Vibration/Shaking - Chevy Impala Forums
post #1 of (permalink) Old 07-29-2009, 05:40 PM Thread Starter
SS Petey's Avatar
Vibration/Shaking
I have an '08 Impala SS and I have a pretty noticable vibration in the car between 60-70mph. It doesn't happen before or after 60-70, just between those speeds?? Any thoughts?
SS Petey is offline
post #2 of (permalink) Old 07-30-2009, 03:44 PM
ImpSS07's Avatar
Wheels unbalanced?
My bearing hub assemblies were bad and caused some shaking on mine.
ImpSS07 is offline
post #3 of (permalink) Old 08-01-2009, 04:50 PM Thread Starter
SS Petey's Avatar
I had the wheels balanced and aligned not too long ago, but I'll check into the Hub Assemblies though....
Thanks.
SS Petey is offline
post #4 of (permalink) Old 12-04-2009, 07:24 PM
Craigss's Avatar
Similar issues
I had a rt front tie rod and hub replaced and balanced all four Corners at the chevy dealer and mine improved....however, be aware that the chevy dealer may not be able to balance tires while on the car at a speed above 55. Yes, that's right. only 55.
You may want to consider, as well as any other users of ultra high performance tires on those big 18" aluminum wheels, finding a tire dealer capable of balancing your tires on the car and at 80mph. That should address all the factors that you need to consider for the smoothest highway ride.
Craigss is offline
post #5 of (permalink) Old 12-06-2009, 08:25 AM
xx rider's Avatar
i believe ur intermedite shaft has gone bad.. this will give a false input .making you think the strut, wheel/tire and or bearing is defective... i think the 06 and up impala ss, ltz .and other malibu models all share this issue,, but those are my thoughts..check with the dealer,,mite be bulliten or covered under warranty
xx rider is offline
post #6 of (permalink) Old 08-16-2015, 05:25 AM
mrdmenace59's Avatar
so i have replaced the wheel bearing hub on both front end sides. and they def needed to be replaced and it made it better but the car still shakes above 60mph. any clue what i should try and replace next? i also balanced tire and rotated them.
mrdmenace59 is offline
post #7 of (permalink) Old 08-16-2015, 05:30 AM
chevyimp08ohv3.5v6's Avatar
chevyimp08ohv3.5v6 is offline
post #8 of (permalink) Old 08-16-2015, 11:12 AM
KG2014's Avatar
Quoted: 55 Post(s)
Tie rods and controls arms. Make sure they are all tight. I also got a vibration I'm trying to track down in my car.
Yeah I got a few mods.......
Check out my mod thread here
Check out my garage here
KG2014 is offline
post #9 of (permalink) Old 08-18-2015, 05:35 AM
acammer's Avatar
I've got the shakes at that speed too. Previous owner went through hubs, brakes, even a rim trying to track it down but never could. Everything seems to be tight, just put a new set of tires on the back, still haven't been able to cure it.
2007 Impala SS - Magnaflow Exhaust, K&N CAI
2011 Camaro SS - Headers back, intake, ported TB, tune, 412rwhp
1993 Dodge 1-ton, 1st Gen Cummins power!
acammer is offline
post #10 of (permalink) Old 08-18-2015, 05:37 AM
2002impalaLS's Avatar
Could be a cv shaft causing the problem
2002impalaLS is offline
post #11 of (permalink) Old 08-18-2015, 07:12 AM
acammer's Avatar
That thought has crossed my mind. It will probably continue to worse if that's the case, which would actually be good as it would make tracking it down easier.
acammer is offline
post #12 of (permalink) Old 08-18-2015, 01:37 PM
KG2014's Avatar
Quoted: 55 Post(s)
I still battling a vibration in my car. Noticed at speeds above 70 the vibration is barely noticeable. But at speeds of around 40 you can really feel it. Feel it more when coasting then when driving. Going to jack up the front end today and check everything.
KG2014 is offline
post #13 of (permalink) Old 08-18-2015, 02:15 PM
ajm786's Avatar
It means your wheels are bent.
http://www.impalaforums.com/chevy-im...lay-dough.html
ajm786 is offline
post #14 of (permalink) Old 08-18-2015, 03:29 PM
KG2014's Avatar
Quoted: 55 Post(s)
It's not the wheels. Did it with factory steel rims with new tires and my brand new rims with new tires. So I can eliminate the rims and tires from both sets.
KG2014 is offline
post #15 of (permalink) Old 09-03-2015, 05:40 AM
Also when I'm braking I can feel the shaking in my stealing wheel, not all the time but if I slow down quick I def can feel it. And what ever it is is on my right side....replaced everything but cv joint arms and the caliber.
Also need help with Vibration? bdhahn73 Chevy Impala 7th Gen Discussion 6 03-01-2009 05:43 PM
vibration??? lowminitruckin Chevy Impala 7th Gen Discussion 3 02-28-2009 05:24 PM
2000 Impala is shaking when i drive it. what could be causing this? str8ballin17 Chevy Impala Discussion 2 06-04-2008 08:19 PM
2000 impala engine shaking.? cmoven Chevy Impala Discussion 1 02-26-2008 02:36 PM
2003 chevy impala right cooling fan is shaking and making alot of noise? saltlife Mechanical and Electrical Problems 1 09-04-2007 05:26 PM
