Rear power door locks failed on 08 - Page 2 - Chevy Impala Forums
post #16 of (permalink) Old 01-02-2011, 06:31 PM
77Impala's Avatar
Quoted: 8 Post(s)
Originally Posted by bbtkd View Post
they sure should not be failing at 65-70k miles.
Has anyone figured out why these things are failing that soon? I am wondering if it is an alignment issue, lack of internal lubrication, or if they are just plain cheaply made.
1977 Chevrolet Impala Sedan
1989 GMC C1500 Sierra ECSB
77Impala is offline
post #17 of (permalink) Old 01-03-2011, 03:23 AM Thread Starter
bbtkd's Avatar
After having replaced one of three failed ones my vote is "cheaply made", though alignment of the convoluted lock shaft could be part of it. I wonder if they've made any design changes, or are they happy for the repeat business?
bbtkd is offline
post #18 of (permalink) Old 01-03-2011, 07:32 AM
rangel515's Avatar
I hope that GM has a recall for this issue. its kind of a safety issue IMO.
rangel515 is offline
post #19 of (permalink) Old 01-03-2011, 03:52 PM Thread Starter
bbtkd's Avatar
I'll bet this is not considered a safety issue since you can still lock and unlock manually, therefore there wouldn't be a recall. Sure hope we're not looking at replacing these every 3-4 years. I've never had one go out any any other car I've owned in the last 30 years.
bbtkd is offline
post #20 of (permalink) Old 01-21-2011, 01:15 PM
the stig's Avatar
Right I have one out and my drivers door is not intermittent, Gm needs to do an recall or at least make the parts cheaper. We should make a letter and send this to gm....
the stig is offline
post #21 of (permalink) Old 01-22-2011, 01:03 PM
awolfinwater's Avatar
Thanks for the great writeup
BBTKD,
I really appreciate the writeup. My passenger front door lock exhibited the same symptoms. I couldn't find an aftermarket part so I just shed out 184.87 at the dealership for the part that is not in stock.
When it arrives this week, I'll try to get back and let you know how the install goes.
Thanks again.
awolfinwater is offline
post #22 of (permalink) Old 01-30-2011, 09:48 AM
wde3477's Avatar
Already have had two fail - driver rear and passenger front. Bought both, replaced the driver rear first since it's a pain to reach - after that ordeal, hesitant toward tackling the passenger front until I have another surplus of ambition and free time.
Really tics me off failing so early. 'Made in Mexico' said it all. Wasn't happy to see all the plastic clips and what not involved with the assembly.
Paid $166 for one and $176 for the other - not sure which was which.
Love the car as a whole, but hate the reliability of some pieces-parts. So far - two power door lock assemblies, one power mirror switch, and one evaporative purge solenoid. Begs the question of what rate of failure will be experienced down the road?
2008 LTZ - 209,000 miles - SOLD
1981 CJ-5 - 171,000 miles
1989 F150 - 217,000 miles - SOLD
2014 F150 - 8,000 miles
wde3477 is offline
post #23 of (permalink) Old 02-19-2011, 08:32 AM
Abner0322's Avatar
Common Problem
Thanks for the info bbtkd. I have the same problem. Right rear door actuator went out at 30,000 miles, repaired under warranty. Now the left rear has gone out at 40,000 miles. No longer under warranty, so I will attempt to fix it myself. Having serious reservations about GM products. Also had electrical problems with 2001 Impala.
Abner0322 is offline
post #24 of (permalink) Old 02-21-2011, 04:24 AM Thread Starter
bbtkd's Avatar
I just picked up the actuator for the left rear and will be installing it in two weeks when my daughter is home. Then I'll do the right front later.
bbtkd is offline
post #25 of (permalink) Old 02-21-2011, 07:03 AM
rangel515's Avatar
does anybody have a picture of the actuator? i found a junked 07, maybe i can pull that part out for cheap
post #26 of (permalink) Old 02-28-2011, 05:00 PM
Joe Clymer's Avatar
Thanks for the help!
I'm new to the forum and found it by searching for door lock actuator replacement. I just wanted to thank bbtkd for the detailed instructions on how to replace. It was a great help. I do appreciate it very much! Saved me some $$$
Joe Clymer is offline
post #27 of (permalink) Old 03-01-2011, 09:54 AM
rangel515's Avatar
Car Door Lock Actuator - Auto Parts Warehouse
found this..............is this the part that we need?
post #28 of (permalink) Old 03-01-2011, 11:29 AM
thacarter546's Avatar
Wow dont pay that. You can get a universal set of 2 for around 25-40 bucks depending on brand. And those are really reliable.
Dont replace a faulty design with a faulty design. I'm having to fix this on my moms. The rear door handles are also not working.
thacarter546 is offline
post #29 of (permalink) Old 03-01-2011, 09:45 PM
rangel515's Avatar
where at?^
post #30 of (permalink) Old 03-07-2011, 08:32 AM
Joe Clymer's Avatar
I used the GM actuator. Very pricey but the lock is and the cable for the inside handle is mounted to it and I couldn't figure out how to mount a universal. You might want to go to a GM dealer and look at one before you try the universal.
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-8th-gen-discussion/269007-rear-power-door-locks-failed-on-08-a.html
What is 2006 CHEVY IMPALA DOOR LOCK PROBLEMS? This thread Refback 09-02-2013 07:57 AM
2005 Impala Rear Door child Safety Locks engineerbll Chevy Impala 7th Gen Discussion 17 03-21-2011 09:24 AM
Chevrolet : Impala LT LT 3.5L Power Steering Power Brakes Power Door Locks RSS Bot eBay Cars For Sale: Impala 0 11-09-2010 04:40 PM
Chevrolet : Impala 3.4L CD Power Steering Power Door Locks Power Windows RSS Bot eBay Cars For Sale: Impala 0 09-15-2010 12:40 PM
Chevrolet : Impala We Finance! LT Certified 3.5L Power Door Locks Power Windows MP3 RSS Bot eBay Cars For Sale: Impala 0 09-04-2010 05:30 PM
Chevrolet : Impala 4dr Sdn LS 4dr Sdn LS 3.5L CD Power Windows Power Door Locks Clock RSS Bot eBay Cars For Sale: Impala 0 09-02-2010 10:30 AM
