2009 Impala LT stuck in park. - Chevy Impala Forums
post #1 of (permalink) Old 11-16-2012, 10:01 PM Thread Starter
ImpalaShift's Avatar
Hi,
Let's start this off by saying that this is the time I have ever visited this forums and that I am not a car genius. So, please bare with me.
Today, I drove to work and everything in my car was working fine. I parked as usual, and left to work. After the end of my shift, I started the car to go home, but I could not shift from parking. I tried everything from from braking to wiggling the shifter, but it was no use. The button on the shift stick would not press. I decided to take the middle panel apart, and after messing around with pretty much everything, I accidentally pressed a silver "button" found a few inches under the stick, on the passenger side. Pressing the button allowed me to shift. But now the key get's stuck in the ignition.
I also noticed that some wires were out. These are four cables in a grey adapter on the passenger side. The adapter had two blue tabs, one on each side. It has silver fixtures inside for the cables to go on, but I don't know how to remove them.
UPDATE
I managed to take the metal fixtures out of the grey adapter. There are pieces of cable in each of them and they are labeled "A,B,C,D,E." The problem now is that they were already broken by the time I got to them, so I don't know which cable corresponds to which letter. There is a green cable, a purple, a black and a yellow.
Thank you for readying, I hope you guy can help me fix this.
Sorry for not knowing the actual names of things.
ImpalaShift is offline
The Following User Says Thank You to ImpalaShift For This Useful Post:
puffy304 (10-21-2013)
post #2 of (permalink) Old 11-17-2012, 03:28 PM
Bart77's Avatar
Quoted: 15 Post(s)
I believe those wires hooked to the BTSI (brake transaxle shift interlock) solenoid. I have seen a few of those wires brake at the connector and cause the issue you described. Your key is getting stuck in the ignition because the key lock solenoid is not being grounded threw the BTSI solenoid. The solenoid needs to be reinstalled like it was to it's pivot points, and the wiring fixed. A new wire harness connector to the BTSI solenoid will have thicker wire connected to the terminals that would be less likely to break. For whatever reason GM has the solenoid move along with the shifter and the wires eventually break from flexing while the vehicle is shifted from park to drive, etc. If you reuse the old terminals hopefully you did not damage the connector nor terminals when you tried to remove them. Here is a chart showing what wire goes where and what each wire is used for.
Automatic Transmission Shift Lock Control Solenoid (with Floor Shifter)
Pin _____ color ________ use
A _______black ________ground
B ____green/white ______A/T Shift Lock Control Solenoid Supply Voltage
C ____Purple/white ______Steering Column Key Cylinder Lock Solenoid Control
D ________- ___________ Not Used
E _______ - ____________Not Used
F _______Yellow ________ Accessory Voltage
Bart77 is offline
The Following 2 Users Say Thank You to Bart77 For This Useful Post:
cobalt327 (08-23-2015), puffy304 (10-21-2013)
post #3 of (permalink) Old 11-19-2012, 09:58 AM Thread Starter
Hi,
You diagram seems right. I have managed to test the purple wire and it does seem to be the key. They way it worked was odd though. I accidentally touched the purple to the green and I heard the key slot click and I was able to remove the key. Yet, I still have not managed anything else to work. Any ideas?
post #4 of (permalink) Old 11-19-2012, 11:13 AM
Quoted: 7 Post(s)
ImpalaShift, I'm sorry you've been having frustrations with your Impala! While we as customer service representatives are not able to provide much in the way of do-it-yourself information, I hope that you get some great feedback from the forum.
If you have any questions about recalls or warranty information, or wanted our assistance in locating and working with a dealership, please don't hesitate to contact me through private messaging on the forum. (We ask that you please include your name, contact information, and the last 8 digits of your VIN in your message.)
Best,
Katie
Chevrolet Customer Service
post #5 of (permalink) Old 11-20-2012, 07:36 PM
Bart77's Avatar
Quoted: 15 Post(s)
The only Idea I have is that the old connector must be too damaged to be repaired and now you need to get a new wire harness connector and pigtail from your dealer, wire up the new connector according to the diagram above and reconnect the new connector to the BTSI solenoid/the button and the system should work.
Bart77 is offline
post #6 of (permalink) Old 11-21-2012, 07:59 AM Thread Starter
Alright, so I went to the mechanic--nasty thing to do in a college student's budget--and he said to find the solenoid, as they usually don't carry them, and take it to be installed. I looked at the only junk yard in the area and they said they don't carry Impala, but they have other Chevy vehicles. They said to find out if any other Chevy vehicles use the same solenoid and then maybe they can help me find it. Same goes for the adapter.
