ABS light reset? - Chevy Impala Forums
post #1 of (permalink) Old 11-09-2012, 01:33 PM Thread Starter
NO LIFT's Avatar
ABS light reset?
My ABS light it on.
Found connector at LR wheel hub bad, replaced.
ABS light still on.
Thinking optomistically that the code is in memory, and just needs reset...but how can I reset the ABS light?
NO LIFT is offline
post #2 of (permalink) Old 11-09-2012, 01:43 PM
auntjemima's Avatar
Need a code reader that can reset BCM codes (pretty sure abs is considered a BCM component however I might be thinking of airbags, either way, you need a reader that can read and reset codes).
auntjemima is offline
post #3 of (permalink) Old 11-09-2012, 02:23 PM
463
463's Avatar
If the ABS light is still on then there is still a problem. Dis connecting the battery will reset . The ABS system will go into self test each time the car is started and drives a short distance, if the system read clear the abs light will not come on till the next time a fault is detected.
I would take a good look at the rest of the wires and see what else may be messed up.
Welcome to the forum
463 is offline
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-8th-gen-discussion/333776-abs-light-reset.html
How do you reset the trac off and abs light on a 2000 impala? - Find Answers Here! This thread Refback 10-24-2016 10:49 PM
How do you reset the trac off and abs light on a 2000 impala? <- Find answers here! This thread Refback 01-20-2015 11:15 PM
how do you reset oil light WITH AFTERMARKET DECK??? MXZ1983 Chevy Impala 7th Gen Discussion 53 03-28-2013 08:13 PM
How do you reset security system light? Hersbird Chevy Impala 8th Gen Discussion 5 05-03-2011 05:28 PM
2004 impala low tire pressure light on-how to reset? justin D Chevy Impala Discussion 0 06-23-2008 12:03 PM
How do I reset the serive engine soon light in a 02 chevy impala? rebel_slash_hippy Chevy Impala Discussion 2 03-23-2008 06:36 AM
How do I reset the Change Oil light on my 2002 Chevy Impala? silverdaleprices Autocare and Maintenance 2 09-10-2007 09:24 AM
