| Chevy Impala 8th Gen Discussion W-Body 2006, 2007, 2008, 2009. Discuss all Chevy Impala 8th Generation Performance and Technical Discussion here. |
Annoying squeak
My car has an annoying squeak that is coming somewhere form the door trim in the back, or somewhere else in the back. The car is an '09 Impala LTZ with fairly stiff suspension and 18 inch wheels. Every time I hit a minor bump or imperfection in the road, I hear a squeak. The worst thing is that it comes and goes. Sometimes there is no squeaking for several days, then it comes back with a vengeance. Any ideas? Anybody has experienced something similar on their SS or LTZ?
I lubricated all the door rubber seals with silicon spray, to no avail. |
| Sponsored Links | |||
Advertisement | |||
you are not the only one. it always happens on those bumpy roads and it annoys me. My solution was the passenger rear window. if i had it down all the way, it would squeak. If I had it up it wouldn't. Also, do you get a vibrating noise on your passenger seats? I do.. and i can't really pinpoint it, it happens when no one is sitting there only.
__________________ Anyone From The NYC Area? Lets Meet Up.06 Impala LS |
#3 (permalink) |
Z71 & imandyyornot, please direct message me anytime if you'd like me to check for recalls on your Impalas or set up appointments for you at a dealership! I realize, though, that you're most likely interested in DIY assistance from other owners, so I hope the community replies soon with their trademark helpfulness.
Katie Chevrolet Customer Service |
#4 (permalink) | |
I have no vibration in the passenger seat, or anywhere else at any speed. My car has very good quality tires, the same as came on the SS model. It has been my experience with other cars over the years that the vibration in the passenger seat is usually caused by improperly balanced front tires, or out of round front tires. Interestingly enough, we have an '07 Impala LS office vehicle at work. I have never heard any squeaks out of that one. The suspension is a bit softer than on mine though. Last edited by Z71; 07-20-2012 at 08:29 PM.. |
#5 (permalink) | |
#6 (permalink) | |
@Katie : I will be removing the passenger seats soon and check it out instead. Thanks. __________________ Anyone From The NYC Area? Lets Meet Up.06 Impala LS |
#8 (permalink) | |
Where exactly did you shove that sock? |
#9 (permalink) |
Well, I think I found the source of the annoying squeak. And it was so simple! The squeak suddenly turned into thumping noise whenever I hit a bump. I checked the spare tire in the trunk and the hold down bolt was loose. I tightened the bolt and the noise is gone - so far. I was convinced that the sound was coming from inside the passenger compartment. But this squeaky noise makes sense- it was tire rubbing against the metal when moving slightly.
#10 (permalink) |
Back in Black
Thing always sound so simple when you find the problem but getting there can be a bit*h. Good find.
__________________ _________________________ 2012 Impala LTZ 2002 Buick Regal LS 335,000 miles 2000 Buick Regal LS 182,000 miles 1998 Olds Silhouette 3.4V6 177,000 miles 1996 Olds Cutlas 3.1V6 293,000miles Too many freaks, not enough circuses. |
#12 (permalink) |
Well, it turns out that I was wrong about the spare tire, the squeak came back. The good news is that after a few minutes of looking I found the squeak source and positively reproduced the annoying squeak. The problem is the left trim piece that fits over the roof pillar around the rear window, right next to the parcel shelf. The edge of that trim piece is loose and when I wiggled the edge, I got the annoying squeak, exactly like I have been hearing whenever I hit a bump. The simplest solution appears to be stuffing a small towel or something like that under the trim piece. I am not sure if some tab is broken or what, but the corner should not be that loose. The trim piece on the other side fits more firmly and does not squeak. I am glad I found the source of this annoying problem.
#13 (permalink) |
There is a metal clip on the trim panel that was not fully pushed in, so it did not lock. It was that clip that was making the annoying squeaking noise. I hit the panel with my hand lightly and the clip seated fully. Problem solved.
| Sponsored Links | |
Advertisement | |
| Top Ten Most Annoying Groups Of Car Owners | NotAWimpyImpy | Automotive Discussion | 68 | 11-07-2011 05:41 PM |
