service engine light - Chevy Impala Forums
  • 1 Post By plano-doug
post #1 of (permalink) Old 01-08-2017, 06:24 AM Thread Starter
rlc
rlc's Avatar
Question service engine light
have 2006 impala .service engine light is on and the horn wont blow help
rlc is offline
post #2 of (permalink) Old 01-08-2017, 07:23 AM
Quoted: 51 Post(s)
I'm not sure these two items are related.
The car still runs, correct? Can you drive it to an auto parts store? They can read the code causing the service engine light to be on. That will give you a starting point for diagnosing it.
As for the horn not working, did that just occur? Or was it a problem before the service engine light came on? There are several things which can cause this. And it takes some time and expertise to isolate it.
rlc (01-16-2017)
post #3 of (permalink) Old 03-21-2017, 03:31 PM Thread Starter
rlc
rlc's Avatar
the horn quit with the air bag light coming on.
rlc is offline
post #4 of (permalink) Old 03-21-2017, 04:29 PM
Quoted: 11 Post(s)
Sounds like it could be a sensor or something shorted from the wheel. Would definitely get that code checked out ASAP, obviously a wheel airbag deploy could be very dangerous.
Don't know if there were any recalls on the airbags on the impala, but would be worth checking.
12 lt is online now
post #5 of (permalink) Old 03-21-2017, 05:35 PM
Quoted: 51 Post(s)
I agree, sounds like something in the wheel/steering column.
The clockspring in the steering wheel hub connects the horn and the airbag. So I'm thinking that's the common link. (It's not really a clock spring, but resembles one, hence the name. It's actually fan folded flex-print.)
The clockspring can be damaged if the wheel gets over-rotated which can happen if the steering shaft is disconnected from the rack. (The wheel is supposed to be tied down whenever the shaft is disconnected.)
To the OP, has the car by chance recently been in for service on the rack or steering column?
Service traction control/Engine power reduced elizabeth82 Chevy Impala 8th Gen Discussion 0 04-28-2016 08:38 AM
Service Vehicle Soon light, no chk engine! den052 Chevy Impala 7th Gen Discussion 30 03-02-2015 02:19 PM
Engine Power Reduced/Service Stabilitrak. raymaane Chevy Impala 8th Gen Discussion 3 12-08-2014 05:25 PM
service engine soon light blinking tigwelder Chevy Impala 6th Gen Discussion 6 02-20-2014 09:35 AM
Message Center: Service Engine Soon BigCee Chevy Impala 7th Gen Discussion 23 10-24-2012 07:13 PM
