2012 tpms - Chevy Impala Forums
post #1 of (permalink) Old 09-14-2012, 08:22 PM Thread Starter
volume's Avatar
2012 tpms
Can some one tell me that this is true ??
service procedures have changed on new cars. GM is doing away with the ability to reset the system by dropping or adding pressure to each wheel. they want to make it so you take the car to the dealer for everything. however, for people that still want to perform tire rotations at home, they came out with the tool listed.
the magnet trick only works on a few cars, including the corvette and cadillac Deville, and maybe a few others. air pressure change will not work on new cars, i know 2012 and up. not sure on 2011's. you will have to try and figure out if it works. we use TPM reset tools, which can be purchased from kent moore, or napa, or any tool company. most cost around 200-700 depending on model and features.
https://gmspecialservicetools.spx.co...s.aspx?id=5677
the one listed used to be 43.00 and has gone up in price recently. probably because of high demand.
you can enter the relearn mode on the impala by putting the ignition to the accessory position, and pressing and holding the lock and unlock buttons on the key fob. you will hear 2 audible horn beeps, and then the system is in learn mode. then start at left front, then move to right front, then right rear, then to left rear. when each tire is learned, the horn will beep, and after the system has been relearned it will beep twice. turn the key off, and start the vehicle. no TPM light should be on.
you will need to place the antenna of the TPM tool on the tire by the valve stem, or at the tip of the valve stem, depending on the tool.
or option 2 is the use of the tech 2/tech 2 win. listed under RCDLR special functions/TPM relearn mode.
or option 3, the dealer can reset it for you. usually does not cost anything to do this, as it can be done easily and quickly.
volume is offline
post #2 of (permalink) Old 09-17-2012, 08:54 AM Thread Starter
volume's Avatar
volume is offline
post #3 of (permalink) Old 09-17-2012, 10:34 AM
Back in Black
12ltz's Avatar
nice to know, Thanks
_________________________
2012 Impala LTZ 72,000 miles
12ltz is offline
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-8th-gen-discussion/330833-2012-tpms.html
2012 tpms - Chevy Impala Forums This thread Refback 09-14-2012 10:45 PM
Using 06ss rims on 04ls.. tpms ? mltno Chevy Impala 7th Gen Discussion 1 03-12-2012 11:49 AM
TPMS advice C.E.Divine Wheels and Tires 16 02-16-2012 04:33 PM
re: TPMS issue, not sure if related to the TSB CubSmurf Chevy Impala 8th Gen Discussion 10 08-03-2011 10:51 AM
is it bad to change rims and not tpms jess Wheels and Tires 21 07-04-2011 01:57 PM
TPMS Rebuild Kits? Domo85 Wheels and Tires 4 12-28-2009 04:58 PM
