2006 3.9L ENGINE HOT A/C OFF Message - Page 3 - Chevy Impala Forums
post #31 of (permalink) Old 06-01-2012, 11:09 AM
jw06's Avatar
Engine hot AC off - again
Two weeks ago I got the "Engine hot AC off" message and the temperature gauge went to cold. After reading these post I replaced the temp sensor and all was well until last night when the message came back. Could this be a thermostat too or could the sensor be bad after two weeks?
jw06 is offline
post #32 of (permalink) Old 06-01-2012, 11:18 AM
Might be the pigtail for the sensor.
post #33 of (permalink) Old 06-01-2012, 10:15 PM
OEM LOL
Ejbiers's Avatar
Exclamation Problem solved!
I had the same problem and it was my thermostat. I took the thermostat out and the rubber seal to seal the thermostat when its closed(not where it was sealed into the engine) was keeping the thermostat open all the time. If you let your engine hot a/c off message go long enough you will get a check engine light and a code(i forget the code) but the code will be the motor is taking too long to warm up (because the thermostat is stuck open and constantly flowing coolant through your motor instead of opening the thermostat and allowing coolant to flow only when your motor reaches 180degrees).
Do not try to pop your thermostat out and fix the seal it is most likely stretched out and shot and even if it wasn't it will still be damn near impossible to try and fix it. just spend the $22 for a new thermostat. The OEM thermostats are cheap and garbage which is why this is a common problem and alot of GM vehicles from pickup trucks to suvs to cars.
The reason you don't get a check engine light right away is because the car taking too long to warm up is not good for the car but its not gonna destroy the car. It will put a pending code on the computer though it just takes some time for the code to register.
Also the temp gauge on the newer cars are not a real representation of the temp. It is a estimate of where the car should be at that point in time. So all the computer does when that message appears is shut down your temp gauge (your motor isnt really that cold). People would freak out when they saw how much the temp gauges would fluctuate when driving so the car markers made the temp gauges 'artificial' so people wouldn't worry so much.
Hopes this solves your problem or at least gives you some insight on it!
2016 Mustang GT PP Premium
Know the truth
http://infowars.com
Ejbiers is offline
post #34 of (permalink) Old 06-02-2012, 09:58 AM
systemcheck2006's Avatar
+1 for post
then you'd be normal."
systemcheck2006 is offline
post #35 of (permalink) Old 07-09-2012, 09:46 AM
dalejrfan88's Avatar
Originally Posted by systemcheck2006 View Post
+1 for post
I had the low coolant loss on my 07 3lt with the 3.9 but never got the "engine hot" turns out my 3.9 was eating coolant due to a bad coolant crossover pipe and poor headgasket and intake gasket...even when i was looking at several used models i noticed that the 3.9s and 3.5 always had very little coolant at the bottom of the resevoirs. Now i see in 2012 they finally went with a more sealed resevoir that is filled to the top
dalejrfan88 is offline
post #36 of (permalink) Old 12-30-2012, 02:53 PM
Impala_Ken's Avatar
I realize this thread is long cold (no pun intended), but just thought I would add my experience on my 2006 3.5 VIN-K. I got the same mystery message "Engine Hot, A/C Off" one day a few weeks ago, I thought I had overheated and ruined my engine (never heard a warning chime, maybe because my driver door speaker had recently failed). I thought I had ruined my engine, but the heater was working fine and the engine seemed okay. The temp guage stayed pegged at "C" through several warm-cool cycles, so replaced the sensor (had to remove driver-side upper motor mount and small coolant pipes to access the sensor. Problem went away (probably due to battery disconnect) for several weeks and through a long 3300 mile vacation, but came back last week. This time I replaced the thermostat since it appeared the observed engine temp varied between 185 and 203 degrees and figured maybe it was sticking (never had my analyze with me when the code would post). Has been quiet since, but won't know for sure for a few weeks. Old thermostat looked perfect, but I have 208K miles on this car.
Impala_Ken is offline
post #37 of (permalink) Old 12-30-2012, 02:58 PM
Impala_Ken's Avatar
Side note: the electrical info in Chiltons seem to indicate that the temp sensor is routed to the Power Control Module and Body Control Module before it goes to the temperature guage. I find it odd that when we get the "Hot Engine, A/C Off" message that the control modules seem to shut the temp guage off. Is there a flash fix for this???
post #38 of (permalink) Old 12-30-2012, 04:08 PM
463
463's Avatar
Hi Ken. when the "Hot Engine, A/C Off" message is on the computer is programed to shut the temp guage off. Is there a flash fix for this? Non that i know of.
The "t" stat can be checked with a thermometer and a pan of water as the temp rises to 195oF the t stat should open smoothly and close when removed fron the heat.
The temp gauge in the car should come up from cold to lets say sit at 1/2 way and stay at that point, at this point the t stat is controling temp and the cooling fans the take over the rest of the cooling as the cooling demands increase.
make sure the cooling recovery tank is at the full cold when the engine is cold, there is a chance the new temp sender is messed up or there is air in the cooling system.
A weak rad cap will also mess with the temp as the psi is to be at 15 lbs then the cooling system is working.