Do you know if any other Chevy models would use the same?
Thanks!
post #7 of (permalink) Old 11-21-2012, 02:25 PM
auntjemima's Avatar
pull it out, get the part or any numbers off of it and then google them or hit the chevy dealer and ask them. That would be the easiest way.
auntjemima is offline
post #8 of (permalink) Old 12-17-2012, 08:21 AM
maheider's Avatar
This appears to be an all to common issue with these cars. I have a 2009 which has not failed (yet) and a 2010 that has. It rendered my daughter's 2010 car unusable since she could not get it into drive although the car was otherwise perfectly functional. That could have been a serious issue had she been somewhere less safe after dark for instance.
I was able to pry the trim away, and temporarily remove the shifter to get the housing underneath off. That exposed the magic button therein which allows the shifter to move when it is pressed. Why Chevy does not at least provide an access hole thru which a screwdriver or something else could be poked to depress that should it fail without requiring that disassembly is beyond me. If one poorly designed or improperly wired component can fail and make the car useless, there ought to be an easy way to bypass that component.
I called the dealer, and they indicated that there are no recalls on this car, and that since I have 60K on it, the warranty does not cover it. My argument that this is directly related to the transmission (in that you can't make use of the transmission, or the engine for that matter if it fails, and it is an integral part of the functioning of the transmission) fell on deaf ears. Not covered by the powertrain warranty was their answer. This is pretty crappy for a car that is less than two years old IMHO.
Anyway, I can probably figure out a way to creatively rewire this to "fix" the problem, but the fact that the whole thing moves with the shifter leads me to believe that there is a good chance of it happening again, and that time it may be in a much less convenient location.
My question is, does anyone know how to permanently bypass this "feature"? The protection it provides is minimal, and the whole thing was really designed from what I can tell to prevent young children from putting the car in gear accidentally. I am fairly certain that the automakers agreed with the NHTSA to install these interlocks for that purpose. I have no young children, and even if I did, they would not be playing in a car in the first place, let alone one with the key in the ignition. I have a 1983 Mercedes diesel with a floor shifter (auto trans) and it had no such safety feature and the lack of that was no issue. Yes, you could shift the car out of park at any time, but so what?
Is there an easy way to permanently disable this system? Would there be other issues, such as perhaps causing the key to not be able to be removed from the ignition, or the ability to attempt to start the car while it is in gear if I did so? Based on the way it failed, I assume that if it loses power (due to a broken wire, or even a dead battery) that it fails in the "locked" position. If that is the case, then it seems I would have to perhaps run power to it that is at least on when the car is running which might be a pain in the backside to get to that location. I was hoping perhaps there is a way I could jumper something to place it permanently in an unlocked state. As long as that is not a big power drain or something, I don't see an issue with doing that.
I am frustrated that the dealer is no help with something that should not be an issue on a 20 month old car. This, along with the myriad of other silly but expensive to repair issues with the car has really made me question my judgment in buying these vehicles. When they are working properly, they drive fairly well, and they are pretty fuel efficient for their size. I would really love to disable this on the 2010, and then proactively do the same for our 2009 if at all possible.
Thanks for any advice you might be able to provide me.
maheider is offline
post #9 of (permalink) Old 02-13-2013, 12:27 PM
c65rosses5's Avatar
2006 gear shift / key stuck
I want to thank you to all of you who have posted notes on here. After being on the phone yesterday for 2 hours trying to see if there was a recall, what GM was planning on doing about this gear shift problem that seems to be a very big problem. I basiclly got no where with them. I read through all these post and decided to attempt to fix my moms car myself. I have to say that I am a female. So I followed all the instructions. Took apart the console. No problems there. Found the wires and the button. I saw immediately the green wire was broke. Went to Chevy dealer, bought a foot of green wire and the silver connector all for $3.61. Came home and rewired the thing myself. But the only thing I should of done before putting the console back together, was to see if the key would come out. My mistake. So went back to Chevy dealer and bought yellow, purple, black wires and more silver connectors. I will splice together all these wires myself. I am really disappointed with GM for not going forth with a recall. They said my mom first had to take her car to Chevy dealer to put on dianostic machine. I totally understand that but who can afford $138.00 just to put on dianostic machine. I explained to GM, like millions of americans that are getting SCREWED by GM they should be responsible to making the wiring harness too short in the first place. I hope more folks read these post and are able to fix their cars just like I did and not take them in to auto machanic and pay hundreds of dollars to get this part fixed. Again thank you so much for posting all these instructions, it proves that woman can fix this gear shift/key issue.
