Key Stuck in Ignition - Won't turn to OFF - Chevy Impala Forums
Old 10-08-2012, 09:04 AM   #1 (permalink)
Orioles's Avatar
Hey guys, I have a 2007 Impala LS and the key is stuck in the ignition. I can't get the key to turn to OFF; it stays stuck in ACC mode and runs down the battery. Any ideas how to (1) get the key out and (2) fix the problem?
I am wondering if the problem lies either in the floor console wiring or the solenoid right next to the ignition tumbler. I found this related thread and the poster mentions pulling the plunger of the ignition cylinder solenoid to get key out of ignition.
key stuck in ignition - 2006-2013 General Discussion - NAIOA
Can I push solenoid plunger without taking steering wheel column trim off? There is a torx screw and some other pin-type thing holding the steering wheel column trim together. I got the torx screw out but can't get the other thing out! Any ideas how to get it out?
Any help is appreciated. Thanks so much.
Orioles is offline   Reply With Quote Quick reply to this message
Old 10-08-2012, 01:03 PM   #2 (permalink)
Orioles's Avatar
ImageShack® - Online Photo and Video Hosting
Here is a link to the picture. I'm trying to get this out so I can take off the steering wheel column trim cover, but I don't know what this is or how to get it out.
Old 04-02-2013, 01:15 PM   #3 (permalink)
systemcheck2006's Avatar
Im sure this has been fixed already but for future use try this.
http://www.impalaforums.com/diy-how-...ition-fix.html
then you'd be normal."
systemcheck2006 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to systemcheck2006 For This Useful Post:
Orioles (04-04-2013)
2007 impala 3.9 key stuck in ignition stuck in park dalejrfan88 Chevy Impala 8th Gen Discussion 11 01-11-2016 01:01 PM
key stuck in ignition wink4life Chevy Impala Discussion 15 11-25-2013 02:07 PM
key stuck in ignition cylinder..HHHEEELLLPP!!!! lopez Chevy Impala 7th Gen Discussion 8 09-30-2009 05:10 PM
Stuck ignition lock cyliner Michelle03 Impala 1st - 5th Gen Discussion 0 04-20-2008 01:28 PM
