2008 LT High-Beam Problems - Chevy Impala Forums
 2Likes
  • 1 Post By Revo2Maxx2016
post #1 of (permalink) Old 03-23-2017, 01:29 PM Thread Starter
tubby131313's Avatar
This morning I noticed my left side high beam wasn't coming on while the right side was working fine.
I checked the bulb and the fuses, the bulb works and the fuse was fine (I replaced it to be sure) but the light still doesn't work. So I checked the fuses for voltage and sure enough the left side fuse has no power. I assume the problem has to be between the relay and the fuse but I have no idea where the relay is located.
Any help would be appreciated.
tubby131313 is offline
post #2 of (permalink) Old 03-23-2017, 06:58 PM
Revo2Maxx2016's Avatar
Quoted: 82 Post(s)
If you have one High Beam working there there is an issue inside your Box. Here is why. The High Beam Relay controls both the right and left. So if you test one of the Fuses and it don't have power while the other one does then there is a issue inside the box. Your Car and many of the IMpalas before yours have PCB controlled Light Relays that are not changeable.
From your None changeable Relay inside the box there is some Copper traces that run to the 2 fuses. from the fuses out to the connector where it exits the box.
James
James
Revo2Maxx2016 is offline
post #3 of (permalink) Old 03-23-2017, 07:04 PM
Quoted: 82 Post(s)
Here is a Picture to give you a better idea of what I am talking about for your Fuse box... Please note the broken trace.
This isn't a Impala Box It is a GM product, this is to give you an idea of what I am thinking it could be...
James
James
post #4 of (permalink) Old 03-24-2017, 02:04 PM
paker's Avatar
Quoted: 14 Post(s)
I am thoroughly impressed by the wealth of info. Especially, Revo.
I wonder if all cars have both high beams in one circuit and low beams in two split circuits. My other Ford is just this way.
paker is offline
One Kit H8 H9 H11 3200 LM High Power 6500K Headlight High Beam White RSS Bot Impala Diecast Toys Cars on eBay 0 06-22-2015 07:30 PM
6400LM Totally White LED High Power 9005 9055 H10 Headlamp High Beam RSS Bot Impala Diecast Toys Cars on eBay 0 06-17-2015 09:21 PM
4000LM 9005 H10 Headlight High Beam High Power Cree Yellow White All in One LED RSS Bot Impala Diecast Toys Cars on eBay 0 04-10-2015 08:11 PM
H8 H9 H11 High Power 4000LM White Cree LED Headlamp High Beam Heatsink Projector RSS Bot Impala Diecast Toys Cars on eBay 0 03-09-2015 12:10 AM
2000 chevy impala low beam and high beam?? impala0712 Chevy Impala 7th Gen Discussion 7 09-11-2012 08:38 AM