Welcome to the forum
463 is offline
post #39 of (permalink) Old 12-31-2012, 11:12 AM
Impala_Ken's Avatar
Thanks. This also may be old news, but when replacing the thermostat I did not follow my instincts and used the thermostat housing torque specs in the Chiltons instead (which is the same as the Factory Service Manual). When I heard the bolt fail I knew I should have waited and looked for a bulletin. Fortunately I had only stretched the bolt and there was enougn metal remaining and I could back it out. Could have been much worse. The thermostat seal is only a rubber O-Ring, I could have done it by "feel'.
For the V6, the stock manuals I have found specify 18 ft-lbs, which is WAY too much for M6 screws. Using the "Just Answer" web-site I paid an online mechanic to look it up and he found the following Bulletin which corrects the torque for V6 (covers 2006 -2008, I believe - did not see the Bulletin).
New specs: 7.4 ft-lbs, or 89 in-lbs.
I was guessing 8, within the range for an M6x1.0 bolt ( 7 - 9 ft-lbs).
post #40 of (permalink) Old 03-13-2013, 06:51 PM
DallaSS 214
TxImpala89's Avatar
I got my struts replaced today (i know this has nothing to do with it) but i down the street from my house when the "engine hot/ac off idle engine" message came on the display and the temp gauge shot up all the way to the top to red! i pulled into my place and it went down to normal temp and the message dissapeared along with the continuous warning chime (all withing 2 minutes) what should i look into?
PROJECT LINDSAY!
TxImpala89 is offline
post #41 of (permalink) Old 03-14-2013, 07:46 AM
TxImpala, I know you're seeking advice from other owners but I just wanted to let you know that visiting your dealership would be a great next step. This way their specialized technicians can run the proper diagnostic checks on your vehicle. And if you would ever like assistance working with your dealership towards a resolution, please feel free to contact me anytime through private message on this forum.
Best,
Katie
Chevrolet Customer Service
post #42 of (permalink) Old 03-14-2013, 09:38 AM
DallaSS 214
TxImpala89's Avatar
So on my way to work this morning the same message came on, this time with the "change oil soon & check engine light" managed to make it to where i change my oil regularly, they said the cam shaft sensor was leaking, I'm waiting here for further info
PROJECT LINDSAY!
post #43 of (permalink) Old 03-14-2013, 01:16 PM
DallaSS 214
TxImpala89's Avatar
Now they are saying intake gasket! They don't know anything! Taking my car to my mechanic
PROJECT LINDSAY!
post #44 of (permalink) Old 03-18-2013, 01:29 PM
Impala_Ken's Avatar
On my '06 Impala 3.5 I replaced the sensor and the problem went away for a few weeks but came back. The dash guage does not read directly off the temp-sensor, the sensor feeds to the computer and then the guage is fed by the computer (was told it is done this way because the temperature actually varies so much it freaks owners out). Once the computer senses an over-heat it puts out the "Engine Hot, A/C Off" message and for some reason drops the temp reading to "C". Changing the sensor probably restored the temp range to the computer and allowed me to run "error free" for a while, but my real problem was the thermostat. The little rubber seal at the valve portion had disintegrated (not the seal around the outside edge of the thermostat body). Have not had a problem since I replaced the thermostat.
Shortly after that I had another sensor go bad on a cold night, the engine oil-pressure sensor. I was working far from home, so I shut the engine down and coasted to a gas-station (thank God, it was below zero). The engine sounded okay, but did not want to chance it, so had it towed to the nearest Chevy dealer who determined my oil pressure was good and the sensor was bad. I have 215,000 miles and the car and engine still drive like it always had, so I cannot complain too much!
post #45 of (permalink) Old 05-16-2014, 05:36 AM
Bobby69's Avatar
Try replacing thermostat first. I replaced my sensor first and still got the same code..
Bobby69 is offline
LinkBack to this Thread: http://www.impalaforums.com/chevy-impala-8th-gen-discussion/241232-2006-3-9l-engine-hot-a-c-off-message.html
My 2006 Chevy impala dash readout says Engine hot ac off. What does this mean Dealer fixed the thermostat and still is running the same This thread Refback 06-24-2013 08:04 PM
Untitled document This thread Refback 02-23-2013 10:29 AM
Untitled document This thread Refback 12-22-2012 09:18 PM
06, 3.9, Turn AC off, engine overheating, Temp guage stays on cold - Chevrolet Forum - Chevy Enthusiasts Forums This thread Refback 08-07-2011 10:52 AM
06, 3.9, Turn AC off, engine overheating, Temp guage stays on cold - Chevrolet Forum - Chevy Enthusiasts Forums This thread Refback 01-05-2010 08:49 PM
2006 3.9l with engine clack and rough idle spartus 8th Gen Engine Performance 3 11-15-2009 06:50 PM
Change Engine Oil Message luke_fairs Chevy Impala 7th Gen Discussion 9 07-02-2009 06:13 PM
message center problem ladyimpala 7th Gen Engine Performance 10 03-04-2009 07:58 AM
2003 Chevy Impala...Change engine oil message just came on.. is it simple to fix? backyard mechanic Chevy Impala Discussion 2 05-28-2008 06:40 PM
