| Chevy Impala 8th Gen Discussion W-Body 2006, 2007, 2008, 2009. Discuss all Chevy Impala 8th Generation Performance and Technical Discussion here. |
Clicking When I Turn
When ever i turn a corner or the car in general i hear a loud clicking noise and it only happens when i hit the gas while turning. I assumed i needed an alignment but after i got the alignment it kept clicking when i turned. Any suggestions on what it might be.
BTW, Im in an 06 Impala SS
Sounds to me like you have either a cv joint (halfshaft/axle), going bad or it could also be a front wheel bearing. One of these is the culprit in 99% of the front clicking noises if it is a constant rate click when you are turning.
#3 (permalink) |
thanx...i just hope its not gonna cost an arm and a leg to get it resolved cuz it bugs the crap outta me.
Have you visited the Impala Forums Store today? Thousands of cars & parts for sale! Last edited by esmiling; 03-11-2010 at 08:00 AM.. |
#4 (permalink) | |
CV is about $70 from Oreilly, wheel hub is about $100 for the cheap one. You can visually inspect the half shafts from under the car with a jack. You'll know if it's blown. there'll be grease slung everywhere.
__________________ ![]() Quote:
#5 (permalink) |
Ill Be Sure To Inspect Then Post The Results.....GREATLY APPRECIATE THE INFO.
Have you visited the Impala Forums Store today? Thousands of cars & parts for sale! Last edited by esmiling; 03-11-2010 at 12:17 PM.. |
#6 (permalink) |
It may be the intermediate steering shaft. I too have an '06 SS and the steering clicked at low speeds like parking. I believe there is a TSB about this, apparently there are not greased enough from the factory and can "go dry" hence the clicking from metal on metal wear. I had it replaced under warranty. Same thing happened to our Aura too and was replaced under warranty.
__________________ '05 GTO -SLP LT, SW Cat back, Hard Core CAI, B&M Ripper, 160 T-stat, SLP skid plate-Cartek reflash, ported TB. '06 Impala SS -K&N Panel filter '08 Saturn Aura XR -K&N Panel Filter |
#7 (permalink) |
I inspected underneath and no oil. Im going to assume its the steering shaft. Got an appt wit the dealership to look at it so lets see what they say. Prolly a bunch of BS.
#8 (permalink) |
Let us know what happens, I am curious to know. I have to remind myself on my next oil change to snot the ISS up a little with more grease just in case. While you're at the dealer you may want to address the power steering hose service bulletin, I have yet to schedule that one.
#9 (permalink) |
I would like to know what it is too, I have an 06 3.5 here at work that is doing the same thing. I thought it was the driver CV, I replaced it, it was in poor shape, but the click is still there. It doesn't seem to be the ISS either, not 100% on that one though. It isn't the wheel bearing, I was able to listen close enough to determine that it was somewhere in the region of the steering rack. I would sure like to have it figured out, like I'm sure you feel as well
![]() __________________ 1978 Caprice Classic Landau 350 2-bolt, stock 4bbl Stock rebuilt TH350 Edelbrock performer cam + intake Dual Flowmaster exuast with hi-flow cat (waiting to be installed) Edelbrock IAS Classic shocks 2.41 Open carrier performance! (95 9C1 3.08 waiting to be installed!) 16x8 American Racing Baja's with 225/60/16 Pirelli P5's Panasonic CD player with all Polk speakers 2-4x6, 2-6x9, 2-12" on alpine 4 channel (till I get my other amp fixed). |
#10 (permalink) | |
King, can you feel it in the steering wheel?
#11 (permalink) |
Kinda, but it's a click. Higher frequency noise than a clunk. So yeah, you can kinda feel it. It sort of feels like there is a piece of plastic trying to stop the wheel from turning. It will only do it with the suspension loaded, jack the front end up and its gone. It reacts more to back and forth motion than anything else too.
#12 (permalink) | |
Check your cradle bolts for proper torque and inspect your sway bar bushings and ball joints.
#13 (permalink) |
Amazing. The same thing is happening on the '72 Chevelle. Whenever I take a right-hand turn it starts clicking. More than "clicking" I can feel it - like someone is tapping pretty decent with a hammer on the control arm.
__________________ Justin ![]() Get your T-Shirts/Decal Sets & Premium Memberships here. PS - Do you know about the new site features? |
#14 (permalink) |
It sounds like the ISS to me. Mine went bad around 33k on my 07 SS. It seems to be a frequent problem. Mine could be felt just turning the wheel while parked. Service manager knew exactly what was the problem.
| Clicking noise when I turn the steering wheel.. What could it be? 2003... | K.M. | Mechanical and Electrical Problems | 1 | 04-29-2010 02:02 PM |
| Something broke on turn signal lever? Turn light won't turn off | sswodawg81 | Chevy Impala 6th Gen Discussion | 0 | 11-02-2009 01:19 PM |
| Clicking sound coming from distributor? | badcompany87 | 1st - 5th Gen Engine Performance | 5 | 08-09-2009 08:14 PM |
| have a 2000 chevy impala clicking noise in front when i turn the wheel its not | Robert C | Chevy Impala Discussion | 2 | 07-08-2008 11:20 AM |
| My 03 Impala is in the shop for a clicking noise that seems to be coming | K.M. | Mechanical and Electrical Problems | 0 | 09-03-2007 06:23 PM |