c65rosses5 is offline
The Following 2 Users Say Thank You to c65rosses5 For This Useful Post:
Ejbiers (02-13-2013), rmejag (05-13-2013)
post #10 of (permalink) Old 02-13-2013, 03:11 PM
Back in Black
12ltz's Avatar
Good job and keep after them
_________________________
2012 Impala LTZ 72,000 miles
12ltz is offline
post #11 of (permalink) Old 02-15-2013, 11:11 AM
mrant212's Avatar
Had the same issue with my 08 SS. Happened in a gas station and I needed to be flat bedded to the dealer. Should be a recall/bullEtin. Has happened to way to many cars.
mrant212 is offline
post #12 of (permalink) Old 02-16-2013, 09:13 AM
systemcheck2006's Avatar
got the same issue right now. it's acutally the third time this has happened where the ground wire snapped out of the harness. got sick of it and just broke the tabs off the fake wood panel for easy removal, so I can get my hand in there and push the button. This is annoying, should be recalled.
then you'd be normal."
systemcheck2006 is offline
post #13 of (permalink) Old 07-01-2013, 02:07 PM
MikeMoore's Avatar
I'm experiencing this now. I was able to get the key out but the shifter was locked. I got the part out and got a replacement from NAPA but now I can't get my key out but the shifter works! Any ideas?
MikeMoore is offline
post #14 of (permalink) Old 07-01-2013, 02:20 PM
wde3477's Avatar
Suggest there's a wiring problem with the replacement. IIRC, the solenoid controls both the shift lock and the ignition key removal. I don't have the schematic handy to be able to help further.
2008 LTZ - 209,000 miles - SOLD
1981 CJ-5 - 171,000 miles
1989 F150 - 217,000 miles - SOLD
2014 F150 - 8,000 miles
wde3477 is offline
post #15 of (permalink) Old 07-01-2013, 02:32 PM
MikeMoore's Avatar
It should be noted that if I put the green and purple together I can release the key
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-8th-gen-discussion/334186-2009-impala-lt-stuck-in-park.html
Guidelines in Selecting an Escort Girl in London This thread Refback 09-09-2014 02:19 PM
Planning to Get an Escort Service in London?-Here?s Some Vital Methods to Take Note This thread Refback 09-09-2014 02:19 PM
About to Have an Escort Service in London?-Here?s A number of Vital Methods to Consider This thread Refback 09-09-2014 02:18 PM
Facts to consider When In search of an Escort Girl in London This thread Refback 09-09-2014 02:17 PM
What You Need to Learn in Hiring an Escort Girl in London This thread Refback 09-09-2014 02:17 PM
Suggestions in Selecting an Escort Girl in London This thread Refback 09-09-2014 02:16 PM
Ways to Pick an Escort Girl in London This thread Refback 09-09-2014 02:16 PM
Suggestions in Selecting an Escort Girl in London This thread Refback 09-09-2014 02:15 PM
Facts to consider When Searching for an Escort Girl in London This thread Refback 09-09-2014 02:15 PM
The way to Pick an Escort Girl in London This thread Refback 09-09-2014 02:14 PM
Ways to Select an Escort Girl in London This thread Refback 09-09-2014 02:14 PM
What You should Know in Employing an Escort Girl in London This thread Refback 09-09-2014 02:13 PM
Guidelines in Picking an Escort Girl in London This thread Refback 09-09-2014 02:13 PM
Considerations When Looking for an Escort Girl in London This thread Refback 09-09-2014 02:12 PM
How to Select an Escort Girl in London This thread Refback 09-09-2014 02:12 PM
Various Things to Consider in Employing an Escort Girl in London This thread Refback 09-09-2014 02:11 PM
EquinoxForum.net: Hitting something solid when shifting into Park This thread Refback 04-08-2014 09:03 AM
TerrainForum.net: Hitting something solid when shifting into Park This thread Refback 04-08-2014 09:01 AM
2007 impala 3.9 key stuck in ignition stuck in park dalejrfan88 Chevy Impala 8th Gen Discussion 11 01-11-2016 12:01 PM
Help! 08' impala stuck on park.. White_Pala08 Autocare and Maintenance 13 10-21-2013 04:28 PM
Stuck in Park? Here's what to do. Randal Chevy Impala 8th Gen Discussion 1 02-28-2011 02:54 PM
1957 Chevy Bel-Air stuck in Park? Rick G Chevy Bel Air 0 02-26-2008 09:39 PM
