Rear doors don't open - Chevy Impala Forums
post #1 of (permalink) Old 03-15-2010, 12:14 AM Thread Starter
Pheonyx's Avatar
Ok, so I have a 2007 Impala, and both rear doors will not open. First, my rear passenger door had this issue maybe about a year ago. Didn't seem like an issue at all. Friend got out of the car and tried to close the door, and it wouldn't shut. The latch wouldn't catch, so I locked my doors and closed it. It all seemed fine until I unlocked my car and the door just wouldn't open. I thought all was fine until 2 weeks ago, because I could live with 1 working back door. My rear driver side door did the same thing! I listened closely to it, and the latch isn't lifting or anything. Like I try to open the doors from both sides and the handle will lift, but it just won't catch I guess. I'm out of town till wednesday. So I'm hoping I get some good answers before then, if not I'm taking it to the dealer to get fixed.
Pheonyx is offline
post #2 of (permalink) Old 03-15-2010, 02:28 PM
91ltz's Avatar
I doubt this is the problem, but the earlier caprices have a lever on the edge of the rear door which let's you keep the doors from opening from the inside. You can still open from the outside. I think it was for child safety.
91ltz is offline
post #3 of (permalink) Old 03-15-2010, 06:49 PM Thread Starter
Pheonyx's Avatar
Ya, that wouldn't be the problem, it won't open from out or in
Pheonyx is offline
post #4 of (permalink) Old 06-22-2010, 02:16 AM
Laurie's Avatar
Did you figure out what was wrong with your door? I have an 07 Impala LTZ and both of my rear doors are stuck shut. One went then soon after, the other. Its not the child safety or door locks. A friend removed the inside panel and put his hand inside and could open the door. There is a rod/wire connecting the inside to the outside door handles and it seems like that is disconnected or stretched. I dont want to go to the dealer to have it fixed. This seems to be a common problem with newer Impalas. I wonder if there will be a recall?
Laurie is offline
post #5 of (permalink) Old 06-22-2010, 01:17 PM
I had this happen on an 07 here at work, it was the driver door. Couldn't figure out the problem for the life of me, and it was random to boot. Eventually I said to hell with it and replaced the latch, haven't had an issue since.
post #6 of (permalink) Old 06-22-2010, 05:24 PM
rkvette's Avatar
i had same problem with my 2008 ss impala.. gm dealer took apart and said needs door activator ? of course did not have in stock ,but got it in 3 days...gm replaced and worked fine ever since, shop tech said see lot of these fail.. best thing, was no charge !! i would do same with yours ..it's not the first one to go bad,maybe no charge? good luck.. rkvette
rkvette is offline
post #7 of (permalink) Old 06-30-2010, 04:47 PM
rangel515's Avatar
fuck....im another victem only one that does work is tha passenger side....all the rest have to be manually opened.....
rangel515 is offline
post #8 of (permalink) Old 07-16-2010, 09:03 PM
rangel515's Avatar
So is it the "activator" on the driver side door that controls evrything?????
Im wondering if installing an aftermarket alarm system will get rid of this problem?????
Someone please help me out??????/
post #9 of (permalink) Old 07-16-2010, 09:28 PM
Quoted: 14 Post(s)
Moderator, please!!! Censor this. TYIA
Shop for Impala Parts:
www.basilonestopshop.com
donmateo is offline
post #10 of (permalink) Old 03-06-2011, 09:04 PM
rogermmj's Avatar
rear door wont open
I have a 2000 impala the the door locks works but from the inside or out sice it wont open. can the door panel come off even with the door closed . any suggestions please let me know
rogermmj is offline
post #11 of (permalink) Old 03-06-2011, 11:05 PM
rangel515's Avatar
what^
post #12 of (permalink) Old 03-07-2011, 05:46 AM
rogermmj's Avatar
The door locks work open and close . But i cant open the rear passanger door for the inside or outside. Can the door panel be taken off even if tthe door is closed ? any othere sugestions
rogermmj is offline
post #13 of (permalink) Old 08-05-2013, 06:52 AM
Dawnfoy's Avatar
Just bought an 06 impala LS for my daughter and same issue came up after about a week...one rear door then the other. Was hoping there was a recall on it since it seems to be a major safety issue. Can't afford to pay a dealer for an expensive fix.
Dawnfoy is offline
post #14 of (permalink) Old 12-20-2014, 07:49 PM
Lynnaf's Avatar
I have an '06 Impala LTZ and both rear doors wouldn't open. My friend, who is a mechanic beat on the outside of the passenger door and it opened, but I can't get the driver rear open. Did anyone find out if this is an actual regular problem with the Impala's?
Lynnaf is offline
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-8th-gen-discussion/242760-rear-doors-don-t-open.html
Rear Door - Blogs, Pictures, and more on Blogged This thread Refback 04-15-2010 12:14 PM
Rear passenger side door won't open uniball Chevy Impala 8th Gen Discussion 38 07-10-2014 06:30 AM
2007 LTZ rear doors wont open grrr........... Laurie Automotive Discussion 3 06-22-2010 02:06 AM
Doors. Will they fit? Systematic Chaos Impala 1st - 5th Gen Discussion 3 11-22-2009 01:46 PM
65 Impala SS Convertible - DOORS?? Randy&Ginger Restoration Forum 0 05-03-2009 02:20 PM
Doors alwyswntd1 Chevy Caprice 6 03-27-2009 01:50 PM
