2013 throwing codes - Chevy Impala Forums
 6Likes
  • 3 Post By sheila
  • 1 Post By carnau
  • 1 Post By pleasehelpme
post #1 of (permalink) Old 06-01-2017, 05:17 AM Thread Starter
pleasehelpme's Avatar
2013 throwing codes
I might've posted on another thread by accident, so sorry if I did
Anyway,
I just bought a 2013 impala ltz a few days ago from a lot. Wouldn't you know it.. went to drive home from work and as soon as I started it there was the check engine light on. The car seems like it's running fine still so far? Maybe not though. Seems a little weak-ish compared to before? Maybe that's in my head. I noticed white smoke when I started it though, but it went away shortly after. Here are the codes.
p0171
p0174
p0300
p0455
p0496
Can anyone explain to me what each code is and what it could be? (Chances are what each code could be?)
I'm wondering if I just bought something full of problems that's going to need a ton of money put into it.. I just left Ford because of that.
pleasehelpme is offline
post #2 of (permalink) Old 06-01-2017, 07:55 AM
Quoted: 73 Post(s)
Is the vehicle still under the new car warranty? If not, did the selling dealer provide any type of short-term warranty? If not, did the selling dealer provide any type of "bring it back for a refund if not happy within XXX days"?
Read this article: http://sandyblogs.com/techlink/?p=1816 - It MAY apply to your situation.
post #3 of (permalink) Old 06-01-2017, 08:16 AM
Quoted: 41 Post(s)
^+1. I'd take it back to the lot and demand they deal with it. Fwiw, p0171= lean bank#1, p0174= lean bank#2, p0300= random/multiple cylinder misfire detected, p0455= evap. emission control system leak detected (gross leak) and p0496= high purge flow. I'd wager the purge valve solenoid underhood needs replaced to cure all these codes.
plano-doug, Josh124 and 12 lt like this.
sheila is online now
The Following 2 Users Say Thank You to sheila For This Useful Post:
cj1 (06-01-2017), plano-doug (06-01-2017)
post #4 of (permalink) Old 06-01-2017, 02:18 PM
Josh124's Avatar
Quoted: 24 Post(s)
Based on that assortment of codes it's probably a simple evap system issue like sheila said. Here's a thread on how to change the underhood canister purge valve that likes to go bad on these vehicles along with a list of the possible symptoms you may experience:
http://www.impalaforums.com/chevy-im...ml#post3059946
Josh124 is offline
post #5 of (permalink) Old 06-01-2017, 08:32 PM
carnau's Avatar
Hey I created a youtube video a while back about replacing a purge valve for the P0496. Hope this helps, sorry it is upside down but still easy to follow.
carnau is offline
The Following User Says Thank You to carnau For This Useful Post:
TSS (06-02-2017)
post #6 of (permalink) Old 06-01-2017, 08:43 PM Thread Starter
Read this article: Damaged Engine Wiring Harness - It MAY apply to your situation.
I live in Ohio so I get screwed for stuff like this when it's a new car, and it's at 114k miles so I believe it's not under any warranty. In Ohio they are allowed to do the "as is" crap. So I had to roll the dice here. So you're all pretty confident that if I replace that purge valve that it might cure majority of these issues? Same with probably a new gas cap?
Also, I took it down the road about an hour ago. I gun'd it pretty hard. Basically the pedal to the floor to clear it out and see if, hopefully not, a transmission issue. I don't think it is a tras issue though? It seemed to be shifting pretty easily into each gear. the only thing I noticed was it would shift at like 5,500 RPM (can't remember which gear it was probably in). That might be normal? I haven't had a car in so long. I had a crap ford f150 for so long and it obviously never shifted that high in RPM. It sounded okay though when it was shifting. What do you all think? Any insight on anything I said in the two paragraphs is greatly appreciated. Thank you.
post #7 of (permalink) Old 06-02-2017, 12:51 AM
Quoted: 73 Post(s)
I suspect that replacing the purge valve as suggested by sheila, Josh124 and carnau will correct the problems. The part is inexpensive and easy to replace. I would buy a genuine GM part (Delco) from a dealer or an AC Delco jobber.
