permalink) Old 02-01-2013, 01:57 PM Thread Starter
xxpjmxx's Avatar
The car does not shake at idle or when it is stopped. Only when I gas and break at the same time
xxpjmxx is offline
post #12 of (permalink) Old 02-01-2013, 02:00 PM Thread Starter
xxpjmxx's Avatar
The car doesnt wobble. When I keep a speed the car shakes harder until I press a little harder on the gas. Feels almost like stalling out
xxpjmxx is offline
post #13 of (permalink) Old 02-01-2013, 02:56 PM
If it doesn't do it at all at idle, I may well be wrong on the balance issues. Kinda stumped now...
post #14 of (permalink) Old 02-01-2013, 08:24 PM
p-3
p-3's Avatar
I am wondering if bad axle or bad cv boot might do that ? Or a bad steering column maybe ?
p-3 is offline
post #15 of (permalink) Old 02-02-2013, 05:51 AM
imandyyornot's Avatar
Send a message via AIM to imandyyornot
I was leaning towards the motor mounts... Why not bring it to your mechanic?
Anyone From The NYC Area? Lets Meet Up.
06 Impala LS
imandyyornot is offline
Shaking at startup aztecs2006 Chevy Impala 7th Gen Discussion 30 11-20-2015 09:32 PM
Vibration/Shaking SS Petey Chevy Impala 8th Gen Discussion 19 09-03-2015 12:16 PM
Shaking in front, Steering wheel is also shaking? Jayln Autocare and Maintenance 12 11-21-2012 12:30 AM
05 impala shaking while driving biggyal66 Autocare and Maintenance 10 11-22-2011 08:52 AM
Shaking/Vibration after 60 MPH ebburtner Automotive Discussion 2 03-17-2011 05:55 PM
