2003 9C1 - New ignition cylinder - 'Security' light on - Chevy Impala Forums
post #1 of (permalink) Old 02-01-2014, 06:00 PM Thread Starter
wakawu's Avatar
Like the title says, 2003 Impala 9C1. I just replaced the ignition cylinder and key with a new set due to the old set being hard to turn and I had to jiggle it to get it to unlock.
After the install I went ahead and turned the key in between the on and crank position then left it in the on position for 10 minutes.. as seen in this instructional
the security/battery light stayed on going back and forth from battery to security light. I cranked it over and it starts up just fine every time but the 'Security' light is still on solid in the dash when running. I tried the reset procedure 2 more times but after 10 minutes each time the security light doesn't go off. Could the ignition cylinder be defective or am I missing something?
Thinking maybe it would have been a better idea to just let a locksmith rebuild the old ignition switch as that only jammed up when put into the off position.
Anyway.. any advice?
2003 Impala 9C1
2000 Crown Victoria P71
wakawu is offline
post #2 of (permalink) Old 02-02-2014, 12:37 AM
g25racer's Avatar
So .. does it start just fine now and just the security light stays on now? Or ..
I would call around to locksmiths and ask if they have a tech 2 scanner. Some do. If not it's likely off the dealer and shop that does have one.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #3 of (permalink) Old 02-02-2014, 05:07 AM Thread Starter
wakawu's Avatar
Yep.. starts right up key works great just worried about the security light staying on while the car is running. What would this tech 2 scanner do? Reset the light?
2003 Impala 9C1
wakawu is offline
post #4 of (permalink) Old 02-02-2014, 12:45 PM
zerialz's Avatar
Quoted: 10 Post(s)
Did you unplug your battery when you swapped the ignition switch? If so I'd check the connections at the battery mine came on intermittently with a loose battery cable... after that I'd suspect the Passlock sensor.
zerialz is offline
post #5 of (permalink) Old 02-02-2014, 09:03 PM Thread Starter
wakawu's Avatar
Uh.. no I actually didn't. I just swapped out the cylinder real quick without touching anything else. Should I unplug the battery and leave it off for a bit then try again?
2003 Impala 9C1
wakawu is offline
post #6 of (permalink) Old 02-03-2014, 03:39 AM
g25racer's Avatar
Yes the battery should be unhooked if the pass lock sensor was replaced as well.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #7 of (permalink) Old 02-08-2014, 10:11 PM Thread Starter
wakawu's Avatar
So just an update... I dunno why I didn't think of trying this before but after fiddling around trying to relearn the new passlock code I removed the new tumbler cylinder assembly and swapped it back into the old passlock housing since the housing/passlock was still good and I only had an issue with the old tumbler/cylinder anyway. Plugged it into the ignition switch and it turned right on, no security light anymore. Didn't think that would work but there ya go. I figured there would be some sort of link between each lock cylinder and passlock but apparently not.. Saved myself the pain of going to the dealer.
2003 Impala 9C1
wakawu is offline
2003 Impala Security Light on - Won't Start james_fr Chevy Impala 7th Gen Discussion 37 09-21-2015 08:05 PM
2003 Impala-Security Light While running jawzgt Mechanical and Electrical Problems 4 07-16-2013 03:45 PM
how to reset change oil light on a chevy impala 2003 using the ignition? Ace Chevy Impala Discussion 1 08-15-2008 01:15 PM
00-05 Impala ignition cylinder with keys TESTING Private Wanted Classifieds 0 05-28-2008 02:24 PM
