HIDS and DRL Problems - Chevy Impala Forums
Old 11-23-2009, 02:06 PM   #1 (permalink)
Impala08's Avatar
Hey, Im new to the forum and in need of some help!
I tried searching and I think the problem has to do with the DRL. I recently installed a set of hids in my 08 Impala. Their wired to the battery, 2 relays, 2 fuses, and Im using the pass headlight to trigger the coils.
When I start my car in my garage the hids turn on normally, but when i back out into daylight they turn off. If I turn off the car and turn it back on everything is normal (outside). Everything also performs normal if I start the car outside. Ive looked into the DRL harness for $75 but I would like to do that as a last resort if possible. Hopefully somebody can shine some light on the situation. Thanks for your time.
Impala08 is offline   Reply With Quote
Old 11-23-2009, 03:17 PM   #2 (permalink)
1CL3ANSUP3RSPORT's Avatar
Don't RUN your HIDS in the daytime,you'll kill them quicker.I always turn my off and run my fogs durning the day.
Blackkbox 8K H11 is what I have
1CL3ANSUP3RSPORT is offline   Reply With Quote
Old 11-29-2009, 05:04 PM   #3 (permalink)
jdubb1's Avatar
hid
I guess I'm not getting what the problem is?? Are u wanting to run your hid's in the daytime?? Can't you just manually overide them using the headlight switch?? The car has a sensor whitch switches the headlights off in the daytime and uses your drl, which if you have hid's is a no-no. Drl dont use enough power, therefore can ruin your hid's. You can manually overide the drl everytime, or just pull the fuse, like i did, and they will never come on. Let me know if this was what the problem was, or maybe I just didn't get it.
Jerimy
jdubb1 is offline   Reply With Quote
HID Problems ImpalaMan80 Mechanical and Electrical Problems 10 04-15-2011 05:59 AM
Problems!! DoctorCastle Chevy Impala 6th Gen Discussion 6 08-17-2009 10:27 AM
RDS Radio problems lavee383 Chevy Impala 7th Gen Discussion 14 05-12-2009 11:25 AM
Heating Problems/Cd Problems ethelaugg Chevy Impala Discussion 0 01-14-2009 08:03 AM
