08 impala cabin fan blower motor noise - Chevy Impala Forums
post #1 of (permalink) Old 12-18-2011, 07:51 AM Thread Starter
tommymac23's Avatar
Question 08 impala cabin fan blower motor noise
ok, my impala is 4 and 1/2 years old and has 73,000 miles
my heat/ac air blower fan has gotten pretty noisy lately
it still blows normal amount of air/ controlled well/ on/off normally , fan speed controlled normally/defrost normal
if the fan is OFF, no noise, however, even if the fan is just turned to 1, i hear a slight humming/subtle vibration
its like one second hum the next silent
its like hummmm........ hummmm ...... hummmm....... huummmmm
i only hear it if it is quiet ... if the radio is on / moderate highway noise, i dont hear it (it is not very loud/not very obvious)
do you guys think its time to change the blower motor/resistor ??
there is no debris... i change the filter every 8,000 miles and i keep the air intake area very clean
let me know what you think.. thanks for reading
tommymac23 is offline
post #2 of (permalink) Old 12-23-2011, 02:26 PM
dalejrfan88's Avatar
Hi i just fixed some noise i had from my 07 with 66,000 miles. In my case my humm was also on level one and it was comming form the passenger side vent (farthest right on dash) I thought it was the cabin air filter so i changed and shook out the debris. It still made noise. I then went under the glove box. you will see some black plastic shrouding and inside some foam which lines it. In my case i moved the foam around and got the noise to stop completely. I think it was blocking the blower vent partially. Im not sure if this is the same noise you are hearing however. Mine only came from that side of the car. Hope this helps a bit
dalejrfan88 is offline
Blower motor kmad61 Chevy Impala 8th Gen Discussion 0 07-08-2011 04:35 AM
blower motor doesnt turn off 04impalaman Chevy Impala 7th Gen Discussion 3 12-09-2010 10:41 AM
Blower Motor Problem...PLEASE HELP impala04ss Automotive Discussion 0 12-25-2009 08:59 AM
Blower motor no workee kingnutin Chevy Caprice 9 07-02-2009 02:35 PM
1996 Olds 88 blower motor? kobascle Automotive Discussion 0 09-07-2007 02:46 AM