I bought a new 2012 Impala LTZ - now with a a family member. I had previously owned a 2008 & 2011 Impala LTZ. The 2012 model with the 3.6 V-6 and 6-speed transmission was a very good performer and much better than the 2008 & 2011 models. I now own a 2014 Impala 2LTZ with the same engine / transmission and it is a good performer.
post #8 of (permalink) Old 06-02-2017, 03:08 AM Thread Starter
I love the engine. It seems powerful. Glad to hear that you think the trans for the 3.6 on the 2013 is a good performer. Does that RPM sound about right when it shifts once I really gun it? And just so I'm clear here, that purge valve might possibly fix those codes? That would be wonderful if it does. I like the look and feel of this car, and I really can't afford super huge payments.
post #9 of (permalink) Old 06-02-2017, 04:44 AM
Quoted: 48 Post(s)
Unfortunately as is is common most places when buying used and it is buyer beware unless otherwise noted.
The 3.6 and 6 speed imo are pretty reliable if taken care of. Bought our 2012 new and now have around 125000 miles on it, it has had the check engine light come on a handful of times, pretty sure they were all related to gas cap as they eventually cleared out on their own and when I tried retrieving any archived codes with my scanner there were none.
Shifting above 5500 with your foot in it is not an issue.
post #10 of (permalink) Old 06-02-2017, 05:26 AM
reubenswinks's Avatar
Quoted: 24 Post(s)
Sounds right to me. I think full throttle they shift at 6500 rpm when stock. At least that is where my 2013 does.
reubenswinks is online now
post #11 of (permalink) Old 06-02-2017, 07:59 AM
Quoted: 70 Post(s)
as a side note after changing out the evap part they listed above it might take a few restarts for the code to go away. so don't be totally alarmed if it doesn't kill the code instantly. i changed the under the hood evap part and it didn't fix it (was like $24 on a 2010 with a 3.5 motor, not your 3.6 so prices will vary). for me to get rid of the evap code it was the purge canister in the drivers rear quarter panel (that was about $80 at autozone/advanced for the 3.5 motor). both were very easy fixes and common issues honestly from what i can see around these forums. if you feel confident ordering the part online vs a parts store you can check out rockauto.com they often have the same parts for reduced prices after shipping. there are also 5% off coupon codes for additional savings usually.
post #12 of (permalink) Old 06-02-2017, 04:11 PM Thread Starter
Yeah it's very upsetting. But I knew that going in, and I'd rather take the gamble on this car than that truck honestly. This car seems like it was taken care of for the most part. Minor cosmetic problems. Still has the power behind it I feel like. So maybe each one of these are related to the cap? And isn't a big issue?
Awesome, thank you.
Thank you for informing me about that. I'll end up checking out both of them. I might just let my mechanics because they're extremely trustworthy and I'm not the -best- mechanic by any means. But I can relay this to them. You guys are the best. Appreciate the help.
If anyone has anymore to suggest or any imput, please go right ahead.
post #13 of (permalink) Old 06-02-2017, 04:33 PM
Quoted: 48 Post(s)
No sorry, I was not referring to your issue as being a gas cap issue but rather that that has been the only cel we have had with ours since we bought it. Just my opinion that these are solid drivetrains in these cars.
I think Sheila probably has it right. From the sounds of it that is not a tough fix and may well fix all your codes.
Good luck with it, and please report back the results.
post #14 of (permalink) Old 06-07-2017, 05:03 AM Thread Starter
Oh you're fine then.
So, my mechanic called me and they're confident that it's the evap valve under the hood and gas cap. Easy and cheaper fix. -Hopefully- that's all it is and I'll find out after I drive it some more. Might post here again later to update and such.
Thank you all so much!
post #15 of (permalink) Old 06-16-2017, 06:32 PM Thread Starter
So, we replaced the purge can and the code came back. Just replaced the gas cap. Hopefully it doesn't come back on. So stressful.
Throwing nitrous in the impala?? tlaclare 8th Gen Engine Performance 37 05-12-2017 01:16 PM
Two P0455 Codes on a 2013 Impala LT jay408 Chevy Impala 8th Gen Discussion 2 11-24-2016 05:34 AM
throwing code 172 bcwarlock2 Chevy Impala 7th Gen Discussion 1 05-04-2013 10:30 PM
08 Impala LT throwing multiple codes blackrosetiger Autocare and Maintenance 7 04-23-2013 06:31 AM
2003 9C1- throwing codes and hesitating HighwayLurker Chevy Impala 7th Gen Discussion 7 03-30-2009 07:37 AM
