| Chevy Impala 8th Gen Discussion W-Body 2006, 2007, 2008, 2009. Discuss all Chevy Impala 8th Generation Performance and Technical Discussion here. |
Problem with my 07SS
I am not sure where to post this issue as I do not know what type of issue it is.
When I bought the car in March, I would hear a very faint squeek when I backed out of parking spots (wheel turned sharply left, in reverse). The dealership thought it was the steering rack. They replaced the steering rack. Since doing so, the squeek has gotten worse. It now happens whenever I have the wheel turned sharply at very low speeds (abt 5 mph... parking lot driving) whether left or right, forward or reverse. The squeek sounds similar to a brake squeal, but never happens with my foot on the brake. It sounds like its coming from the wheels, but I could definitley be wrong, and is not consistent with the rotation of the wheel. I will hear about 3-5 separate squeels per one wheel rotation. It sounds as if the driveshaft may be rubbing up against something. I really have no idea what this could be. Any thoughts would be greatly appreciated so that I can bring this to the dealership with SOME suggestions. Thanks as always fellas
Have you visited the Impala Forums Store today? Thousands of cars & parts for sale! Last edited by Manoogia86; 06-29-2009 at 10:48 AM.. |
Sounds like an axle issue.
__________________ My name is Angel. I have been around B-bodies since mid 2000 and have been working on them since about 2002. I work at a shop that specializes in the repair and restoration/refurbishing of 91-96 Caprice and Impala cars. I do not and have not claimed to know everything about these cars, but by seeing a great deal of these cars daily I can usually be of some help in giving advise when a problem comes up. Feel free to ask questions
#3 (permalink) |
Really? I would have never guessed that.
I have an appt. the 11th I will definitley mention that possibility when I bring it in. Any other thoughts from anyone would be very helpful.
#5 (permalink) | |
__________________ 2009 G8 GT 6.0L V8,PSP,V8 6.0 Side Badges, Holden Rear Deck V Badge,JBA Shorty Headers,Magnaflow Axle-Back,X-Pipe,Volant Powercore CAI,Superchips Cortex Tuner,Lovells Shocks and Struts Gas Legend,Eibach Pro Kit Springs,BMR Sub Frame Connectors,G8 Door Sill Plate,Red Hot Shift Knob,LED's Lights,HID's 35W 6K Lights,HID's Fog's 25W 8K lights.Silver Carbon Oil Cap,Mobil1 5W30 |
#6 (permalink) |
Hopefully that is all it is... I am keeping a list of possiblities... so far I have the following:
- Brake parts not alligned correctly, causing rubbing - Steering shaft rubbing - Axle related issue - CV joints need greasing Any other ideas are appreciated until I bring this in for fixing 7/11/09.
#7 (permalink) |
I had a similar problem with my last car. I would hear a slight squeak at slow speeds up to 8-10 MPH and after losing my mind and replacing everything I possibly could it turned out to be the hub bearing. I had gotten an really good deal on 4 new bearings and decided with 180k on the clock to replace all 4 and the sound disappeared!!! So check the hub (might need to be repacked or replaced) and if not probably CV joint.
#8 (permalink) |
When they changed the steering rack they also changed one of the hub assemblies... after that service the issue only got worse... im wondering if they skipped a step or possibly need to do the other side :confused:... we will HOPEFULLY find out this saturday.
#9 (permalink) |
so what was the outcome? did they fix it or.....................
#10 (permalink) |
Fixed... It was the Anti Squeek sensors on the brake pads... figures the anti-squeek mechanism was CAUSING THE DAMN SQUEEK...
Also it needed a new ISS.... this is the 4th time it has been replaced since birth...
| Strut Tower Braces on 07SS | Manoogia86 | 8th Gen Suspension | 11 | 07-03-2010 08:16 AM |
