Problems With Remote Start - Chevy Impala Forums
post #1 of (permalink) Old 12-03-2011, 12:56 AM Thread Starter
Black06SS's Avatar
Go figure, a week after owning my SS and I have this problem. It actually started on me the night I got home from the dealership, but the car doesn't have a warranty so I should have expected they would tell me they couldn't do anything.
Anyhow, the remote start worked twice for me the day I bought it. Then it all of a sudden decided to stop. I lock the car as it states in the manual and then hold down the top button on the key fob as stated. The lights on the car flash, but that is all. Before the lights would flash, the fuel pump would prime and the car would start up.
The other day I went out to see if it would work and it started right up. I don't know what it could be. I'd like some of your input before I take it to the Chevy dealer by me. Thanks for the help in advance guys!!
-1998 Chevy Silverado 4x4
-2010 Harley Davidson 48
-2006 Chevy Impala SS w/ 237,000 miles & still climbing --- Sold
-2006 Chevy Impala SS --- Sold
Black06SS is offline
post #2 of (permalink) Old 12-03-2011, 11:50 AM
463
463's Avatar
push the lock button on the fob 2x. then push and hold the start button. should work.
Welcome to the forum
463 is offline
post #3 of (permalink) Old 12-03-2011, 12:27 PM
SPARTAN sui's Avatar
Yep, I have this issue every now and then. I can sit there from 5 feet away, lock the doors twice, only get the lights to flash and get nothing. So I hop in the car and it starts right up. It bugs the crap out of me. Oh, and the horrendous range sucks.
2007 Impala SS traded for 2011 Camaro 2LT
SPARTAN sui is offline
post #4 of (permalink) Old 12-03-2011, 03:17 PM
805_IMPALA_SS's Avatar
ya every once in a while mine doesn't wanna start either
805_IMPALA_SS is offline
post #5 of (permalink) Old 12-04-2011, 05:27 PM
pkazsr's Avatar
Replace the battery in the remote. Cheaper than a visit to the stealer. (Dealer)
pkazsr is offline
post #6 of (permalink) Old 12-05-2011, 08:04 AM
TSS
TSS's Avatar
Quoted: 24 Post(s)
Range simply sucks. I have had a myriad of new remotes with new batteries and the range sucks. More sucky in the winter than summer for some odd reason.
2009 Impala SS (sold 3/2012);
2014 Impala Limited LTZ
2010 Buick Enclave CXL;
TSS is offline
post #7 of (permalink) Old 12-05-2011, 01:38 PM
SStuntin on em
WallyLO's Avatar
there may be more to it if the lights flash like when it starts, but no start.
WallyLO is offline
post #8 of (permalink) Old 12-07-2011, 02:55 PM
johnniep's Avatar
my factory remote i have to press the lock button on mine sometimes and then press the start button and it's fine....only does it sometimes......sometimes you have to be close to the car ....sometimes it will work 40 to 80 ft... often wonder if the dealer has to reload the software for it......i know they load when the purchaser buys it new.....my monte has an aftermarket start but i stopped using it because it sometimes locks you out for 10/15 minutes
2006 Impala LT, 2002 Monte Carlo SS, 2002 Pontiac Gran Prix GT
johnniep is offline
post #9 of (permalink) Old 12-08-2011, 07:35 AM
OHSIXSuperSport's Avatar
There was a TSB about this.
Mine was under warranty, but they replace recievers, antenna, the wire running to your antenna, and your fobs. I think the whole job is $800ish out of pocket.
A good way to know if you have will have issues is turn your FOB over. If you see a triangle with a little star in it, (next to where it says details) then you have had the job completed.
OHSIXSuperSport is offline
post #10 of (permalink) Old 12-27-2013, 11:16 AM
spickard's Avatar
I drive a 2011 Impala and I've found that after being remote started the car shuts off after 10 minutes so I often end up starting it multiple times to get it warm enough. It seems that after starting it remotely twice it will stop working, even if it's been hours or days since the last remote start. I can then start it manually and the remote starter will work two more times. I haven't found anything to corroborate this but this could be some kind of "security" feature.
spickard is offline
post #11 of (permalink) Old 12-27-2013, 11:34 AM
Quoted: 22 Post(s)
^ Spickard, your remote start is functioning normally.
post #12 of (permalink) Old 12-27-2013, 09:10 PM
Ilgoose's Avatar
What Sheila said...that's exactly the way it's supposed to work.
2013 Impala LTZ
Ilgoose is offline
post #13 of (permalink) Old 12-27-2013, 10:09 PM
spickard's Avatar
That's what I thought but that could be the reason that some people's remote starter doesn't seem to be working sometimes. I don't suppose anyone knows if there is any way to change or deactivate either of these features so it will stay on longer or start more than twice.
spickard is offline
post #14 of (permalink) Old 12-28-2013, 08:44 AM
Harley fanatic
gearhead's Avatar
if there is a code stored it will not remote start. not all codes set the cel light.
2006 Impala 2LT 3.5 auto
2003 Silverado 2500HD 6.6 duramax 6 speed manual
2002 Impala LS 3.8 auto SOLD
2010 Impala 2LT 3.5 auto
2002 Harley FLHTCUI Ultra
1998 Harley FXDWG Wide glide 95th anniversary
1982 Harley FXB Sturgis
PGR Rider
gearhead is offline
post #15 of (permalink) Old 12-29-2013, 01:57 AM
Quoted: 240 Post(s)
What you can do to make it run longer is remote-start it twice in a row. Once it's already remote-started, just do the remote start process on the keyfob again - the lights will blink to acknowledge that you have "stacked" two remote starts, so the car will stay running for 20 minutes.
Chevrolet : Impala LT REMOTE ST 2010 IMPALA LT REMOTE START 100K WARNT Y-BUY NEW@$134 RSS Bot eBay Cars For Sale: Impala 0 02-12-2011 12:00 PM
Factory remote start aftermarket alarm remote programing daphatom Chevy Impala 8th Gen Discussion 0 09-10-2010 05:47 PM
06 LT Remote Start nick8519 Chevy Impala 8th Gen Discussion 0 02-11-2010 06:57 PM
Remote Start Up 73impala Chevy Impala Discussion 2 11-21-2008 03:15 PM
how do you program the remote keyfob for a 2007 impala with remote start...I've trm420 Audio, Video, and Electronics 0 09-26-2007 09:52 PM
