07 impala window defogger - Chevy Impala Forums
post #1 of (permalink) Old 08-18-2009, 10:51 AM Thread Starter
jhollen's Avatar
I have an 07 impala. The rear window defogger won't work. It happened about a year ago while under warrenty. The dealer mechanic said they replaced something under the dash that had collected moisture. He said it was a known problem. I'm out of warrenty so I'm doing it myself. I have checked the relay and the grid on the window and all related connections and all are ok. Can someone enlighten me if there is something under the dash like a connection or module I can check.
jhollen is offline
post #2 of (permalink) Old 08-18-2009, 01:01 PM
blusail's Avatar
Was it over a year ago? If they replaced a part and it was less than a year ago, then if the problem is the same part then can do a parts warranty on it and it shouldnt cost anything. If you have the invoice from when you had it done see if you can find a part number on there and I can tell you what the part that they replaced(if any).
blusail is offline
post #3 of (permalink) Old 08-18-2009, 01:58 PM Thread Starter
jhollen's Avatar
It has been over a year. I contacted the dealer. Being I was 2k miles over warranty they brushed me off. I even contacted GM and got the same result. When I said about a year, after checking it was several months past that.
jhollen is offline
post #4 of (permalink) Old 12-09-2009, 08:03 AM
chaser1023's Avatar
Unhappy
can anyone else chime in on this....because my defogger isn't working either.
It just stopped....no idea why! I used to have a dealer less than four miles from my home, straight shot down the highway. They've closed down. next dealership is quite an inconvenient trip now. So I have really resorted to solving what I can when I can, but this defogger thing is just a mystery.
chaser1023 is offline
post #5 of (permalink) Old 12-09-2009, 10:26 AM
damn pos new parts that they put on cars
4 B BODIES
2 SOLD CAPRICES
post #6 of (permalink) Old 12-30-2009, 12:46 AM
LisaWilliams's Avatar
If your vehicle rear window defogger does not appear to be doing the trick, it may have a faulty fuse or grid. Most of impala model come equipped with rear window defoggers as a standard feature and you can troubleshoot the defogger with a single kit available at most auto repair retailers.
LisaWilliams is offline
post #7 of (permalink) Old 01-22-2010, 01:44 AM
mattkremer39's Avatar
defog
Mine isn't working on my 06 SS. its so annoying!
mattkremer39 is offline
post #8 of (permalink) Old 01-22-2010, 07:42 AM
Moderator
wanderson75's Avatar
First, get a multimeter, you'll need this.
Start the car, and turn on your rear defroster, and read the voltage and make sure it's reading 12-14v. If not, then look at your fuse and circuit breaker. There's a 60A fuse in the bottom jbox under the hood. And a 30A circuit breaker behind the right side fuse box. If the fuse and circuit breaker are good, then it's the defroster relay.
If you ARE getting voltage:
Unplug the defroster leads on the back window and take a multimeter to your grid and read the resistance across it (the contacts on the window, not the leads that were plugged into it.). If it reads 0, it's open and the grid needs replaced. If it reads 1 or less (but not zero) it's shorted and needs replaced. If it's reading something else, then more than likely you have a wiring issue.
–adjective
Last edited by wanderson75; 01-22-2010 at 07:53 AM. Reason: Rechecked my wiring diagrams.
wanderson75 is offline
post #9 of (permalink) Old 02-12-2010, 03:48 PM
dit13841's Avatar
wanderson75,
Would this be the same for an 06 impala? The reason I am asking is because by the owners manual I have a relay under the hood that I can hear work as I turn the defogger on and off so I am assume that is working ok. When I check voltage at rear window I get nothing again I am assume I have a blown fuse. So would my fuse be inside the right fuse box or would it be under the hood?
Thanks for your help
dit13841 is offline
Electrical connector 62 Impala power window javigolf Restoration Forum 5 09-22-2009 10:55 PM
77 impala 1/4 window trim Dime Restoration Forum 1 08-04-2009 03:25 PM
Window wont crank (62 impala)? vanessaskiss Chevy Impala Discussion 0 05-14-2008 12:25 AM
67 Chevy Impala Chrome Window Molding? l_alvarad0 Restoration Forum 1 11-20-2007 01:17 AM
My 2002 Impala driver window goes down but not up why? emmamom Mechanical and Electrical Problems 0 09-21-2007 10:44 AM
