Omg!! There is coolant everywhere!! - Chevy Impala Forums
 5Likes
post #1 of (permalink) Old 01-19-2017, 04:23 AM Thread Starter
AutoZone Employee
dcooper323's Avatar
Exclamation Omg!! There is coolant everywhere!!
Now that I have your attention, i come looking for help.
So yesterday as I am coming through my little town, I started smelling antifreeze. Pulled over and noticed a good amount dripping from the passenger side front wheel. After further investigation(and by investigation i mean the belt was screaming like a banshee), coolant is getting on the belt, and saturated quite a bit of the area by the pulleys.
So i did some research on here and pretty much narrowed it down to 1 of 2 things, and an option for a 3rd.
-Coolant Crossover Gasket. I hope it isnt this, but i am prepared to dive in to repair it if need be.
-Water Pump. Of the possibilities, I hope this is it, as there are enough DIY videos on YouTube for this. I could not find a how-to for the coolant crossover gaskets, so I would be going in blind.
And the longshot, a coolant hose. I didnt really look at it when I was there to see if there was even a hose in that area.
My question for the audience, Is there any real way to narrow down which is leaking? Everything is pretty much soaked, and it was a pretty substantial leak. Im talking about letting it sit for 5-7 minutes and having 3 separate puddles of DexCool under my car that were about 4-5 inches in diameter.
dcooper323 is offline
post #2 of (permalink) Old 01-19-2017, 04:55 AM
retiredpauly's Avatar
Quoted: 113 Post(s)
Hook a pressure tester to the system and pump it up to whatever the PSI rating is on your rad cap. ( 13 - 15lbs i'm guessing) You should see where it's coming from.
Most of the auto repair places will rent, or loan you a pressure tester if you don't have one.
Your probably gonna have to buy a new belt now as well as this ones been soaked in antifreeze. They will usually squeak and squeal after that.
Good luck and let us know.
retiredpauly is offline
The Following 2 Users Say Thank You to retiredpauly For This Useful Post:
dcooper323 (01-19-2017)
post #3 of (permalink) Old 01-19-2017, 05:04 AM Thread Starter
AutoZone Employee
dcooper323's Avatar
I appreciate the advice. I will see if we have one in store, and if not, im sure one of our shops will have one. Thanks again.
So when I hook the pressure tester to it, will it just start pushing coolant out of where it is leaking?
post #4 of (permalink) Old 01-19-2017, 05:15 AM
Quoted: 113 Post(s)
Yes.
If the engine is hot you will have to carefully remove the rad cap. If the engine is cold not problem, but, if it's hot, you will have to wait until the pressure is out of the system.
From the sounds of the leak you have that should not take very long.
Ensure the cooling system is refilled to where it's supposed to be. Then, hook up the pressure tester cap in place of the rad cap and hook it to the hand pump ( if it's that type, there are a couple different types ) and pump it up to the pressure rated on the cap. You will be able to see where the coolant is running out from.
Just to state the obvious here, but this is done with the engine NOT RUNNING.
Do not exceed the pressure rating on the cap with the test equipment.
If it's as big a leak as you are stating it should be pretty obvious pretty quickly.
post #5 of (permalink) Old 01-19-2017, 05:18 AM
Quoted: 113 Post(s)
Here is a generic type video of what your going to do.
post #6 of (permalink) Old 01-19-2017, 05:20 AM
jso2378's Avatar
Quoted: 17 Post(s)
Yes, It will show you where your leak is at. Your autozone store should have one they rent to customers. I know almost all of them do.
jso2378 is offline
The Following 2 Users Say Thank You to jso2378 For This Useful Post:
post #7 of (permalink) Old 01-19-2017, 05:27 AM Thread Starter
AutoZone Employee
dcooper323's Avatar
Yeah, I called, they do have one. I will be looking at this today.
My fear is that the leak will be in an area that wont help determine if it is the water pump or the crossover gaskets.. They seem to be near each other right?
post #8 of (permalink) Old 01-19-2017, 05:58 AM
Quoted: 57 Post(s)
what year and how many miles on the car, also which motor. it might help narrow down possible causes due to common issues with one engine over another.
Joes74challenger is offline
post #9 of (permalink) Old 01-19-2017, 06:14 AM
Quoted: 113 Post(s)
Making sure everything is dried off and wiping the joints etc with a rag. Then use your finger to check connections etc. Start at the very top and work your way down. A mirror on a stick may help you. I'm sure auto zone will have one for around 6.00. Handy to have on hand for future projects.
dcooper323 (01-20-2017)
post #10 of (permalink) Old 01-19-2017, 06:41 AM Thread Starter
AutoZone Employee
dcooper323's Avatar
2008 Impala LT. 3.5l Non Flex. 135k.
post #11 of (permalink) Old 01-19-2017, 08:50 AM
WickedGoat's Avatar
Quoted: 47 Post(s)
Clean the engine bay off so you can see where the coolant is spraying from. Make sure you top it off with water so that the system is full. The pressure tester will not work well with low coolant.
2014 Chevy Impala LTZ Limited
- My daily driver... 5% Window Tint, Rosen GM1210 Stereo, Addco rear Sway Bar, ZZP Strut Tower Braces... More to come
2004 Pontiac GTO
2004 GMC Yukon SLT
WickedGoat is offline
post #12 of (permalink) Old 01-19-2017, 01:32 PM Thread Starter
AutoZone Employee
dcooper323's Avatar
So I started it up to get it to where I need to work on it. It grinded like hell when it first started, and then just went to normal sounding. Not sure if the water pump is that bad, or if it is something else.
post #13 of (permalink) Old 01-19-2017, 02:42 PM Thread Starter
AutoZone Employee
dcooper323's Avatar
Some videos of the sound.
https://youtu.be/tMHxH_C6YD4
https://youtu.be/qcwuZOrT_LQ
Also, the pressure tester didn't work. There is a missing adapter.
post #14 of (permalink) Old 01-19-2017, 03:46 PM Thread Starter
AutoZone Employee
dcooper323's Avatar
A few things to note.
I didn't do the pressure test, but I did notice the water pump pulley was throwing small droplets of water. There was also water dripping on top of the AC Compressor. That's where it looks to be the most prominent leak.
The videos above show the sound as a started it, and after it had run for a few seconds.
post #15 of (permalink) Old 01-19-2017, 05:37 PM
Quoted: 113 Post(s)
I be thinking mechanical seal on water pump took a crap
Some one hit my car OMG Anonymous Appearance 54 02-28-2013 07:51 AM
omg omg omg omg omg LS7 on my local CL! NotAWimpyImpy Automotive Discussion 3 10-04-2011 09:39 PM
OMG! Smooth Operator 6th Gen Engine Performance 9 08-17-2010 09:21 PM
Omg iceship Automotive Discussion 10 01-19-2010 08:29 AM
OMG Check out this website! (May not BSFW) Richard Off-Topic Discussion 2 05-27-2008 08:58 PM
